[petsc-users] Questions about DMDA Local and Global vectors
    Anush Krishnan
    anush at bu.edu
    Mon Nov  4 11:09:18 CST 2013
I have some questions about the differences between distributed local and
global vectors that are created using the same DM.
   1. I used a local vector for 'x' in the KSPSolve function, and I got a
   size mismatch error (due to extra ghost points on the local vector). So I
   had to use a global vector to perform the linear solve, and then later copy
   the values to a local vector to be able to perform finite-difference
   stencil-type operations. This doubles my memory usage. Is there a way to
   use this without the extra storage?
   2. When I use VecView to print the vectors to file, the global vector
   gets printed in full, but only the local values on process 0 are printed
   for a local vector.
   3. Should I assume that I always pass only global vectors to PETSc
   functions, and use local vectors only when I perform the stencil operations?
Thank you,
Anush
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131104/74cb93a1/attachment.html>
