[petsc-users] Solving Poisson equation with multigrid
Michele Rosso
mrosso at uci.edu
Fri May 24 16:46:39 CDT 2013
In both cases I used -ksp_view and -option_left.
For case 1 ( -pc_type gamg -pc_mg_cycle_type v -pc_gamg_agg_nsmooths 1
-mg_coarse_sub_pc_factor_shift_nonzero ) I posted the only output I had.
For case 2 ( -pc_type gamg -pc_mg_cycle_type v -pc_gamg_agg_nsmooths 1
-mg_coarse_pc_type svd) the output was too long to fit into an e-mail.
Please find it attached.
Michele
On 05/24/2013 02:37 PM, Matthew Knepley wrote:
> On Fri, May 24, 2013 at 4:35 PM, Michele Rosso <mrosso at uci.edu
> <mailto:mrosso at uci.edu>> wrote:
> I tried
> but I still get
> [0]PETSC ERROR: Detected zero pivot in LU factorization:
> see http://www.mcs.anl.gov/petsc/documentation/faq.html#ZeroPivot!
> [0]PETSC ERROR: Zero pivot row 280 value 6.58999e-17 tolerance
> 2.22045e-14!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29
> 11:26:24 CDT 2012
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: ./hit on a named nid21818 by Unknown Fri May 24
> 16:08:33 2013
> [0]PETSC ERROR: Libraries linked from
> [0]PETSC ERROR: Configure run at
> [0]PETSC ERROR: Configure options
> [0]PETSC ERROR:
> [0]PETSC ERROR: MatPivotCheck_none() line 583 in
> src/mat/impls/aij/seq//ptmp/skelly/petsc/3.3.03/cray_interlagos_build/real/src/include/petsc-private/matimpl.h
> [0]PETSC ERROR: MatPivotCheck() line 602 in
> [0]PETSC ERROR: MatLUFactorNumeric_SeqAIJ() line 585 in
> src/mat/impls/aij/seq/aijfact.c
> [0]PETSC ERROR: MatLUFactorNumeric() line 2803 in
> src/mat/interface/matrix.c
> [0]PETSC ERROR: PCSetUp_LU() line 160 in
> src/ksp/pc/impls/factor/lu/lu.c
> [0]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: PCSetUpOnBlocks_BJacobi_Singleblock() line 715 in
> src/ksp/pc/impls/bjacobi/bjacobi.c
> [0]PETSC ERROR: PCSetUpOnBlocks() line 865 in
> [0]PETSC ERROR: KSPSetUpOnBlocks() line 154 in
> [0]PETSC ERROR: KSPSolve() line 403 in src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: PCMGMCycle_Private() line 20 in
> src/ksp/pc/impls/mg/mg.c
> [0]PETSC ERROR: PCMGMCycle_Private() line 49 in
> [0]PETSC ERROR: PCApply_MG() line 326 in src/ksp/pc/impls/mg/mg.c
> [0]PETSC ERROR: PCApply() line 384 in src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: KSPSolve_CG() line 139 in src/ksp/ksp/impls/cg/cg.c
> [0]PETSC ERROR: KSPSolve() line 446 in src/ksp/ksp/interface/itfunc.c
> If instead I use
> as Matthew suggested, I am told that there is an invalid argument.
> 1) When you send these in, we need to see -ksp_view, so we know what
> is begin used
> 2) This is not enough information above. I use this all the time, or I
> would not have suggested it
> Matt
> Michele
> On 05/24/2013 01:04 PM, Matthew Knepley wrote:
>> On Fri, May 24, 2013 at 2:55 PM, Jed Brown <jedbrown at mcs.anl.gov
>> <mailto:jedbrown at mcs.anl.gov>> wrote:
>> Michele Rosso <mrosso at uci.edu <mailto:mrosso at uci.edu>> writes:
>> > Hi Jed,
>> > I followed your suggestion by using:
>> > This works perfectly if I have a non-singular matrix. When
>> instead I use
>> > periodic conditions for my system ( I set the nullspace
>> removal
>> > correctly ),
>> > I receive an error saying a zero pivot is detected in the LU
>> > factorization. So, after some research, I found in the
>> mailinglist a fix :
>> > -mg_coarse_pc_factor_shift_nonzero
>> It'll need to be -mg_coarse_sub_pc_factor_shift_nonzero
>> With petsc-3.4 (which you should upgrade to), use
>> -mg_coarse_sub_pc_factor_shift_type NONZERO
>> The reason you need this "sub" prefix is that the code always
>> restricts
>> using block Jacobi (usually localized so that all the entries
>> are in one
>> block), before applying the direct coarse solver.
>> I think this is less elegant than
>> Matt
>> > Still I am receiving the following error
>> > [0]PETSC ERROR: --------------------- Error Message
>> > see
>> > [0]PETSC ERROR: Zero pivot row 280 value 6.5908e-17
>> tolerance 2.22045e-14!
>> > [0]PETSC ERROR:
>> Aug 29
>> > 11:26:24 CDT 2012
>> shooting.
>> > [0]PETSC ERROR:
>> > [0]PETSC ERROR: ./hit on a named nid09458 by Unknown Fri
>> May 24
>> > 14:40:48 2013
>> > [0]PETSC ERROR:
>> 715 in
>> > What could the reason be?
>> > Thank you,
>> > Michele
>> > On 05/17/2013 07:35 PM, Michele Rosso wrote:
>> >> Thank you very much. I will try and let you know.
>> >> Michele
>> >> On 05/17/2013 07:01 PM, Jed Brown wrote:
>> >>> Michele Rosso<mrosso at uci.edu <mailto:mrosso at uci.edu>>
>> writes:
>> >>>> I noticed that the problem appears even if I use CG with
>> the default
>> >>>> preconditioner: commenting KSPSetDM() solves the problem.
>> >>> Okay, this issue can't show up if you use SNES, but it's
>> a consequence
>> >>> of making geometric multigrid work with a pure KSP
>> interface. You can
>> >>> either use KSPSetComputeOperators() to put your assembly
>> in a function
>> >>> (which will also be called on coarse levels if you use
>> -pc_type mg
>> >>> without Galerkin coarse operators) or you can can provide
>> the Jacobian
>> >>> using KSPSetOperators() as usual, but also call
>> KSPSetDMActive() so that
>> >>> the DM is not used for computing/updating the Jacobian.
>> >>> The logic is cleaner in petsc-3.4 and I think it just
>> does the right
>> >>> thing in your case.
>> >>>> So basically without a proper grid (it seems no grid
>> with an even
>> >>>> numbers of nodes qualifies) and with my own system
>> matrix, I cannot use
>> >>>> any type of multigrid
>> >>>> pre-conditioner?
>> >>> You can use all the AMG methods without setting a DM.
>> experiments is infinitely more interesting than any results to
>> which their experiments lead.
>> -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130524/4c3b1b5c/attachment-0001.html>
options used : -pc_type gamg -pc_mg_cycle_type v -pc_gamg_agg_nsmooths 1 -mg_coarse_pc_type svd
[0]PCSetData_AGG bs=1 MM=131072
[5]PETSC ERROR: [4]PETSC ERROR: --------------------- Error Message ------------------------------------
[5]PETSC ERROR: [4]PETSC ERROR: Invalid argument!
Invalid argument!
[5]PETSC ERROR: [4]PETSC ERROR: Comm must be of size 1!
[5]PETSC ERROR: [4]PETSC ERROR: ------------------------------------------------------------------------
[12]PETSC ERROR: ------------------------------------------------------------------------
[1]PETSC ERROR: [13]PETSC ERROR: [14]PETSC ERROR: [15]PETSC ERROR: [25]PETSC ERROR: [17]PETSC ERROR: [6]PETSC ERROR: [23]PETSC ERROR: [22]PETSC ERROR: [4]PETSC ERROR: [26]PETSC ERROR: --------------------- Error Message ------------------------------------
[18]PETSC ERROR: [19]PETSC ERROR: [8]PETSC ERROR: [23]PETSC ERROR: [22]PETSC ERROR: [31]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[5]PETSC ERROR: --------------------- Error Message ------------------------------------
[3]PETSC ERROR: [25]PETSC ERROR: [30]PETSC ERROR: --------------------- Error Message ------------------------------------
[27]PETSC ERROR: [28]PETSC ERROR: [20]PETSC ERROR: --------------------- Error Message ------------------------------------
[27]PETSC ERROR: [0]PETSC ERROR: --------------------- Error Message ------------------------------------
[21]PETSC ERROR: [17]PETSC ERROR: --------------------- Error Message ------------------------------------
[1]PETSC ERROR: --------------------- Error Message ------------------------------------
[2]PETSC ERROR: [3]PETSC ERROR: --------------------- Error Message ------------------------------------
[10]PETSC ERROR: --------------------- Error Message ------------------------------------
Invalid argument!
[8]PETSC ERROR: [29]PETSC ERROR: --------------------- Error Message ------------------------------------
Invalid argument!
[9]PETSC ERROR: --------------------- Error Message ------------------------------------
Invalid argument!
[22]PETSC ERROR: [0]PETSC ERROR: --------------------- Error Message ------------------------------------
Invalid argument!
[24]PETSC ERROR: Invalid argument!
[7]PETSC ERROR: [29]PETSC ERROR: [15]PETSC ERROR: Invalid argument!
[5]PETSC ERROR: [13]PETSC ERROR: Invalid argument!
Invalid argument!
Invalid argument!
[23]PETSC ERROR: --------------------- Error Message ------------------------------------
Invalid argument!
[64]PETSC ERROR: [65]PETSC ERROR: --------------------- Error Message ------------------------------------
[64]PETSC ERROR: [65]PETSC ERROR: [78]PETSC ERROR: Invalid argument!
Invalid argument!
