[petsc-users] Solving Poisson equation with multigrid
Michele Rosso mrosso at uci.edu
Wed May 29 18:22:49 CDT 2013
I attached the complete output.
I used 2 processors for this run. I wanted to use only one to have a
cleaner output but I could not because of this error:
[0]PCSetData_AGG bs=1 MM=32768
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Arguments are incompatible!
[0]PETSC ERROR: MatMatMult requires A, mpiaij, to be compatible with B,
seqaij!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29
11:26:24 CDT 2012
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./hit on a  named nid15343 by Unknown Wed May 29
18:15:24 2013
[0]PETSC ERROR: Libraries linked from
[0]PETSC ERROR: Configure run at
[0]PETSC ERROR: Configure options
[0]PETSC ERROR:
[0]PETSC ERROR: MatMatMult() line 8614 in src/mat/interface/matrix.c
[0]PETSC ERROR: PCGAMGOptprol_AGG() line 1358 in src/ksp/pc/impls/gamg/agg.c
[0]PETSC ERROR: PCSetUp_GAMG() line 673 in src/ksp/pc/impls/gamg/gamg.c
[0]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[0]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
hit: gamg.c:568: PCSetUp_GAMG: Assertion `pc->setupcalled' failed.
On 05/29/2013 02:29 PM, Matthew Knepley wrote:
> On Wed, May 29, 2013 at 5:25 PM, Michele Rosso <mrosso at uci.edu
> <mailto:mrosso at uci.edu>> wrote:
>     Hi,
>     I proceeded as Matt suggested. I am running without nullspace
>     (Dirichlet's BCs) with the following options:
>     -pc_type gamg  -pc_mg_cycle_type v -pc_gamg_agg_nsmooths 1
>     -mg_coarse_sub_pc_factor_shift_type NONZERO -ksp_view -options_left
>     The results are fine and the run finishes. The output of -ksp_view
>     does not say anything about the coarse solver being shifted.
>     In fact the option -mg_coarse_sub_pc_factor_shift_type NONZERO is
>     not used:
> Please show us the COMPLETE output.
>   Thanks,
>      Matt
>     #PETSc Option Table entries:
>     -ksp_view
>     -options_left
>     -pc_mg_cycle_type v
>     -pc_type gamg
>     #End of PETSc Option Table entries
>     There is one unused database option. It is:
>     Option left: name:-mg_coarse_sub_pc_factor_shift_type value: NONZERO
>     Michele
>     On 05/24/2013 03:20 PM, Matthew Knepley wrote:
>>     On Fri, May 24, 2013 at 5:18 PM, Michele Rosso <mrosso at uci.edu
>>         Using
>>         -mg_coarse_sub_pc_factor_shift_type NONZERO  -option_left
>>         -ksp_view
>>     This is what debugging is about. We are not running your problem.
>>     How could this be debugged?
>>     1) Run the problem w/o a null space so that it finishes
>>     2) Look at the output for -ksp_view
>>     3) Does the coarse solver say that it is shifted?
>>     4) Are there options which were unused?
>>        Matt
>>         still produces the same error:
>>         [0]PCSetData_AGG bs=1 MM=131072
>>         [0]PETSC ERROR: Detected zero pivot in LU factorization:
>>         see
>>         http://www.mcs.anl.gov/petsc/documentation/faq.html#ZeroPivot!
>>         [0]PETSC ERROR: Zero pivot row 280 value 6.56964e-17
>>         tolerance 2.22045e-14!
>>         [0]PETSC ERROR:
>>         29 11:26:24 CDT 2012
>>         shooting.
>>         [0]PETSC ERROR:
>>         [0]PETSC ERROR: ./hit on a  named nid15363 by Unknown Fri May
>>         24 17:06:50 2013
>>         [0]PETSC ERROR:
>>         [0]PETSC ERROR: MatPivotCheck_none() line 583 in
>>         src/mat/impls/aij/seq//ptmp/skelly/petsc/3.3.03/cray_interlagos_build/real/src/include/petsc-private/matimpl.h
>>         [0]PETSC ERROR: MatPivotCheck() line 602 in
>>         [0]PETSC ERROR: MatLUFactorNumeric_SeqAIJ() line 585 in
>>         src/mat/impls/aij/seq/aijfact.c
>>         [0]PETSC ERROR: MatLUFactorNumeric() line 2803 in
>>         [0]PETSC ERROR: PCSetUp_LU() line 160 in
>>         src/ksp/pc/impls/factor/lu/lu.c
>>         [0]PETSC ERROR: PCSetUpOnBlocks_BJacobi_Singleblock() line
>>         715 in src/ksp/pc/impls/bjacobi/bjacobi.c
>>         [0]PETSC ERROR: PCSetUpOnBlocks() line 865 in
>>         [0]PETSC ERROR: KSPSetUpOnBlocks() line 154 in
>>         [0]PETSC ERROR: KSPSolve() line 403 in
>>         [0]PETSC ERROR: PCMGMCycle_Private() line 20 in
>>         src/ksp/pc/impls/mg/mg.c
>>         [0]PETSC ERROR: PCMGMCycle_Private() line 49 in
>>         [0]PETSC ERROR: PCApply_MG() line 326 in src/ksp/pc/impls/mg/mg.c
>>         [0]PETSC ERROR: PCApply() line 384 in
>>         [0]PETSC ERROR: KSPSolve_CG() line 139 in
>>         src/ksp/ksp/impls/cg/cg.c
>>         [0]PETSC ERROR: KSPSolve() line 446 in
>>         On 05/24/2013 02:51 PM, Jed Brown wrote:
>>>         Michele Rosso<mrosso at uci.edu>  <mailto:mrosso at uci.edu>  writes:
>>>>>              With petsc-3.4 (which you should upgrade to), use
>>>         Actually, use this with petsc-3.3 also (and please upgrade to
>>>         petsc-3.4).
