[petsc-users] Petsc configuration failure in windows 7 x64
Agnostic Noname u1028451 at gmail.com
Sun May 26 04:37:22 CDT 2013
Dear Matt and Satish,
thank you for the immediate reply. I tried looking around for any updates
to VS2012 but I didn't find any. However, adding
 #include <petscerror.h>
to src\mat\impls\baij\seq\baijfact2.c did the trick. Although the make test
failed, the petsc libs generated were libf2cblas.lib, libf2clapack.lib
and libpetsc.lib so I think it should be ok.
Hopefully I will manage to link them to my application.
I know it's an ugly hack but most of my colleagues that will try to compile
petsc will be using VS2012. I don't know the reason for this error, since
in mac and linux petsc works like a charm.
Thanks again for your help. It's greatly appreciated.
On Sun, May 26, 2013 at 5:33 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Sat, 25 May 2013, Matthew Knepley wrote:
> > On Sat, May 25, 2013 at 6:27 AM, Agnostic Noname <u1028451 at gmail.com>
> wrote:
> > 1) Please send messages with logs to petsc-maint at mcs.anl.gov so everyone
> > does not get huge attachments
> Its now acceptable to send build logs to petsc-users. petsc-users is
> now support with public archives - and petsc-maint is as usualy
> private communiation.
> We should be doing automatic compression of attachments [which we
> haven't figured out]. Currently the limit is set at 5MB - so if the
> e-mail comes through - then its acceptable. Alternative is to compress
> and send logs [or we generate logs in a compressed-ready-to-send
> tarball]
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130526/fa9d4bf1/attachment.html>