[64]PETSC ERROR: [79]PETSC ERROR: [89]PETSC ERROR: [65]PETSC ERROR: --------------------- Error Message ------------------------------------
[69]PETSC ERROR: [87]PETSC ERROR: [65]PETSC ERROR: [86]PETSC ERROR: [84]PETSC ERROR: [85]PETSC ERROR: [92]PETSC ERROR: [96]PETSC ERROR: [97]PETSC ERROR: [99]PETSC ERROR: --------------------- Error Message ------------------------------------
[98]PETSC ERROR: [96]PETSC ERROR: --------------------- Error Message ------------------------------------
[100]PETSC ERROR: [97]PETSC ERROR: [98]PETSC ERROR: [123]PETSC ERROR: [101]PETSC ERROR: [122]PETSC ERROR: [103]PETSC ERROR: [106]PETSC ERROR: [112]PETSC ERROR: Invalid argument!
[105]PETSC ERROR: --------------------- Error Message ------------------------------------
[108]PETSC ERROR: [118]PETSC ERROR: [104]PETSC ERROR: [111]PETSC ERROR: [97]PETSC ERROR: [127]PETSC ERROR: [124]PETSC ERROR: Invalid argument!
[109]PETSC ERROR: --------------------- Error Message ------------------------------------
[103]PETSC ERROR: [102]PETSC ERROR: [101]PETSC ERROR: --------------------- Error Message ------------------------------------
[97]PETSC ERROR: --------------------- Error Message ------------------------------------
[107]PETSC ERROR: [100]PETSC ERROR: [120]PETSC ERROR: --------------------- Error Message ------------------------------------
Invalid argument!
[102]PETSC ERROR: [97]PETSC ERROR: --------------------- Error Message ------------------------------------
Invalid argument!
[107]PETSC ERROR: [106]PETSC ERROR: -------------------[33]PETSC ERROR: [32]PETSC ERROR: --------------------- Error Message ------------------------------------
[33]PETSC ERROR: [32]PETSC ERROR: [39]PETSC ERROR: Invalid argument!
[38]PETSC ERROR: [32]PETSC ERROR: --------------------- Error Message ------------------------------------
[34]PETSC ERROR: [39]PETSC ERROR: [44]PETSC ERROR: [37]PETSC ERROR: [35]PETSC ERROR: [62]PETSC ERROR: --------------------- Error Message ------------------------------------
[35]PETSC ERROR: [61]PETSC ERROR: Invalid argument!
[60]PETSC ERROR: Invalid argument!
[57]PETSC ERROR: [34]PETSC ERROR: [35]PETSC ERROR: [46]PETSC ERROR: [58]PETSC ERROR: [53]PETSC ERROR: [38]PETSC ERROR: Invalid argument!
[50]PETSC ERROR: [52]PETSC ERROR: --------------------- Error Message ------------------------------------
[32]PETSC ERROR: [48]PETSC ERROR: [49]PETSC ERROR: [39]PETSC ERROR: [43]PETSC ERROR: [46]PETSC ERROR: Invalid argument!
[33]PETSC ERROR: [42]PETSC ERROR: [45]PETSC ERROR: --------------------- Error Message ------------------------------------
Invalid argument!
Invalid argument!
[27]PETSC ERROR: [16]PETSC ERROR: [24]PETSC ERROR: [18]PETSC ERROR: [31]PETSC ERROR: [25]PETSC ERROR: --------------------- Error Message ------------------------------------
[29]PETSC ERROR: [0]PETSC ERROR: [7]PETSC ERROR: [19]PETSC ERROR: Comm must be of size 1!
[6]PETSC ERROR: Invalid argument!
Invalid argument!
[28]PETSC ERROR: Comm must be of size 1!
[17]PETSC ERROR: Comm must be of size 1!
[4]PETSC ERROR: [27]PETSC ERROR: [12]PETSC ERROR: [29]PETSC ERROR: [22]PETSC ERROR: Invalid argument!
Invalid argument!
[19]PETSC ERROR: Invalid argument!
[23]PETSC ERROR: Invalid argument!
Invalid argument!
[7]PETSC ERROR: See docs/changes/index.html for recent updates.
[18]PETSC ERROR: Comm must be of size 1!
Invalid argument!
[8]PETSC ERROR: [28]PETSC ERROR: [31]PETSC ERROR: [24]PETSC ERROR: ------------------------------------------------------------------------
[30]PETSC ERROR: Comm must be of size 1!
[22]PETSC ERROR: [6]PETSC ERROR: Invalid argument!
[3]PETSC ERROR: [15]PETSC ERROR: --------------------- Error Message ------------------------------------
[5]PETSC ERROR: Comm must be of size 1!
[9]PETSC ERROR: Comm must be of size 1!
[11]PETSC ERROR: [31]PETSC ERROR: [30]PETSC ERROR: [14]PETSC ERROR: [19]PETSC ERROR: Comm must be of size 1!
Invalid argument!
[21]PETSC ERROR: [20]PETSC ERROR: [8]PETSC ERROR: [13]PETSC ERROR: [4]PETSC ERROR: ------------------------------------------------------------------------
Invalid argument!
[0]PETSC ERROR: Comm must be of size 1!
Invalid argument!
[2]PETSC ERROR: [28]PETSC ERROR: Comm must be of size 1!
Invalid argument!
[3]PETSC ERROR: Comm must be of size 1!
[25]PETSC ERROR: Invalid argument!
Invalid argument!
[27]PETSC ERROR: Comm must be of size 1!
[21]PETSC ERROR: [20]PETSC ERROR: [22]PETSC ERROR: [17]PETSC ERROR: Comm must be of size 1!
[18]PETSC ERROR: [0]PETSC ERROR: [16]PETSC ERROR: Comm must be of size 1!
[5]PETSC ERROR: [6]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[7]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[22]PETSC ERROR: [24]PETSC ERROR: ------------------------------------------------------------------------
[23]PETSC ERROR: [0]PETSC ERROR: [12]PETSC ERROR: ------------------------------------------------------------------------
[13]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[20]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[9]PETSC ERROR: ------------------------------------------------------------------------
[24]PETSC ERROR: [4]PETSC ERROR: Comm must be of size 1!
[14]PETSC ERROR: [21]PETSC ERROR: ------------------------------------------------------------------------
[15]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
Invalid argument!
[0]PETSC ERROR: [8]PETSC ERROR: --------------------- Error Message ------------------------------------
[22]PETSC ERROR: ------------------------------------------------------------------------
[26]PETSC ERROR: [3]PETSC ERROR: [15]PETSC ERROR: ------------------------------------------------------------------------
[27]PETSC ERROR: ------------------------------------------------------------------------
[6]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[31]PETSC ERROR: Invalid argument!
[28]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[23]PETSC ERROR: [24]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[29]PETSC ERROR: ------------------------------------------------------------------------
[19]PETSC ERROR: [17]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[9]PETSC ERROR: [15]PETSC ERROR: Comm must be of size 1!
[28]PETSC ERROR: [26]PETSC ERROR: [11]PETSC ERROR: [24]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[30]PETSC ERROR: See docs/index.html for manual pages.
[2]PETSC ERROR: See docs/changes/index.html for recent updates.
[20]PETSC ERROR: [31]PETSC ERROR: [0]PETSC ERROR: Comm must be of size 1!
[28]PETSC ERROR: ./hit on a named nid21818 by Unknown Fri May 24 16:12:20 2013
[8]PETSC ERROR: ------------------------------------------------------------------------
Invalid argument!
[10]PETSC ERROR: [18]PETSC ERROR: See docs/index.html for manual pages.
[6]PETSC ERROR: [4]PETSC ERROR: [3]PETSC ERROR: [26]PETSC ERROR: Libraries linked from
[25]PETSC ERROR: [0]PETSC ERROR: [11]PETSC ERROR: [22]PETSC ERROR: See docs/changes/index.html for recent updates.
[4]PETSC ERROR: See docs/changes/index.html for recent updates.
[29]PETSC ERROR: [12]PETSC ERROR: See docs/changes/index.html for recent updates.
[23]PETSC ERROR: See docs/changes/index.html for recent updates.
[20]PETSC ERROR: [0]PETSC ERROR: [18]PETSC ERROR: [3]PETSC ERROR: See docs/changes/index.html for recent updates.
Configure run at
[4]PETSC ERROR: [10]PETSC ERROR: [19]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[30]PETSC ERROR: [15]PETSC ERROR: ------------------------------------------------------------------------
[9]PETSC ERROR: Configure options
[17]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[27]PETSC ERROR: [19]PETSC ERROR: [31]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[11]PETSC ERROR: See docs/index.html for manual pages.
[23]PETSC ERROR: [13]PETSC ERROR: Comm must be of size 1!
[14]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[12]PETSC ERROR: ./hit on a named nid21818 by Unknown Fri May 24 16:12:20 2013
[19]PETSC ERROR: [28]PETSC ERROR: [22]PETSC ERROR: See docs/changes/index.html for recent updates.
[20]PETSC ERROR: [21]PETSC ERROR: ------------------------------------------------------------------------
[16]PETSC ERROR: [17]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[17]PETSC ERROR: [2]PETSC ERROR: See docs/changes/index.html for recent updates.
[19]PETSC ERROR: See docs/index.html for manual pages.
[17]PETSC ERROR: [18]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[21]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[20]PETSC ERROR: [4]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: [29]PETSC ERROR: [30]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[25]PETSC ERROR: [21]PETSC ERROR: ------------------------------------------------------------------------
[10]PETSC ERROR: [19]PETSC ERROR: [7]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[3]PETSC ERROR: Libraries linked from
[6]PETSC ERROR: See docs/changes/index.html for recent updates.
[16]PETSC ERROR: [13]PETSC ERROR: [17]PETSC ERROR: [4]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[15]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[2]PETSC ERROR: [19]PETSC ERROR: ------------------------------------------------------------------------
Configure run at
[23]PETSC ERROR: [26]PETSC ERROR: ------------------------------------------------------------------------
[24]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[7]PETSC ERROR: See docs/index.html for manual pages.
[27]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[8]PETSC ERROR: [24]PETSC ERROR: [31]PETSC ERROR: See docs/index.html for manual pages.
[4]PETSC ERROR: See docs/index.html for manual pages.
[12]PETSC ERROR: Libraries linked from
[18]PETSC ERROR: [19]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[119]PETSC ERROR: [122]PETSC ERROR: Invalid argument!
[113]PETSC ERROR: [114]PETSC ERROR: Invalid argument!
