[petsc-users] Solving Poisson equation with multigrid
Jed Brown
jedbrown at mcs.anl.gov
Wed May 29 23:05:01 CDT 2013
Michele Rosso <mrosso at uci.edu> writes:
> Hi,
> I proceeded as Matt suggested. I am running without nullspace
> (Dirichlet's BCs) with the following options:
> -pc_type gamg -pc_mg_cycle_type v -pc_gamg_agg_nsmooths 1
> -mg_coarse_sub_pc_factor_shift_type NONZERO -ksp_view -options_left
> The results are fine and the run finishes. The output of -ksp_view does
> not say anything about the coarse solver being shifted.
With petsc-3.4, it has these lines:
tolerance for zero pivot 2.22045e-14
using diagonal shift on blocks to prevent zero pivot
You can try a proposed fix in the branch 'jed/fix-gamg-coarse'.
Hong, I think this diagnostic output is unintuitive for a user that
doesn't know this relation. Shall we add the enum names to the output
lines below?
if (factor->info.shifttype==(PetscReal)MAT_SHIFT_POSITIVE_DEFINITE) {
ierr = PetscViewerASCIIPrintf(viewer," using Manteuffel shift\n");CHKERRQ(ierr);
if (factor->info.shifttype==(PetscReal)MAT_SHIFT_NONZERO) {
ierr = PetscViewerASCIIPrintf(viewer," using diagonal shift to prevent zero pivot\n");CHKERRQ(ierr);
if (factor->info.shifttype==(PetscReal)MAT_SHIFT_INBLOCKS) {
ierr = PetscViewerASCIIPrintf(viewer," using diagonal shift on blocks to prevent zero pivot\n");CHKERRQ(ierr);
