[petsc-users] The multiplication of large matrices
Joon hee Choi
choi240 at purdue.edu
Wed May 29 05:43:37 CDT 2013
Hello all,
I am trying to compute the multiplication of large matrices using petsc. First,
I=2.6*10^7, J=4.8*10^7.
The matrix X is as follows: size of I*(I*J), block size of I, and non-zeros of 1.4*10^8.
-> X=[X1 X2 ...]
The matrix B is as follows: size of I*1, and dense.
The matrix M is as follows: size of I*J. M is the multiplication of each block of the matrix X and the matrix B.
-> M=[X1*B X2*B ...]
I have to get the matrix M, given X and B. I successfully set up very large aij matrix X. However, I don't know what I have to do next. I tried two ways, but I failed.
First, I tried to get each block X1, X2,... using ISCreate and MatGetLocalSubMatrix, compute X1*B, X2*B,... using MatMatMult, and then set up the matrix M using ISLocalToGlobalMappingCreate and MatSetLocalToGlobalMapping. However, I got "No support for this operation for this object type" error. Also, this code was very slow because of 48 million loops.
Second, I tried to set up the new matrix BB from B. The matrix BB has the size of (I*J)*J and the block size of I*1. And every diagonal block of BB is B and all other blocks are 0 matrices. That is,
| B 0 0 .. 0 |
BB = | 0 B 0 .. 0 |
| 0 0 0 .. B |
This is not a block diagonal matrix because B is not square. Anyway, if I set up BB, I can get M easily because M=X*BB. However, I got "out of memory" error from MatCreateSeqAIJ. I think this is because BB has non-zeros of I*J=10^15.
I never have any other ideas. If someone can fix my wrong ways correctly or has new ideas, then please please let me know. Thank you very much.
Joon