Invalid argument!
[109]PETSC ERROR: [98]PETSC ERROR: [110]PETSC ERROR: Invalid argument!
[104]PETSC ERROR: [108]PETSC ERROR: [103]PETSC ERROR: Invalid argument!
Invalid argument!
[99]PETSC ERROR: [116]PETSC ERROR: [111]PETSC ERROR: Comm must be of size 1!
[112]PETSC ERROR: [121]PETSC ERROR: Invalid argument!
[99]PETSC ERROR: [121]PETSC ERROR: [120]PETSC ERROR: [124]PETSC ERROR: Invalid argument!
Invalid argument!
[106]PETSC ERROR: [102]PETSC ERROR: [114]PETSC ERROR: [117]PETSC ERROR: [107]PETSC ERROR: [99]PETSC ERROR: --------------------- Error Message ------------------------------------
[116]PETSC ERROR: [123]PETSC ERROR: Comm must be of size 1!
[98]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
Invalid argument!
[102]PETSC ERROR: Invalid argument!
[100]PETSC ERROR: [122]PETSC ERROR: [127]PETSC ERROR: [115]PETSC ERROR: Invalid argument!
[126]PETSC ERROR: Comm must be of size 1!
[96]PETSC ERROR: ------------------------------------------------------------------------
[112]PETSC ERROR: ------------------------------------------------------------------------
Invalid argument!
-[71]PETSC ERROR: [72]PETSC ERROR: [73]PETSC ERROR: --------------------- Error Message ------------------------------------
[93]PETSC ERROR: --------------------- Error Message ------------------------------------
[78]PETSC ERROR: [80]PETSC ERROR: [73]PETSC ERROR: [85]PETSC ERROR: [68]PETSC ERROR: [91]PETSC ERROR: Invalid argument!
[90]PETSC ERROR: [75]PETSC ERROR: [88]PETSC ERROR: --------------------- Error Message ------------------------------------
[83]PETSC ERROR: Invalid argument!
[84]PETSC ERROR: ------------------------------------------------------------------------
[68]PETSC ERROR: --------------------- Error Message ------------------------------------
[93]PETSC ERROR: [92]PETSC ERROR: --------------------- Error Message ------------------------------------
[71]PETSC ERROR: [74]PETSC ERROR: [65]PETSC ERROR: [67]PETSC ERROR: [77]PETSC ERROR: [95]PETSC ERROR: [94]PETSC ERROR: [88]PETSC ERROR: [82]PETSC ERROR: [83]PETSC ERROR: Invalid argument!
Invalid argument!
Invalid argument!
[82]PETSC ERROR: [81]PETSC ERROR: [87]PETSC ERROR: Invalid argument!
[71]PETSC ERROR: --------------------- Error Message -----------[41]PETSC ERROR: Comm must be of size 1!
[38]PETSC ERROR: --------------------- Error Message ------------------------------------
[34]PETSC ERROR: --------------------- Error Message ------------------------------------
[47]PETSC ERROR: Comm must be of size 1!
[35]PETSC ERROR: [34]PETSC ERROR: --------------------- Error Message ------------------------------------
[36]PETSC ERROR: [42]PETSC ERROR: [44]PETSC ERROR: [54]PETSC ERROR: [40]PETSC ERROR: [58]PETSC ERROR: Comm must be of size 1!
[51]PETSC ERROR: --------------------- Error Message ------------------------------------
[37]PETSC ERROR: [39]PETSC ERROR: [48]PETSC ERROR: [60]PETSC ERROR: --------------------- Error Message ------------------------------------
[49]PETSC ERROR: [55]PETSC ERROR: Comm must be of size 1!
[46]PETSC ERROR: [39]PETSC ERROR: Invalid argument!
[43]PETSC ERROR: [36]PETSC ERROR: [37]PETSC ERROR: --------------------- Error Message ------------------------------------
[50]PETSC ERROR: [38]PETSC ERROR: ------------------------------------------------------------------------
Invalid argument!
[33]PETSC ERROR: --------------------- Error Message ------------------------------------
[63]PETSC ERROR: --------------------- Error Message ------------------------------------
Invalid ar-------------------- Error Message ------------------------------------
[113]PETSC ERROR: Comm must be of size 1!
Invalid argument!
Invalid argument!
[97]PETSC ERROR: [106]PETSC ERROR: --------------------- Error Message ------------------------------------
[119]PETSC ERROR: [108]PETSC ERROR: Comm must be of size 1!
[98]PETSC ERROR: [101]PETSC ERROR: [107]PETSC ERROR: [100]PETSC ERROR: [105]PETSC ERROR: ------------------------------------------------------------------------
[96]PETSC ERROR: [125]PETSC ERROR: ------------------------------------------------------------------------
[100]PETSC ERROR: Invalid argument!
[116]PETSC ERROR: [127]PETSC ERROR: [103]PETSC ERROR: [102]PETSC ERROR: [120]PETSC ERROR: Invalid argument!
[99]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[125]PETSC ERROR: [124]PETSC ERROR: [126]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[98]PETSC ERROR: [97]PETSC ERROR: [102]PETSC ERROR: See docs/changes/index.html for recent updates.
[118]PETSC ERROR: [119]PETSC ERROR: [112]PETSC ERROR: [122]PETSC ERROR: [98]PETSC ERROR: ------------------------------------------------------------------------
Invalid argument!
[103]PETSC ERROR: [127]PETSC ERROR: [110]PETSC ERROR: Comm must be of size 1!
Invalid argument!
[76]PETSC ERROR: --------------------- Error Message ------------------------------------
[65]PETSC ERROR: Invalid argument!
Invalid argument!
[90]PETSC ERROR: Invalid argument!
Invalid argument!
[69]PETSC ERROR: --------------------- Error Message ------------------------------------
Invalid argument!
[93]PETSC ERROR: [92]PETSC ERROR: [84]PETSC ERROR: [85]PETSC ERROR: Comm must be of size 1!
[68]PETSC ERROR: [81]PETSC ERROR: --------------------- Error Message ------------------------------------
[82]PETSC ERROR: [70]PETSC ERROR: [77]PETSC ERROR: [71]PETSC ERROR: [95]PETSC ERROR: [84]PETSC ERROR: [78]PETSC ERROR: --------------------- Error Message ------------------------------------
[80]PETSC ERROR: Comm must be of size 1!
[65]PETSC ERROR: [85]PETSC ERROR: --------------------- Error Message ------------------------------------
[86]PETSC ERROR: [70]PETSC ERROR: [68]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
Invalid argument!
[73]PETSC ERROR: [72]PETSC ERROR: Invalid argument!
[71]PETSC ERROR: ------------------------------------------------------------------------
[66]PETSC ERROR: Comm must be of size 1!
[94]PETSC ERROR: [87]PETSC ERROR: [70]PETSC ERROR: Invalid argument!
[68]PETSC ERROR: [90]PETSC ERROR: Comm must be of size 1!
[76]PETSC ERROR: [65]PETSC ERROR: Invalid argument!
--------------------- Error Message gument!
Invalid argument!
[59]PETSC ERROR: [42]PETSC ERROR: [57]PETSC ERROR: [51]PETSC ERROR: Invalid argument!
[61]PETSC ERROR: [46]PETSC ERROR: [39]PETSC ERROR: Comm must be of size 1!
[34]PETSC ERROR: [55]PETSC ERROR: ------------------------------------------------------------------------
Invalid argument!
Invalid argument!
[33]PETSC ERROR: ------------------------------------------------------------------------
Invalid argument!
Invalid argument!
[48]PETSC ERROR: [41]PETSC ERROR: [46]PETSC ERROR: [57]PETSC ERROR: [45]PETSC ERROR: [49]PETSC ERROR: Comm must be of size 1!
[56]PETSC ERROR: Comm must be of size 1!
[34]PETSC ERROR: [48]PETSC ERROR: [50]PETSC ERROR: [40]PETSC ERROR: Invalid argument!
Invalid argument!
Invalid argument!
[36]PETSC ERROR: See docs/changes/index.html for recent updates.
Invalid argument!
[52]PETSC ERROR: [58]PETSC ERROR: Invalid argument!
[33]PETSC ERROR: Comm must be of size 1!
[44]PETSC ERROR: ------------------------------------------------------------------------
[33]PETSC ERROR: [42]PETSC ERROR: Comm must be of size 1!
[53]PETSC ERROR: [34]PETSC ERROR: [37]PETSC ERROR: Invalid argument!
[63]PETSC ERROR: ------------------------------------------------------------------------
[58]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[35]PETSC ERROR: [38]PETSC ERROR: [34------------
[124]PETSC ERROR: [122]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[111]PETSC ERROR: [119]PETSC ERROR: [102]PETSC ERROR: ------------------------------------------------------------------------
[106]PETSC ERROR: Invalid argument!
Invalid argument!
Invalid argument!
[119]PETSC ERROR: [120]PETSC ERROR: Invalid argument!
[126]PETSC ERROR: [103]PETSC ERROR: [104]PETSC ERROR: [102]PETSC ERROR: See docs/changes/index.html for recent updates.
Invalid argument!
[99]PETSC ERROR: [105]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[115]PETSC ERROR: [102]PETSC ERROR: [110]PETSC ERROR: [109]PETSC ERROR: Comm must be of size 1!
[97]PETSC ERROR: [98]PETSC ERROR: Comm must be of size 1!
[103]PETSC ERROR: See docs/index.html for manual pages.
Invalid argument!
[101]PETSC ERROR: [105]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[100]PETSC ERROR: See docs/index.html for manual pages.
./hit on a named nid21861 by Unknown Fri May 24 16:12:20 2013
[97]PETSC ERROR: [120]PETSC ERROR: [118]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[115]PETSC ERROR------------------------------------
[78]PETSC ERROR: Comm must be of size 1!
[73]PETSC ERROR: [82]PETSC ERROR: [74]PETSC ERROR: ------------------------------------------------------------------------
[89]PETSC ERROR: ------------------------------------------------------------------------
[66]PETSC ERROR: Invalid argument!
Invalid argument!
Invalid argument!
