[petsc-users] Errors from large matrices
Matthew Knepley
knepley at gmail.com
Sun May 26 13:27:01 CDT 2013
On Sun, May 26, 2013 at 2:10 PM, Choi240 <choi240 at purdue.edu> wrote:
> Thank you for your fast reply. However, I was already using 64 bit pointer.
Then it sounds like you ar really out of memory. Also, make sure you are
checking all error codes
with CHKERRQ so you do not get follow-on errors.
Matt
> -------- Original message --------
> Subject: Re: [petsc-users] Errors from large matrices
> From: Barry Smith <bsmith at mcs.anl.gov>
> To: Joon hee Choi <choi240 at purdue.edu>
> CC: petsc-users at mcs.anl.gov
> On May 26, 2013, at 6:19 AM, Joon hee Choi <choi240 at purdue.edu> wrote:
> > Hello all,
> > I need to multiply a large seqaij matrix(X1) and a maij(or baij)
> matrix(CC). I set up X1 (size:4273949x108965941330383, nonzeros:143599552)
> and C (size:25495389x10, nonzeros:254953890) and created a maij matrix CC
> from C. However, I got errors such as out of memory and Caught signal
> number 11 SEGV: Segmentation Violation, probably memory access out of
> range. Is this memory problem, and do I have to change seqaij into mpiaij
> and use multi processors? Or do I have another methods fixing it? If you
> know the method, then please let me know it. Thank you.
> http://www.mcs.anl.gov/petsc/documentation/faq.html#with-64-bit-indices
> > Joon
> > Code:
> > ierr = MatCreate(PETSC_COMM_SELF, &X1); CHKERRQ(ierr);
> > ierr = MatSetSizes(X1, PETSC_DECIDE, PETSC_DECIDE, I, J*K);
> CHKERRQ(ierr);
> > ierr = MatSetBlockSizes(X1, I, J); CHKERRQ(ierr);
> > ierr = MatSetType(X1, MATSEQAIJ); CHKERRQ(ierr);
> > ierr = MatSeqAIJSetPreallocation(X1, 0, nnz); CHKERRQ(ierr);
> > for (int x=0; x<tups.size(); x++) {
> > i = std::tr1::get<0>(tups[x]);
> > j = std::tr1::get<2>(tups[x]) + std::tr1::get<1>(tups[x])*J;
> > val = std::tr1::get<3>(tups[x]);
> > ierr = MatSetValues(X1, 1, &i, 1, &j, &val, INSERT_VALUES);
> CHKERRQ(ierr);
> > ierr = MatAssemblyBegin(X1, MAT_FINAL_ASSEMBLY);
> > ierr = MatAssemblyEnd(X1, MAT_FINAL_ASSEMBLY);
> > ierr = PetscGetTime(&v1); CHKERRQ(ierr);
> > ierr = PetscPrintf(PETSC_COMM_WORLD, "Setup Time: %2.1e \n", v1-v);
> CHKERRQ(ierr);
> > // Create a matrix C (K x R) with all values 1
> > ierr = MatCreateSeqAIJ(PETSC_COMM_SELF, K, R, R, NULL, &C);
> CHKERRQ(ierr);
> > for (k=0; k<K; k++) {
> > for (r=0; r<R; r++) {
> > ierr = MatSetValues(C, 1, &k, 1, &r, &one, INSERT_VALUES);
> CHKERRQ(ierr);
> > ierr = MatAssemblyBegin(C, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
> > ierr = MatAssemblyEnd(C, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
> > ierr = M...
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130526/9a368636/attachment.html>
