[petsc-users] confusion about MatSetValues(A, ,ADD_VALUES);
Satish Balay
balay at mcs.anl.gov
Fri May 31 11:59:01 CDT 2013
On Fri, 31 May 2013, Jed Brown wrote:
> 丁老师 <ztdepyahoo at 163.com> writes:
> > I write a simple c procedure to test the MatSetValues. the main body of procedure is like this
> > int row=1;
> > int col=10;
> > double v=1.0;
> > MatSetValues(A,1,&row,1,&col,&v,INSERT_VALUES);
> > MatSetValues(A,1,&row,1,&row,&v,ADD_VALUES);
> > MatSetValues(A,1,&col,1,&col,&v,ADD_VALUES);
> You can't mix INSERT_VALUES and ADD_VALUES. Please use debugging PETSc
> for development. It warns about this.
i.e use:
MatAssemblyBegin(A,MAT_FLUSH_ASSEMBLY);
MatAssemblyEnd(A,MAT_FLUSH_ASSEMBLY);
MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);
MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);
Satish