[77]PETSC ERROR: [92]PETSC ERROR: [87]PETSC ERROR: [67]PETSC ERROR: Invalid argument!
[95]PETSC ERROR: ------------------------------------------------------------------------
[94]PETSC ERROR: Invalid argument!
[73]PETSC ERROR: Invalid argument!
[65]PETSC ERROR: [93]PETSC ERROR: [81]PETSC ERROR: ------------------------------------------------------------------------
Invalid argument!
[72]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
./hit on a named nid21860 by Unknown Fri May 24 16:12:20 2013
[84]PETSC ERROR: Invalid argument!
[92]PETSC ERROR: [65]PETSC ERROR: [80]PETSC ERROR: Libraries linked from
[68]PETSC ERROR: Invalid argument!
[65]PETSC ERROR: [83]PETSC ERROR: Configure run at
Invalid argument!
[93]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[65]PETSC ERROR: [71]PETSC ERROR: [74]PETSC ERROR: Comm must be of size 1!
[67]PETSC ERROR: [66]PETSC ERROR: See docs/changes/index.html for recent updates.
[71]PETSC ERROR: ]PETSC ERROR: [57]PETSC ERROR: [60]PETSC ERROR: [47]PETSC ERROR: [40]PETSC ERROR: Invalid argument!
[51]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
Invalid argument!
[39]PETSC ERROR: [35]PETSC ERROR: [59]PETSC ERROR: [43]PETSC ERROR: [33]PETSC ERROR: Invalid argument!
[52]PETSC ERROR: [41]PETSC ERROR: Comm must be of size 1!
[56]PETSC ERROR: ------------------------------------------------------------------------
[59]PETSC ERROR: Comm must be of size 1!
[51]PETSC ERROR: [33]PETSC ERROR: See docs/index.html for manual pages.
[50]PETSC ERROR: [36]PETSC ERROR: ------------------------------------------------------------------------
[45]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[62]PETSC ERROR: Invalid argument!
[54]PETSC ERROR: [43]PETSC ERROR: [38]PETSC ERROR: ------------------------------------------------------------------------
[39]PETSC ERROR: [36]PETSC ERROR: ------------------------------------------------------------------------
Invalid argument!
[42]PETSC ERROR: [61]PETSC ERROR: [33]PETSC ERROR: [60]PETSC ERROR: [62]PETSC ERROR: [51]PETSC ERROR: [44]PETSC ERROR: [39]PETSC ERROR: See docs/index.html for manual pages.
[46]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT: Comm must be of size 1!
[119]PETSC ERROR: [121]PETSC ERROR: [126]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[102]PETSC ERROR: [113]PETSC ERROR: Comm must be of size 1!
[122]PETSC ERROR: [120]PETSC ERROR: [116]PETSC ERROR: ------------------------------------------------------------------------
[104]PETSC ERROR: ------------------------------------------------------------------------
[118]PETSC ERROR: See docs/changes/index.html for recent updates.
[122]PETSC ERROR: [109]PETSC ERROR: [97]PETSC ERROR: [113]PETSC ERROR: [119]PETSC ERROR: [105]PETSC ERROR: [101]PETSC ERROR: ------------------------------------------------------------------------
[99]PETSC ERROR: [111]PETSC ERROR: [97]PETSC ERROR: ------------------------------------------------------------------------
[104]PETSC ERROR: [100]PETSC ERROR: [68]PETSC ERROR: [91]PETSC ERROR: Comm must be of size 1!
[76]PETSC ERROR: [70]PETSC ERROR: Comm must be of size 1!
[86]PETSC ERROR: Comm must be of size 1!
[76]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[69]PETSC ERROR: [92]PETSC ERROR: Comm must be of size 1!
[88]PETSC ERROR: Configure options
[90]PETSC ERROR: ------------------------------------------------------------------------
[89]PETSC ERROR: Comm must be of size 1!
[69]PETSC ERROR: [66]PETSC ERROR: ------------------------------------------------------------------------
[82]PETSC ERROR: ------------------------------------------------------------------------
[67]PETSC ERROR: ------------------------------------------------------------------------
[65]PETSC ERROR: [68]PETSC ERROR: ------------------------------------------------------------------------
[87]PETSC ERROR: [78]PETSC ERROR: [69]PETSC ERROR: See docs/index.html for manual pages.
[91]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[66]PETSC ERROR: [84]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[81]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[68]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[83]PETSC ERROR: Comm must be of size 1!
[72]PETSC ERROR: ------------------------------------------------------------------------
Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11: 2012
Invalid argument!
[63]PETSC ERROR: Comm must be of size 1!
[36]PETSC ERROR: [35]PETSC ERROR: [47]PETSC ERROR: ./hit on a named nid21819 by Unknown Fri May 24 16:12:20 2013
[37]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[56]PETSC ERROR: [50]PETSC ERROR: See docs/changes/index.html for recent updates.
[103]PETSC ERROR: [126]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
Configure run at
[118]PETSC ERROR: Libraries linked from
[124]PETSC ERROR: See docs/index.html for manual pages.
[102]PETSC ERROR: [106]PETSC ERROR: [97]PETSC ERROR: See docs/changes/index.html for recent updates.
Configure options
[98]PETSC ERROR: Configure run at
[108]PETSC ERROR: [105]PETSC ERROR: [97]PETSC ERROR: [126]PETSC ERROR: [124]PETSC ERROR: See docs/changes/index.html for recent updates.
Configure options
[97]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[119]PETSC ERROR: [102]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[99]PETSC ERROR: Comm must be of size 1!
[105]PETSC ERROR: [107]PETSC ERROR: [117]PETSC ERROR: [98]PETSC ERROR: ------------------------------------------------------------------------
[118]PETSC ERROR: [111]PETSC ERROR: See docs/changes/index.html for recent updates.
[125]PETSC ERROR: [122]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[123]PETSC ERROR: ------------------------------------26:24 CDT 2012
[70]PETSC ERROR: [78]PETSC ERROR: See docs/changes/index.html for recent updates.
[93]PETSC ERROR: [74]PETSC ERROR: ------------------------------------------------------------------------
[69]PETSC ERROR: [89]PETSC ERROR: ------------------------------------------------------------------------
[68]PETSC ERROR: See docs/changes/index.html for recent updates.
[92]PETSC ERROR: ------------------------------------------------------------------------
[76]PETSC ERROR: Comm must be of size 1!
[94]PETSC ERROR: [85]PETSC ERROR: [80]PETSC ERROR: [74]PETSC ERROR: [87]PETSC ERROR: [83]PETSC ERROR: [89]PETSC ERROR: [65]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[69]PETSC ERROR: [88]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[70]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[94]PETSC ERROR: [95]PETSC ERROR: [82]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[77]PETSC ERROR: [64]PETSC ERROR: [34]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
Invalid argument!
[48]PETSC ERROR: [63]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[49]PETSC ERROR: See docs/changes/index.html for recent updates.
[37]PETSC ERROR: ------------------------------------------------------------------------
[40]PETSC ERROR: Libraries linked from
[52]PETSC ERROR: [35]PETSC ERROR: [42]PETSC ERROR: ------------------------------------------------------------------------
[61]PETSC ERROR: ------------------------------------
[121]PETSC ERROR: [97]PETSC ERROR: Comm must be of size 1!
[120]PETSC ERROR: [126]PETSC ERROR: [103]PETSC ERROR: [110]PETSC ERROR: ------------------------------------------------------------------------
[111]PETSC ERROR: [100]PETSC ERROR: ------------------------------------------------------------------------
[108]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[101]PETSC ERROR: [121]PETSC ERROR: [113]PETSC ERROR: [102]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[109]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[106]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[118]PETSC ERROR: [119]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[97]PETSC ERROR: [112]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[100]PETSC ERROR: [104]PETSC ERROR: [101]PETSC ERROR: ------------------------------------------------------------------------
[113]PETSC ERROR: [108]PETSC ERROR: See docs/index.html for manual pages.
[102]PETSC ERROR: [106]PETSC ERROR: [123]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[114]PETSC[47]PETSC ERROR: [60]PETSC ERROR: ------------------------------------------------------------------------
[39]PETSC ERROR: ------------------------------------------------------------------------
[38]PETSC ERROR: [49]PETSC ERROR: ------------------------------------------------------------------------
[43]PETSC ERROR: See docs/changes/index.html for recent updates.
[63]PETSC ERROR: See docs/index.html for manual pages.
[55]PETSC ERROR: See docs/changes/index.html for recent updates.
[62]PETSC ERROR: [38]PETSC ERROR: ------------------------------------------------------------------------
[45]PETSC ERROR: [52]PETSC ERROR: [47]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[37]PETSC ERROR: [35]PETSC ERROR: [36]PETSC ERROR: ------------------------------------------------------------------------
[60]PETSC ERROR: [48]PETSC ERROR: [40]PETSC ERROR: [46]PETSC ERROR: [53]PETSC ERROR: [52]PETSC ERROR: [59]PETSC ERROR: [44]PETSC ERROR: [54]PETSC ERROR: [36]PETSC ERROR: Configure run at
[38]PETSC ERROR: Comm must be of size 1!
[34]PETSC ERROR: ------------------------------------------------------------------------
[49]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[38]PETSC ERROR: [52]PETSC ERROR: See docs/changes/index.html for recent updates.
[3]PETSC ERROR: [2]PETSC ERROR: [23]PETSC ERROR: ------------------------------------------------------------------------
[2]PETSC ERROR: [21]PETSC ERROR: [30]PETSC ERROR: [20]PETSC ERROR: [0]PETSC ERROR: [28]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[13]PETSC ERROR: [15]PETSC ERROR: [8]PETSC ERROR: ------------------------------------------------------------------------
[22]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[3]PETSC ERROR: ./hit on a named nid21818 by Unknown Fri May 24 16:12:20 2013
Configure run at
[6]PETSC ERROR: [29]PETSC ERROR: ------------------------------------------------------------------------
[29]PETSC ERROR: ./hit on a named nid21818 by Unknown Fri May 24 16:12:20 2013
Configure run at
[26]PETSC ERROR: ./hit on a named nid21818 by Unknown Fri May 24 16:12:20 2013
[21]PETSC ERROR: [22]PETSC ERROR: [23]PETSC ERROR: [18]PETSC ERROR: [11]PETSC ERROR: [4]PETSC ERROR: [31]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: ------------------------------------------------------------------------
Configure options
Configure options
Configure options
MatConvert() line 3747 in src/mat/interface/matrix.c
[22]PETSC ERROR: [19]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[2]PETSC ERROR: [0]PETSC ERROR: See docs/index.html for manual pages.
