[petsc-users] question about alternative to MatMatSolve
Mon Nov 4 21:49:50 CST 2013
Michael Povolotskyi <mpovolot at purdue.edu> writes:
> In my case each right hand side column is an almost empty vector with a
> couple of non zero entries.
> Is there any way to use the fact that the right hand side is very sparse
> and make the calculations faster?
Optimizing for this case would only give a small benefit because the
vector becomes dense during the forward-solve and the entire back-solve
has the dense vector.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131104/f8d5de91/attachment.pgp>
