[petsc-users] How to measure the memory usage of the application built on the Petsc?
Fande Kong
Fande.Kong at Colorado.EDU
Tue May 28 04:54:07 CDT 2013
Hi Smith,
Thank you very much. According to your suggestions and information, I added
these functions into my code to measure the memory usage. Now I am
confused, since the small problem needs large memory.
I added the function PetscMemorySetGetMaximumUsage() immediately after
PetscInitialize(). And then I added the following code into several
positions in the code (before & after setting up unstructured mesh, before
& after KSPSetUp(), before & after KSPSolve(), and Destroy all stuffs):
PetscLogDouble space =0;
ierr = PetscMallocGetCurrentUsage(&space);CHKERRQ(ierr);
ierr = PetscPrintf(comm,"Current space PetscMalloc()ed %G M\n",
space/(1024*1024));CHKERRQ(ierr);
ierr = PetscMallocGetMaximumUsage(&space);CHKERRQ(ierr);
ierr = PetscPrintf(comm,"Max space PetscMalloced() %G M\n",
ierr = PetscMemoryGetCurrentUsage(&space);CHKERRQ(ierr);
ierr = PetscPrintf(comm,"Current process memory %G M\n",
ierr = PetscMemoryGetMaximumUsage(&space);CHKERRQ(ierr);
ierr = PetscPrintf(comm,"Max process memory %G M\n",
In order to measure the memory usage, I just used only one core (mpirun -n
1 ./program ) to solve a small problem with 12691 mesh nodes (the freedom
is about 12691*3= 4 *10^4 ). I solve the linear elasticity problem by using
FGMRES preconditioned by multigrid method (PCMG). I use all petsc standard
routines except that I construct coarse matrix and interpolation matrix by
myself. I used the following run script to set up solver and preconditioner:
mpirun -n 1 ./linearElasticity -ksp_type fgmres -pc_type mg -pc_mg_levels
2 -pc_mg_cycle_type v -pc_mg_type multiplicative -mg_levels_1_ksp_type
richardson -mg_levels_1_ksp_max_it 1 -mg_levels_1_pc_type asm
-mg_levels_1_sub_ksp_type preonly -mg_levels_1_sub_pc_type ilu
-mg_levels_1_sub_pc_factor_levels 4
-mg_levels_1_sub_pc_factor_mat_ordering_type rcm -mg_coarse_ksp_type cg
-mg_coarse_ksp_rtol 0.1 -mg_coarse_ksp_max_it 10 -mg_coarse_pc_type asm
-mg_coarse_sub_ksp_type preonly -mg_coarse_sub_pc_type ilu
-mg_coarse_sub_pc_factor_levels 2
-mg_coarse_sub_pc_factor_mat_ordering_type rcm -ksp_view -log_summary
-pc_mg_log
I got the following results:
(1) before setting up mesh,
Current space PetscMalloc()ed 0.075882 M
Max space PetscMalloced() 0.119675 M
Current process memory 7.83203 M
Max process memory 0 M
(2) after setting up mesh,
Current space PetscMalloc()ed 16.8411 M
Max space PetscMalloced() 22.1353 M
Current process memory 28.4336 M
Max process memory 33.0547 M
(3) before calling KSPSetUp()
Current space PetscMalloc()ed 16.868 M
Current process memory 28.6914 M
(4) after calling KSPSetUp()
Current space PetscMalloc()ed 74.3354 M
Max space PetscMalloced() 74.3355 M
Current process memory 85.6953 M
Max process memory 84.9258 M
(5) before calling KSPSolve()
Current process memory 85.8711 M
(6) after calling KSPSolve()
Current space PetscMalloc()ed 290.952 M
Max space PetscMalloced() 593.367 M
Current process memory 306.852 M
Max process memory 301.441 M
(7) After destroying all stuffs
Current space PetscMalloc()ed 0.331482 M
Current process memory 67.2539 M
Max process memory 309.137 M
So my question is why/if I need so much memory (306.852 M) for so small
problem (freedom: 4*10^4). Or is it normal case? Or my run script used to
set up solver is not reasonable?
Fande Kong,
Department of Computer Science
University of Colorado Boulder
On Mon, May 27, 2013 at 9:48 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> There are several ways to monitor the memory usage. You can divide them
> into two categories: those that monitor how much memory has been malloced
> specifically by PETSc and how much is used totally be the process.
> PetscMallocGetCurrentUsage() and PetscMallocGetMaximumUsage() which only
> work with the command line option -malloc provide how much PETSc has
> malloced.
> PetscMemoryGetCurrentUsage() and PetscMemoryGetMaximumUsage() (call
> PetscMemorySetGetMaximumUsage() immediately after PetscInitialize() for
> this one to work) provide total memory usage.
> These are called on each process so use a MPI_Reduce() to gather the total
> memory across all processes to process 0 to print it out. Suggest calling
> it after the mesh as been set up, then call again immediately before the
> XXXSolve() is called and then after the XXXSolve() is called.
> Please let us know if you have any difficulties.
> As always we recommend you upgrade to PETSc 3.4
> Barry
> On May 27, 2013, at 10:22 PM, Fande Kong <fande.kong at colorado.edu> wrote:
> > Hi all,
> I am now solving linear elasticity equations with fgmres preconditioned by
> two-level method, that is, preconditioned by multigrid method where on each
> level the additive Schwarz method is adopted. More than 1000 cores are
> adopted to solve this problem on the supercomputer. When the total freedom
> of the problem is about 60M, the application correctly run and produce
> correct results. But when the total freedom increases to 600M, the
> application abort and say there is not enough memory ( the system
> administrator of the supercomputer told me that my application run out
> memory).
> > Thus, I want to monitor the memory usage dynamically when the
> application running. Are there any functions or strategies that could be
> used for this purpose?
> > The error information is attached.
> > Regards,
> > Fande Kong
> > University of Colorado at Boulder
> > <solid3dcube2.o1603352><configure and make log.zip>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130528/95f94d78/attachment.html>