[13]PETSC ERROR: [15]PETSC ERROR: [0]PETSC ERROR: [27]PETSC ERROR: [6]PETSC ERROR: ./hit on a named nid21818 by Unknown Fri May 24 16:12:20 2013
[25]PETSC ERROR: [4]PETSC ERROR: See docs/index.html for manual pages.
[28]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[18]PETSC ERROR: [24]PETSC ERROR: ./hit on a named nid21818 by Unknown Fri May 24 16:12:20 2013
[20]PETSC ERROR: [21]PETSC ERROR: [23]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[15]PETSC ERROR: [3]PETSC ERROR: [9]PETSC ERROR: [26]PETSC ERROR: ./hit on a named nid21818 by Unknown Fri May 24 16:12:20 2013
[4]PETSC ERROR: Libraries linked from
[8]PETSC ERROR: See docs/changes/index.html for recent updates.
[9]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[11]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[7]PETSC ERROR: [17]PETSC ERROR: [29]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR: [13]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[26]PETSC ERROR: Configure run at
[10]PETSC ERROR: See docs/changes/index.html for recent updates.
[30]PETSC ERROR: ------------------------------------------------------------------------
[22]PETSC ERROR: ./hit on a named nid21818 by Unknown Fri May 24 16:12:20 2013
[16]PETSC ERROR: [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
Configure options
[4]PETSC ERROR: [16]PETSC ERROR: Configure run at
[22]PETSC ERROR: [23]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[31]PETSC ERROR: [2]PETSC ERROR: ------------------------------------------------------------------------
[4]PETSC ERROR: [0]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[25]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[8]PETSC ERROR: [21]PETSC ERROR: [0]PETSC ERROR: See docs/index.html for manual pages.
[10]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[3]PETSC ERROR: [17]PETSC ERROR: See docs/changes/index.html for recent updates.
[19]PETSC ERROR: [4]PETSC ERROR: Libraries linked from
Configure options
[2]PETSC ERROR: Configure run at
[9]PETSC ERROR: [28]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[26]PETSC ERROR: [12]PETSC ERROR: [21]PETSC ERROR: [23]PETSC ERROR: [0]PETSC ERROR: Configure run at
[21]PETSC ERROR: [18]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[20]PETSC ERROR: [11]PETSC ERROR: See docs/index.html for manual pages.
[31]PETSC ERROR: [30]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[8]PETSC ERROR: [7]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[29]PETSC ERROR: Configure run at
[2]PETSC ERROR: Libraries linked from
[19]PETSC ERROR: Libraries linked from
[17]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[9]PETSC ERROR: Libraries linked from
[3]PETSC ERROR: [0]PETSC ERROR: ------------------------------------------------------------------------
[27]PETSC ERROR: [4]PETSC ERROR: [29]PETSC ERROR: [26]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[18]PETSC ERROR: [8]PETSC ERROR: ------------------------------------------------------------------------
Configure run at
[16]PETSC ERROR: [6]PETSC ERROR: [7]PETSC ERROR: [22]PETSC ERROR: [9]PETSC ERROR: ./hit on a named nid21818 by Unknown Fri May 24 16:12:20 2013
[18]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[26]PETSC ERROR: [20]PETSC ERROR: See docs/index.html for manual pages.
[14]PETSC ERROR: Libraries linked from
[13]PETSC ERROR: Configure options
[30]PETSC ERROR: Configure run at
[20]PETSC ERROR: Libraries linked from
[23]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
Configure options
Configure run at
[16]PETSC ERROR: [25]PETSC ERROR: [6]PETSC ERROR: [26]PETSC ERROR: [14]PETSC ERROR: Configure options
[8]PETSC ERROR: Configure run at
Configure run at
Configure run at
[13]PETSC ERROR: See docs/changes/index.html for recent updates.
Configure run at
[22]PETSC ERROR: [11]PETSC ERROR: [9]PETSC ERROR: [15]PETSC ERROR: Configure options
[10]PETSC ERROR: [25]PETSC ERROR: [7]PETSC ERROR: [24]PETSC ERROR: [31]PETSC ERROR: [6]PETSC ERROR: Libraries linked from
[23]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[19]PETSC ERROR: [22]PETSC ERROR: Configure options
[16]PETSC ERROR: Configure options
Configure options
Configure options
[18]PETSC ERROR: [8]PETSC ERROR: [20]PETSC ERROR: [22]PETSC ERROR: See docs/index.html for manual pages.
[6]PETSC ERROR: [28]PETSC ERROR: [7]PETSC ERROR: [29]PETSC ERROR: Configure run at
[11]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[9]PETSC ERROR: [17]PETSC ERROR: [24]PETSC ERROR: Libraries linked from
[23]PETSC ERROR: Configure options
[3]PETSC ERROR: [28]PETSC ERROR: [25]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[30]PETSC ERROR: [12]PETSC ERROR: ------------------------------------------------------------------------
[58]PETSC ERROR: [50]PETSC ERROR: [46]PETSC ERROR: ./hit on a named nid21819 by Unknown Fri May 24 16:12:20 2013
[48]PETSC ERROR: See docs/changes/index.html for recent updates.
[60]PETSC ERROR: See docs/changes/index.html for recent updates.
[51]PETSC ERROR: See docs/index.html for manual pages.
[54]PETSC ERROR: ------------------------------------------------------------------------
[50]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[57]PETSC ERROR: [61]PETSC ERROR: [56]PETSC ERROR: Libraries linked from
[53]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[49]PETSC ERROR: [60]PETSC ERROR: [42]PETSC ERROR: ------------------------------------------------------------------------
[34]PETSC ERROR: [35]PETSC ERROR: [52]PETSC ERROR: Libraries linked from
[38]PETSC ERROR: See docs/index.html for manual pages.
[43]PETSC ERROR: [35]PETSC ERROR: Configure run at
[53]PETSC ERROR: See docs/changes/index.html for recent updates.
[46]PETSC ERROR: [37]PETSC ERROR: ------------------------------------------------------------------------
[44]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[61]PETSC ERROR: [55]PETSC ERROR: [47]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[38]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[39]PETSC ERROR: [52]PETSC ERROR: [62]PETSC ERROR: [40]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[34]PETSC ERROR: Configure options
[51]PETSC ERROR: Configure run at
Configure options
[34]PETSC ERROR: [56]PETSC ERROR: [57]PETSC ERROR: See docs/index.html for manual pages.
Configure options
[53]PETSC ERROR: ------------------------------------------------------------------------
[52]PETSC ERROR: [62]PETSC ERROR: [63]PETSC ERROR: [60]PETSC ERROR: [34]PETSC ERROR: [45]PETSC ERROR: [59]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[38]PETSC ERROR: [42]PETSC ERROR: [43]PETSC ERROR: ------------------------------------------------------------------------
[56]PETSC ERROR: [57]PETSC ERROR: See docs/changes/index.html for recent updates.
[51]PETSC ERROR: [61]PETSC ERROR: [36]PETSC ERROR: ./hit on a named nid21819 by Unknown Fri May 24 16:12:20 2013
[63]PETSC ERROR: [62]PETSC ERROR: [34]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[50]PETSC ERROR: ------------------------------------------------------------------------
[37]PETSC ERROR: See docs/changes/index.html for recent updates.
[48]PETSC ERROR: [35]PETSC ERROR: [39]PETSC ERROR: See docs/index.html for manual pages.
Configure run at
[32]PETSC ERROR: [35]PETSC ERROR: [41]PETSC ERROR: [42]PETSC ERROR: [61]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[58]PETSC ERROR: [51]PETSC ERROR: ------------------------------------------------------------------------
[52]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[46]PETSC ERROR: [39]PETSC ERROR: [38]PETSC ERROR: ------------------------------------------------------------------------
[53]PETSC ERROR: [43]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense. ERROR: [103]PETSC ERROR: Libraries linked from
[115]PETSC ERROR: See docs/changes/index.html for recent updates.
[109]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[120]PETSC ERROR: ------------------------------------------------------------------------
[98]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[99]PETSC ERROR: See docs/index.html for manual pages.
[100]PETSC ERROR: [97]PETSC ERROR: ./hit on a named nid21861 by Unknown Fri May 24 16:12:20 2013
[124]PETSC ERROR: Comm must be of size 1!
[99]PETSC ERROR: See docs/changes/index.html for recent updates.
Configure run at
[101]PETSC ERROR: Invalid argument!
[123]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[102]PETSC ERROR: [126]PETSC ERROR: [125]PETSC ERROR: [116]PETSC ERROR: [97]PETSC ERROR: [104]PETSC ERROR: ------------------------------------------------------------------------
[122]PETSC ERROR: [123]PETSC ERROR: [115]PETSC ERROR: [126]PETSC ERROR: [101]PETSC ERROR: [106]PETSC ERROR: [107]PETSC ERROR: Libraries linked from
[110]PETSC ERROR: [98]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[104]PETSC ERROR: [114]PETSC ERROR: [119]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
MatConvec
Configure options
[59]PETSC ERROR: See docs/index.html for manual pages.
[50]PETSC ERROR: [49]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[51]PETSC ERROR: ./hit on a named nid21819 by Unknown Fri May 24 16:12:20 2013
[57]PETSC ERROR: [56]PETSC ERROR: [48]PETSC ERROR: [58]PETSC ERROR: See docs/changes/index.html for recent updates.
[44]PETSC ERROR: [37]PETSC ERROR: [61]PETSC ERROR: See docs/index.html for manual pages.
[63]PETSC ERROR: [62]PETSC ERROR: [32]PETSC ERROR: See docs/changes/index.html for recent updates.