>>>         The option you were passing was not being used.
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     which their experiments lead.
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130529/18c25662/attachment-0001.html>
[0]PCSetData_AGG bs=1 MM=16384
KSP Object: 2 MPI processes
  type: cg
  maximum iterations=10000
  tolerances:  relative=1e-14, absolute=1e-50, divergence=10000
  left preconditioning
  using nonzero initial guess
  using PRECONDITIONED norm type for convergence test
PC Object: 2 MPI processes
  type: gamg
    MG: type is MULTIPLICATIVE, levels=3 cycles=v
      Cycles per PCApply=1
      Using Galerkin computed coarse grid matrices
  Coarse grid solver -- level -------------------------------
    KSP Object:    (mg_coarse_)     2 MPI processes
      type: gmres
        GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
        GMRES: happy breakdown tolerance 1e-30
      maximum iterations=1, initial guess is zero
      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
      using NONE norm type for convergence test
    PC Object:    (mg_coarse_)     2 MPI processes
      type: bjacobi
        block Jacobi: number of blocks = 2
        Local solve info for each block is in the following KSP and PC objects:
      [0] number of local blocks = 1, first local block number = 0
              [0] local block number 0
    KSP Object:            KSP Object:    (mg_coarse_sub_)            (mg_coarse_sub_)     1 MPI processes
             1 MPI processes
      type: preonly
              type: preonly
      maximum iterations=10000, initial guess is zero
                PC Object:PC Object:                (mg_coarse_sub_)(mg_coarse_sub_)                 1 MPI processes
 1 MPI processes
                  type: lu
  type: lu
                      LU: out-of-place factorization
                      tolerance for zero pivot 2.22045e-14
                      matrix ordering: nd
  matrix ordering: nd
                      factor fill ratio given 5, needed 1.07862
  factor fill ratio given 5, needed 0
                        Factored matrix follows:
                                Matrix Object:Matrix Object:                                 1 MPI processes
 1 MPI processes
                                  type: seqaij
  type: seqaij
                                    rows=61, cols=61
rows=0, cols=0
                                    package used to perform factorization: petsc
                                    total: nonzeros=3677, allocated nonzeros=3677
total: nonzeros=1, allocated nonzeros=1
                                    total number of mallocs used during MatSetValues calls =0
                                        not using I-node routines
                  linear system matrix = precond matrix:
 1 MPI processes
                      type: seqaij
  type: seqaij
                        rows=61, cols=61
rows=0, cols=0
                        total: nonzeros=3409, allocated nonzeros=3409
total: nonzeros=0, allocated nonzeros=0
      [1] number of local blocks = 1, first local block number = 1
        [1] local block number 0
      Matrix Object:       2 MPI processes
        type: mpiaij
        rows=61, cols=61
          not using I-node (on process 0) routines
  Down solver (pre-smoother) on level 1 -------------------------------
    KSP Object:    (mg_levels_1_)     2 MPI processes
      type: chebyshev
        Chebyshev: eigenvalue estimates:  min = 0.0266892, max = 1.42507
      maximum iterations=2
    PC Object:    (mg_levels_1_)     2 MPI processes
      type: jacobi
        type: mpiaij
        rows=3102, cols=3102
        total: nonzeros=108330, allocated nonzeros=108330
  Up solver (post-smoother) same as down solver (pre-smoother)
  Down solver (pre-smoother) on level 2 -------------------------------
    KSP Object:    (mg_levels_2_)     2 MPI processes
      type: chebyshev
        Chebyshev: eigenvalue estimates:  min = 0.182939, max = 2.0291
    PC Object:    (mg_levels_2_)     2 MPI processes
      type: jacobi
        type: mpiaij
        rows=32768, cols=32768
        total: nonzeros=229376, allocated nonzeros=229376
    type: mpiaij
-ksp_view
-options_left
-pc_mg_cycle_type v
-pc_type gamg
