[petsc-users] How to measure the memory usage of the application built on the Petsc?
Fande Kong
fande.kong at colorado.edu
Tue May 28 07:42:54 CDT 2013
Hi Matthew,
I added the function PetscMallocDump() into the code after calling
KSPSolve():
(6) after calling KSPSolve()
ierr = PetscMallocGetCurrentUsage(&space);CHKERRQ(ierr);
ierr = PetscPrintf(comm,"Current space PetscMalloc()ed %G M\n",
space/(1024*1024));CHKERRQ(ierr);
ierr = PetscMallocGetMaximumUsage(&space);CHKERRQ(ierr);
ierr = PetscPrintf(comm,"Max space PetscMalloced() %G M\n",
ierr = PetscMemoryGetCurrentUsage(&space);CHKERRQ(ierr);
ierr = PetscPrintf(comm,"Current process memory %G M\n",
ierr = PetscMemoryGetMaximumUsage(&space);CHKERRQ(ierr);
ierr = PetscPrintf(comm,"Max process memory %G M\n",
ierr = PetscMallocDump(PETSC_NULL);CHKERRQ(ierr);
Current space PetscMalloc()ed 290.952 M
Max space PetscMalloced() 593.367 M
Current process memory 306.852 M
Max process memory 301.441 M
The printed detailed petscmalloc information is attached. The output seems
too many lines to understand. How to understand this information?
On Tue, May 28, 2013 at 6:05 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, May 28, 2013 at 5:54 AM, Fande Kong <Fande.Kong at colorado.edu>wrote:
>> Hi Smith,
>> Thank you very much. According to your suggestions and information, I
>> added these functions into my code to measure the memory usage. Now I am
>> confused, since the small problem needs large memory.
>> I added the function PetscMemorySetGetMaximumUsage() immediately after
>> PetscInitialize(). And then I added the following code into several
>> positions in the code (before & after setting up unstructured mesh, before
>> & after KSPSetUp(), before & after KSPSolve(), and Destroy all stuffs):
>> PetscLogDouble space =0;
>> In order to measure the memory usage, I just used only one core (mpirun
>> -n 1 ./program ) to solve a small problem with 12691 mesh nodes (the
>> freedom is about 12691*3= 4 *10^4 ). I solve the linear elasticity problem
>> by using FGMRES preconditioned by multigrid method (PCMG). I use all petsc
>> standard routines except that I construct coarse matrix and interpolation
>> matrix by myself. I used the following run script to set up solver and
>> preconditioner:
>> mpirun -n 1 ./linearElasticity -ksp_type fgmres -pc_type mg
>> -pc_mg_levels 2 -pc_mg_cycle_type v -pc_mg_type multiplicative
>> -mg_levels_1_ksp_type richardson -mg_levels_1_ksp_max_it 1
>> -mg_levels_1_pc_type asm -mg_levels_1_sub_ksp_type preonly
>> -mg_levels_1_sub_pc_type ilu -mg_levels_1_sub_pc_factor_levels 4
>> -mg_levels_1_sub_pc_factor_mat_ordering_type rcm -mg_coarse_ksp_type cg
>> -mg_coarse_ksp_rtol 0.1 -mg_coarse_ksp_max_it 10 -mg_coarse_pc_type asm
>> -mg_coarse_sub_ksp_type preonly -mg_coarse_sub_pc_type ilu
>> -mg_coarse_sub_pc_factor_levels 2
>> -mg_coarse_sub_pc_factor_mat_ordering_type rcm -ksp_view -log_summary
>> -pc_mg_log
>> I got the following results:
>> (1) before setting up mesh,
>> Current space PetscMalloc()ed 0.075882 M
>> Max space PetscMalloced() 0.119675 M
>> Current process memory 7.83203 M
>> Max process memory 0 M
>> (2) after setting up mesh,
>> Current space PetscMalloc()ed 16.8411 M
>> Max space PetscMalloced() 22.1353 M
>> Current process memory 28.4336 M
>> Max process memory 33.0547 M
>> (3) before calling KSPSetUp()
>> Current space PetscMalloc()ed 16.868 M
>> Current process memory 28.6914 M
>> (4) after calling KSPSetUp()
>> Current space PetscMalloc()ed 74.3354 M
>> Max space PetscMalloced() 74.3355 M
> This makes sense. It is 20M for your mesh, 20M
> for the Krylov space on the fine level, and I am guessing
> 35M for the Jacobian and the ILU factors.
>> Current process memory 85.6953 M
>> Max process memory 84.9258 M
>> (5) before calling KSPSolve()
>> Current process memory 85.8711 M
> The question is what was malloc'd here. There is no way we could
> tell without seeing the code and probably running it. I suggest
> using
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscMallocDump.html
> to see what was allocated. The solvers tend not to allocated during
> the solve, as that is slow. So I would be inclined to check user code
> first.
> Matt
>> (7) After destroying all stuffs
>> Current space PetscMalloc()ed 0.331482 M
>> Current process memory 67.2539 M
>> Max process memory 309.137 M
>> So my question is why/if I need so much memory (306.852 M) for so small
>> problem (freedom: 4*10^4). Or is it normal case? Or my run script used to
>> set up solver is not reasonable?
>> Regards,
>> Fande Kong,
>> Department of Computer Science
>> University of Colorado Boulder
>> On Mon, May 27, 2013 at 9:48 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> There are several ways to monitor the memory usage. You can divide
>>> them into two categories: those that monitor how much memory has been
>>> malloced specifically by PETSc and how much is used totally be the process.
>>> PetscMallocGetCurrentUsage() and PetscMallocGetMaximumUsage() which only
>>> work with the command line option -malloc provide how much PETSc has
>>> malloced.
>>> PetscMemoryGetCurrentUsage() and PetscMemoryGetMaximumUsage() (call
>>> PetscMemorySetGetMaximumUsage() immediately after PetscInitialize() for
>>> this one to work) provide total memory usage.
>>> These are called on each process so use a MPI_Reduce() to gather the
>>> total memory across all processes to process 0 to print it out. Suggest
>>> calling it after the mesh as been set up, then call again immediately
>>> before the XXXSolve() is called and then after the XXXSolve() is called.
>>> Please let us know if you have any difficulties.
>>> As always we recommend you upgrade to PETSc 3.4
>>> Barry
>>> On May 27, 2013, at 10:22 PM, Fande Kong <fande.kong at colorado.edu>
>>> wrote:
>>> > Hi all,
>>> I am now solving linear elasticity equations with fgmres preconditioned by
>>> two-level method, that is, preconditioned by multigrid method where on each
>>> level the additive Schwarz method is adopted. More than 1000 cores are
>>> adopted to solve this problem on the supercomputer. When the total freedom
>>> of the problem is about 60M, the application correctly run and produce
>>> correct results. But when the total freedom increases to 600M, the
>>> application abort and say there is not enough memory ( the system
>>> administrator of the supercomputer told me that my application run out
>>> memory).
>>> > Thus, I want to monitor the memory usage dynamically when the
>>> application running. Are there any functions or strategies that could be
>>> used for this purpose?
>>> > The error information is attached.
>>> > Regards,
>>> > Fande Kong
>>> > University of Colorado at Boulder
>>> > <solid3dcube2.o1603352><configure and make log.zip>
> experiments lead.
> -- Norbert Wiener
Fande Kong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130528/6bdcd69d/attachment-0001.html>
Type: application/zip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130528/6bdcd69d/attachment-0001.zip>