[38]PETSC ERROR: Libraries linked from
[46]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[50]PETSC ERROR: [35]PETSC ERROR: [34]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[40]PETSC ERROR: See docs/changes/index.html for recent updates.
[56]PETSC ERROR: [47]PETSC ERROR: Libraries linked from
[32]PETSC ERROR: ------------------------------------------------------------------------
./hit on a named nid21819 by Unknown Fri Mart() line 3747 in src/mat/interface/matrix.c
[105]PETSC ERROR: See docs/changes/index.html for recent updates.
[97]PETSC ERROR: [121]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[105]PETSC ERROR: [115]PETSC ERROR: [114]PETSC ERROR: [111]PETSC ERROR: [100]PETSC ERROR: [113]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[109]PETSC ERROR: Configure run at
[103]PETSC ERROR: [102]PETSC ERROR: [97]PETSC ERROR: See docs/index.html for manual pages.
Configure options
[97]PETSC ERROR: [117]PETSC ERROR: ------------------------------------------------------------------------
[108]PETSC ERROR: [104]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[116]PETSC ERROR: [110]PETSC ERROR: Comm must be of size 1!
[98]PETSC ERROR: [112]PETSC ERROR: [121]PETSC ERROR: ./hit on a named nid21861 by Unknown Fri May 24 16:12:20 2013
[118]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[119]PETSC ERROR: Libraries linked from
[111]PETSC ERROR: See docs/index.html for manual pages.
[116]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
PCSetUp_GAMG() line 984 in src/ky 24 16:12:20 2013
[45]PETSC ERROR: [35]PETSC ERROR: [56]PETSC ERROR: ./hit on a named nid21819 by Unknown Fri May 24 16:12:20 2013
[46]PETSC ERROR: See docs/changes/index.html for recent updates.
[44]PETSC ERROR: [41]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[53]PETSC ERROR: Libraries linked from
[47]PETSC ERROR: [35]PETSC ERROR: [34]PETSC ERROR: [54]PETSC ERROR: [55]PETSC ERROR: See docs/changes/index.html for recent updates.
[43]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[39]PETSC ERROR: [62]PETSC ERROR: See docs/index.html for manual pages.
[38]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[53]PETSC ERROR: [43]PETSC ERROR: ------------------------------------------------------------------------
[55]PETSC ERROR: See docs/index.html for manual pages.
[32]PETSC ERROR: [56]PETSC ERROR: sp/pc/impls/gamg/gamg.c
[114]PETSC ERROR: ./hit on a named nid21861 by Unknown Fri May 24 16:12:20 2013
[100]PETSC ERROR: [126]PETSC ERROR: [101]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[123]PETSC ERROR: [97]PETSC ERROR: ./hit on a named nid21861 by Unknown Fri May 24 16:12:20 2013
[120]PETSC ERROR: [113]PETSC ERROR: [121]PETSC ERROR: [99]PETSC ERROR: ------------------------------------------------------------------------
[126]PETSC ERROR: [112]PETSC ERROR: Libraries linked from
Configure run at
[100]PETSC ERROR: See docs/changes/index.html for recent updates.
[126]PETSC ERROR: See docs/index.html for manual pages.
Configure run at
[123]PETSC ERROR: [126]PETSC ERROR: [115]PETSC ERROR: [117]PETSC ERROR: [98]PETSC ERROR: [101]PETSC ERROR: Configure options
[102]PETSC ERROR: [97]PETSC ERROR: [108]PETSC ERROR: Configure options
[110]PETSC ERROR: [99]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[125]PETSC ERROR: See docs/index.html for manual pages.
[58]PETSC ERROR: [54]PETSC ERROR: ./hit on a named nid21819 by Unknown Fri May 24 16:12:20 2013
[55]PETSC ERROR: [34]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[44]PETSC ERROR: [37]PETSC ERROR: ------------------------------------------------------------------------
[41]PETSC ERROR: [63]PETSC ERROR: [61]PETSC ERROR: [46]PETSC ERROR: [51]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[58]PETSC ERROR: Configure run at
[32]PETSC ERROR: [39]PETSC ERROR: ------------------------------------------------------------------------
[37]PETSC ERROR: Configure options
[49]PETSC ERROR: Libraries linked from
[57]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[38]PETSC ERROR: [36]PETSC ERROR: [32]PETSC ERROR: [41]PETSC ERROR: Configure options
[44]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[52]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[45]PETSC ERROR: [59]PETSC ERROR: ------------------------------------------------------------------------
[39]PETSC ERROR: [50]PETSC ERROR: ./hit on a named nid21819 by Unknown Fri May 24 16:12:20 2013
Configure run at
[61]PETSC ERROR: [37]PETSC ERROR: [43]PETSC ERROR: Configure run at
Configure run at
[46]PETSC ERROR: Configure run at
[53]PETSC ERROR: ./hit on a named nid21819 by Unknown Fri Ma[106]PETSC ERROR: ------------------------------------------------------------------------
[104]PETSC ERROR: [121]PETSC ERROR: [120]PETSC ERROR: [108]PETSC ERROR: [109]PETSC ERROR: Configure options
[100]PETSC ERROR: Configure run at
[103]PETSC ERROR: [101]PETSC ERROR: [126]PETSC ERROR: See docs/index.html for manual pages.
[114]PETSC ERROR: ------------------------------------------------------------------------
[105]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
Configure run at
[116]PETSC ERROR: Configure options
[126]PETSC ERROR: [116]PETSC ERROR: ./hit on a named nid21861 by Unknown Fri May 24 16:12:20 2013
[96]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[108]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[126]PETSC ERROR: [118]PETSC ERROR: [119]PETSC ERROR: ./hit on a named nid21861 by Unknown Fri May 24 16:12:20 2013
[114]PETSC ERROR: [105]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[116]PETSC ERROR: [117]PETSC ERROR: Libraries linked from
[102]PETSC ERROR: [98]PETSC ERROR: ./hit on a named nid21861 by Unknown Fri May 24 16:12:20 2013
[100]PETSC ERROR: [113]PETSC ERROR: [126]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[104]PETSC ERROR: [96]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[101]PETSC ERROR: See docs/changes/index.html for recent updates.
[118]PETSC ERROR: Configure run at
[96]PETSC ERROR: See docs/changes/index.html for recent updates.
[111]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[115]PETSC ERROR: ------------------------------------------------------------------------
[107]PETSC ERROR: ./hit on a named nid21861 by Unknown Fri May 24 16:12:20 2013
[124]PETSC ERROR: ./hit on a named nid21861 by Unknown Fri May 24 16:12:20 2013
[117]PETSC ERROR: [99]PETSC ERROR: [98]PETSC ERROR: [122]PETSC ERROR: ./hit on a named nid21861 by Unknown Fri May 24 16:12:20 2013
[124]PETSC ERROR: [125]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[112]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[103]PETSC ERROR: [101]PETSC ERROR: [109]PETSC ERROR: ------------------------------------------------------------------------
[110]PETSC ERROR: Libraries linked from
[99]PETSC ERROR: [119]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[100]PETSC ERROR: [111]PETSC ERROR: [105]PETSC ERROR: Configure options
[122]PETSC ERROR: See docs/changes/index.html for recent updates.
[96]PETSC ERROR: [98]PETSC ERROR: [114]PETSC ERROR: ./hit on a named nid21861 by Unknown Fri May 24 16:12:20 2013
[106]PETSC ERROR: [118]PETSC ERROR: Configure options
[119]PETSC ERROR: [115]PETSC ERROR: ------------------------------------------------------------------------
[118]PETSC ERROR: See docs/index.html for manual pages.
[107]PETSC ERROR: [120]PETSC ERROR: [96]PETSC ERROR: [102]PETSC ERROR: [103]PETSC ERROR: ./hit on a named nid21861 by Unknown Fri May 24 16:12:20 2013
Configure run at
[108]PETSC ERROR: [113]PETSC ERROR: ------------------------------------------------------------------------
[126]PETSC ERROR: [125]PETSC ERROR: [98]PETSC ERROR: [96]PETSC ERROR: Libraries linked from
[99]PETSC ERROR: Configure run at
Configure run at
[114]PETSC ERROR: [119]PETSC ERROR: ------------------------------------------------------------------------
[122]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[96]PETSC ERROR: Configure run at
[116]PETSC ERROR: [111]PETSC ERROR: ---------------------------------------------Configure run at
[13]PETSC ERROR: [15]PETSC ERROR: Configure run at
[27]PETSC ERROR: [14]PETSC ERROR: Configure options
[26]PETSC ERROR: Configure options
[16]PETSC ERROR: [20]PETSC ERROR: [15]PETSC ERROR: Configure options
[22]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[31]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[17]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[3]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[8]PETSC ERROR: [26]PETSC ERROR: ------------------------------------------------------------------------
[14]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
Configure run at
[2]PETSC ERROR: See docs/index.html for manual pages.
[25]PETSC ERROR: [6]PETSC ERROR: [7]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
Configure options
[20]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[3]PETSC ERROR: [27]PETSC ERROR: ./hit on a named nid21818 by Unknown Fri May 24 16:12:20 2013
Configure run at
[18]PETSC ERROR: Configure options
[12]PETSC ERROR: Configure options
[28]PETSC ERROR: [7]PETSC ERROR: [6]PETSC ERROR: [14]PETSC ERROR: [23]PETSC ERROR: [15]PETSC ERROR: [20]PETSC ERROR: [22]PETSC ERROR: ------------------------------------------------------------------------
[2]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[16]PETSC ERROR: ------------------------------------------------------------------------
[20]PETSC ERROR: ./hit on a named nid21818 by Unknown Fri May 24 16:12:20 2013
[14]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[28]PETSC ERROR: [11]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[17]PETSC ERROR: [24]PETSC ERROR: [26]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[27]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[26]PETSC ERROR: [16]PETSC ERROR: Configure options
Configure run at
[31]PETSC ERROR: [18]PETSC ERROR: [20]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[10]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[29]PETSC ERROR: [8]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[23]PETSC ERROR: [22]PETSC ERROR: [19]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[14]PETSC ERROR: [16]PETSC ERROR: [28]PETSC ERROR: [24]PETSC ERROR: [30]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[27]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[31]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[20]PETSC ERROR: [24]PETSC ERROR: [15]PETSC ERROR: Configure run at
[9]PETSC ERROR: [7]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[14]PETSC ERROR: ------------------------------------------------------------------------
[8]PETSC ERROR: [23]PETSC ERROR: [9]PETSC ERROR: Configure options
[15]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[30]PETSC ERROR: [6]PETSC ERROR: [13]PETSC ERROR: [7]PETSC ERROR: Configure options
[6]PETSC ERROR: [20]PETSC ERROR: [18]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[20]PETSC ERROR: [25]PETSC ERROR: [28]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[23]PETSC ERROR: [17]PETSC ERROR: Configure options
[16]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[2]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[9]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[24]PETSC ERROR: [16]PETSC ERROR: [23]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[19]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[12]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
Configure run at
[16]PETSC ERROR: [3]PETSC ERROR: Configure options
[12]PETSC ERROR: [14]PETSC ERROR: [13]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[27]PETSC ERROR: [26]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[25]PETSC ERROR: Configure options
[28]PETSC ERROR: [19]PETSC ERROR: [12]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[10]PETSC ERROR: [18]PETSC ERROR: ./hit on a named nid21818 by Unknown Fri May 24 16:12:20 2013
[17]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[31]PETSC ERROR: [30]PETSC ERROR: [3]PETSC ERROR: [29]PETSC ERROR: [24]PETSC ERROR: [19]PETSC ERROR: ------------------------------------------------------------------------
[11]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[10]PETSC ERROR: [15]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[11]PETSC ERROR: [6]PETSC ERROR: Configure run at
[24]PETSC ERROR: [27]PETSC ERROR: [29]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[28]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[2]PETSC ERROR: [24]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[7]PETSC ERROR: [17]PETSC ERROR: [30]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[31]PETSC ERROR: [2]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[11]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[10]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[14]PETSC ERROR: [16]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[31]PETSC ERROR: [7]PETSC ERROR: [24]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[7]PETSC ERROR: [26]PETSC ERROR: Configure options
[28]PETSC ERROR: [16]PETSC ERROR: [30]PETSC ERROR: [9]PETSC ERROR: Libraries linked from
[11]PETSC ERROR: [6]PETSC ERROR: ------------------------------------------------------------------------
[2]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[26]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[15]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[121]PETSC ERROR: [105]PETSC ERROR: Libraries linked from
[96]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[111]PETSC ERROR: [110]PETSC ERROR: See docs/index.html for manual pages.
Configure options
[107]PETSC ERROR: [100]PETSC ERROR: [117]PETSC ERROR: Configure options
[115]PETSC ERROR: ./hit on a named nid21861 by Unknown Fri May 24 16:12:20 2013
Configure run at
[118]PETSC ERROR: [116]PETSC ERROR: [126]PETSC ERROR: ------------------------------------------------------------------------
Configure run at
[104]PETSC ERROR: [113]PETSC ERROR: [117]PETSC ERROR: [101]PETSC ERROR: [103]PETSC ERROR: [96]PETSC ERROR: ------------------------------------------------------------------------
[98]PETSC ERROR: [122]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
Configure options
[96]PETSC ERROR: [109]PETSC ERROR: [106]PETSC ERROR: [100]PETSC ERROR: [99]PETSC ERROR: Configure run at
Configure options
[106]PETSC ERROR: ./hit on a named nid21861 by Unknown Fri May 24 16:12:20 2013
[105]PETSC ERROR: [112]PETSC ERROR: [109]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[103]PEy 24 16:12:20 2013
[49]PETSC ERROR: [52]PETSC ERROR: ./hit on a named nid21819 by Unknown Fri May 24 16:12:20 2013
[36]PETSC ERROR: [57]PETSC ERROR: [59]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[61]PETSC ERROR: Configure options
[46]PETSC ERROR: [56]PETSC ERROR: [36]PETSC ERROR: [51]PETSC ERROR: [44]PETSC ERROR: [37]PETSC ERROR: [63]PETSC ERROR: Configure run at
[47]PETSC ERROR: [34]PETSC ERROR: [45]PETSC ERROR: [38]PETSC ERROR: See docs/index.html for manual pages.
[32]PETSC ERROR: [58]PETSC ERROR: [42]PETSC ERROR: [59]PETSC ERROR: Configure options
[45]PETSC ERROR: [61]PETSC ERROR: ./hit on a named nid21819 by Unknown Fri May 24 16:12:20 2013
[43]PETSC ERROR: Libraries linked from
[54]PETSC ERROR: [57]PETSC ERROR: [35]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[58]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
Configure options
[57]PETSC ERROR: ./hit on a named nid21819 by Unknown Fri May 24 16:12:20 2013
[35]PETSC ERROR: [32]PETSC ERROR: Libraries linked from
[46]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
./hit on a named nid21819TSC ERROR: [102]PETSC ERROR: Configure options
[115]PETSC ERROR: [106]PETSC ERROR: [124]PETSC ERROR: [125]PETSC ERROR: [100]PETSC ERROR: [101]PETSC ERROR: Configure options
[96]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[127]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[124]PETSC ERROR: [126]PETSC ERROR: Libraries linked from
[103]PETSC ERROR: [111]PETSC ERROR: [102]PETSC ERROR: [100]PETSC ERROR: Configure options
[101]PETSC ERROR: Configure run at
[102]PETSC ERROR: [108]PETSC ERROR: [116]PETSC ERROR: [110]PETSC ERROR: ------------------------------------------------------------------------
[104]PETSC ERROR: Configure run at
[122]PETSC ERROR: [125]PETSC ERROR: Libraries linked from
[107]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[113]PETSC ERROR: ./hit on a named nid21861 by Unknown Fri May 24 16:12:20 2013
[122]PETSC ERROR: [118]PETSC ERROR: [109]PETSC ERROR: [126]PETSC ERROR: [127]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[111]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
PCSetUp_MG() line 729 in s by Unknown Fri May 24 16:12:20 2013
[55]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[40]PETSC ERROR: [35]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[53]PETSC ERROR: [48]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
Configure run at
Configure run at
[62]PETSC ERROR: [41]PETSC ERROR: [38]PETSC ERROR: [46]PETSC ERROR: ./hit on a named nid21819 by Unknown Fri May 24 16:12:20 2013
[61]PETSC ERROR: [62]PETSC ERROR: Libraries linked from
Configure run at
Configure options
Configure run at
[59]PETSC ERROR: [54]PETSC ERROR: [47]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[45]PETSC ERROR: [52]PETSC ERROR: [35]PETSC ERROR: Libraries linked from
[40]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[43]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[32]PETSC ERROR: [61]PETSC ERROR: Configure run at
[51]PETSC ERROR: [62]PETSC ERROR: [61]PETSC ERROR: [35]PETSC ERROR: [59]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
Configure options
[37]PETSC ERROR: [32]PETSC ERROR: ------------------------------------------------------------------------
[57]PETSC ERROR: Libraries linked from
[55]PETSC ERROR: [56]PETSC ERROR: Configure options
[38]PETSC ERROR: ------------------------rc/ksp/pc/impls/mg/mg.c
[117]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[104]PETSC ERROR: [116]PETSC ERROR: ./hit on a named nid21861 by Unknown Fri May 24 16:12:20 2013
Configure run at
[108]PETSC ERROR: [112]PETSC ERROR: [103]PETSC ERROR: [99]PETSC ERROR: [124]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[101]PETSC ERROR: [113]PETSC ERROR: [117]PETSC ERROR: Configure run at
[52]PETSC ERROR: [39]PETSC ERROR: [42]PETSC ERROR: ./hit on a named nid21819 by Unknown Fri May 24 16:12:20 2013
[41]PETSC ERROR: [35]PETSC ERROR: [32]PETSC ERROR: [61]PETSC ERROR: Libraries linked from
[63]PETSC ERROR: ./hit on a named nid21819 by Unknown Fri May 24 16:12:20 2013
Configure run at
[37]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[62]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
Configure run at
[38]PETSC ERROR: [39]PETSC ERROR: [35]PETSC ERROR: [50]PETSC ERROR: [54]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[61]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[40]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[46]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
Configure run at
[56]PETSC ERROR: [55]PETSC ERROR: [61]PETSC ERROR: [32]PETSC ERROR: [58]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
Configure options
[53]PETSC ERROR: [126]PETSC ERROR: [98]PETSC ERROR: Libraries linked from
[109]PETSC ERROR: [122]PETSC ERROR: Libraries linked from
[101]PETSC ERROR: [117]PETSC ERROR: [119]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[99]PETSC ERROR: Libraries linked from
[120]PETSC ERROR: Configure options
[126]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[105]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[100]PETSC ERROR: [101]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[106]PETSC ERROR: [107]PETSC ERROR: [104]PETSC ERROR: Configure options
[110]PETSC ERROR: [111]PETSC ERROR: Configure run at
[121]PETSC ERROR: Configure run at
[110]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[98]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
Configure options
Configure run at
[126]PETSC ERROR: [118]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[122]PETSC ERROR: [112]PETSC ERROR: Libraries linked from
[113]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[103]PETSC ERROR: Configure run at
[109]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
Configure Configure options
[36]PETSC ERROR: [37]PETSC ERROR: Libraries linked from
[41]PETSC ERROR: [39]PETSC ERROR: Libraries linked from
Configure options
[42]PETSC ERROR: [61]PETSC ERROR: [44]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
Configure run at
Configure options
[47]PETSC ERROR: [32]PETSC ERROR: [52]PETSC ERROR: [40]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[57]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[62]PETSC ERROR: [56]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
Configure run at
[36]PETSC ERROR: [54]PETSC ERROR: Configure options
[61]PETSC ERROR: ------------------------------------------------------------------------
[37]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
Configure options
[62]PETSC ERROR: [46]PETSC ERROR: [32]PETSC ERROR: Configure run at
[35]PETSC ERROR: Configure options
[61]PETSC ERROR: [54]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[36]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[43]PETSC ERROR: [62]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[59]PETSC ERROR: [58]PETSC ERROR: [37]PETSC ERROR: [36]PETSC ERRORoptions
[119]PETSC ERROR: [115]PETSC ERROR: [100]PETSC ERROR: [116]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[112]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[103]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[117]PETSC ERROR: [100]PETSC ERROR: [124]PETSC ERROR: [101]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[99]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[107]PETSC ERROR: ------------------------------------------------------------------------
[101]PETSC ERROR: [103]PETSC ERROR: [114]PETSC ERROR: [98]PETSC ERROR: [124]PETSC ERROR: ------------------------------------------------------------------------
[120]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[113]PETSC ERROR: [118]PETSC ERROR: [122]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[99]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[106]PETSC ERROR: [100]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[99]PETSC ERROR: [113]PETSC ERROR: [125]PETSC ERROR: [116]PETSC ERROR: [111]PETSC ERROR: [108]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
Configure run at
[104]PETSC ERROR: [121]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
Confi: [39]PETSC ERROR: [55]PETSC ERROR: ------------------------------------------------------------------------
[32]PETSC ERROR: [44]PETSC ERROR: Libraries linked from
[41]PETSC ERROR: gure run at
[127]PETSC ERROR: Configure run at
[112]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[115]PETSC ERROR: [114]PETSC ERROR: [125]PETSC ERROR: Configure options
[106]PETSC ERROR: Configure run at
[124]PETSC ERROR: [120]PETSC ERROR: See docs/index.html for manual pages.
[103]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[122]PETSC ERROR: [127]PETSC ERROR: [113]PETSC ERROR: Configure options
[114]PETSC ERROR: Configure options
[121]PETSC ERROR: [120]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[114]PETSC ERROR: [121]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[112]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[127]PETSC ERROR: Configure options
[103]PETSC ERROR: [113]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[122]PETSC ERROR: [115]PETSC ERROR: PCSePCSetUp() line 832 in src/ksp/pc/interface/precon.c
[32]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[58]PETSC ERROR: Configure options
[56]PETSC ERROR: [51]PETSC ERROR: [50]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[62]PETSC ERROR: [57]PETSC ERROR: Libraries linked from
[52]PETSC ERROR: [45]PETSC ERROR: Configure options
[53]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[42]PETSC ERROR: [40]PETSC ERROR: [38]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
Configure run at
Configure options
[61]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[59]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[32]PETSC ERROR: [36]PETSC ERROR: [39]PETSC ERROR: [37]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[62]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[32]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[39]PETSC ERROR: [62]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[62]PETSC ERROR: [43]PETSC ERROR: [44]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[58]PETSC ERROR: [32]PETSC ERROR: [46]PETSC ERROR: [40]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[53]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[48]PETSC ERROR: [37]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[3]PETSC ERROR: [6]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[26]PETSC ERROR: [19]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[10]PETSC ERROR: [11]PETSC ERROR: [9]PETSC ERROR: Configure run at
[27]PETSC ERROR: [2]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[3]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[18]PETSC ERROR: [7]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[13]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[16]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[6]PETSC ERROR: [8]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[26]PETSC ERROR: [25]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[17]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[3]PETSC ERROR: [10]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[14]PETSC ERROR: [18]PETSC ERROR: [7]PETSC ERROR: [17]PETSC ERROR: [29]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[2]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[24]PETSC ERROR: [27]PETSC ERROR: [26]PETSC ERROR: [28]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[27]PETSC ERROR: [6]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[7]PETSC ERROR: [31]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[29]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[13]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[17]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[31]PETSC ERROR: [3]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[18]PETSC ERROR: [7]PETSC ERROR: [9]PETSC ERROR: Configure options
[30]PETSC ERROR: [16]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[11]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[13]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[14]PETSC ERROR: [15]PETSC ERROR: [18]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[2]PETSC ERROR: [3]PETSC ERROR: [16]PETSC ERROR: [31]PETSC ERROR: [25]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[8]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[30]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[9]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[13]PETSC ERROR: [15]PETSC ERROR: [14]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[27]PETSC ERROR: [3]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[8]PETSC ERROR: [16]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[18]PETSC ERROR: [9]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[16]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[18]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[2]PETSC ERROR: [29]PETSC ERROR: [13]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[31]PETSC ERROR: [24]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[15]PETSC ERROR: [14]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[29]PETSC ERROR: [10]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[14]PETSC ERROR: [15]PETSC ERROR: [8]PETSC ERROR: ------------------------------------------------------------------------
[12]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[25]PETSC ERROR: [9]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[14]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[10]PETSC ERROR: [25]PETSC ERROR: [15]PETSC ERROR: [12]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[30]PETSC ERROR: [27]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[10]PETSC ERROR: [9]PETSC ERROR: [12]PETSC ERROR: [25]PETSC ERROR: [14]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[8]PETSC ERROR: [11]PETSC ERROR: [30]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[29]PETSC ERROR: [9]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[25]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[10]PETSC ERROR: [11]PETSC ERROR: [14]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[27]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[8]PETSC ERROR: [12]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[14]PETSC ERROR: [13]PETSC ERROR: [8]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[12]PETSC ERROR: [11]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[29]PETSC ERROR: [13]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[12]PETSC ERROR: [10]PETSC ERROR: [13]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[11]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[13]PETSC ERROR: [11]PETSC ERROR: [12]PETSC ERROR: [30]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[10]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[10]PETSC ERROR: [11]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[10]PETSC ERROR: [11]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
Invalid argument!
[1]PETSC ERROR: Comm must be of size 1!
[1]PETSC ERROR: ------------------------------------------------------------------------
[1]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[1]PETSC ERROR: See docs/changes/index.html for recent updates.
[1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[1]PETSC ERROR: See docs/index.html for manual pages.
[1]PETSC ERROR: ./hit on a named nid21818 by Unknown Fri May 24 16:12:20 2013
[1]PETSC ERROR: Libraries linked from
[1]PETSC ERROR: Configure run at
[1]PETSC ERROR: Configure options
[1]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[1]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[1]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[1]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[1]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[1]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[1]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[1]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[111]PETSC ERROR: [107]PETSC ERROR: [122]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[116]PETSC ERROR: [120]PETSC ERROR: [119]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[117]PETSC ERROR: [109]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[120]PETSC ERROR: Configure run at
[118]PETSC ERROR: [125]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[127]PETSC ERROR: [119]PETSC ERROR: [122]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[121]PETSC ERROR: [116]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[119]PETSC ERROR: [113]PETSC ERROR: [110]PETSC ERROR: [107]PETSC ERROR: [111]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[124]PETSC ERROR: [112]PETSC ERROR: [121]PETSC ERROR: Configure run at
[125]PETSC ERROR: [117]PETSC ERROR: Configure run at
[127]PETSC ERROR: [114]PETSC ERROR: [115]PETSC ERROR: [108]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
Configure options
[83]PETSC ERROR: See docs/changes/index.html for recent updates.
[71]PETSC ERROR: [78]PETSC ERROR: [66]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[67]PETSC ERROR: [70]PETSC ERROR: [74]PETSC ERROR: ------------------------------------------------------------------------
[87]PETSC ERROR: [73]PETSC ERROR: See docs/changes/index.html for recent updates.
[78]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[68]PETSC ERROR: See docs/index.html for manual pages.
[87]PETSC ERROR: [78]PETSC ERROR: [69]PETSC ERROR: See docs/changes/index.html for recent updates.
[71]PETSC ERROR: See docs/index.html for manual pages.
[70]PETSC ERROR: [69]PETSC ERROR: [74]PETSC ERROR: [86]PETSC ERROR: ------------------------------------------------------------------------
[82]PETSC ERROR: [76]PETSC ERROR: Libraries linked from
[67]PETSC ERROR: [68]PETSC ERROR: See docs/changes/index.html for recent updates.
[72]PETSC ERROR: Configure run at
[85]PETSC ERROR: [84]PETSC ERROR: [88]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[64]PETSC ERROR: [93]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
See docs/index.htm[32]PETSC ERROR: [55]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[49]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[56]PETSC ERROR: [57]PETSC ERROR: [51]PETSC ERROR: [50]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
Configure options
[52]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[43]PETSC ERROR: [62]PETSC ERROR: [57]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[56]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[62]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[36]PETSC ERROR: [42]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[51]PETSC ERROR: [46]PETSC ERROR: [106]PETSC ERROR: [124]PETSC ERROR: [118]PETSC ERROR: Configure options
[121]PETSC ERROR: [127]PETSC ERROR: [110]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[105]PETSC ERROR: [108]PETSC ERROR: [120]PETSC ERROR: ------------------------------------------------------------------------
[114]PETSC ERROR: [121]PETSC ERROR: [119]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[125]PETSC ERROR: ------------------------------------------------------------------------
[116]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[127]PETSC ERROR: [121]PETSC ERROR: [107]PETSC ERROR: [108]PETSC ERROR: [111]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[104]PETSC ERROR: l for manual pages.
[94]PETSC ERROR: [95]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[65]PETSC ERROR: [70]PETSC ERROR: [71]PETSC ERROR: [89]PETSC ERROR: See docs/changes/index.html for recent updates.
[91]PETSC ERROR: [81]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[87]PETSC ERROR: [67]PETSC ERROR: [73]PETSC ERROR: [66]PETSC ERROR: See docs/index.html for manual pages.
[80]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[78]PETSC ERROR: [85]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[70]PETSC ERROR: [67]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[43]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[49]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[57]PETSC ERROR: [37]PETSC ERROR: [36]PETSC ERROR: [62]PETSC ERROR: [54]PETSC ERROR: [51]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[50]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[45]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[54]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[36]PETSC ERROR: [55]PETSC ERROR: [47]PETSC ERROR: ./hit on a named nid21819 by Unknown Fri May 24 16:12:20 2013
[33]PETSC ERROR: [40]PETSC ERROR: [36]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
Configure run at
[46]PETSC ERROR: [56]PETSC ERROR: [41]PETSC ERROR: [44]PETSC ERROR: [49]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[112]PETSC ERROR: [116]PETSC ERROR: [121]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[115]PETSC ERROR: [117]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[114]PETSC ERROR: [116]PETSC ERROR: [125]PETSC ERROR: [127]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[119]PETSC ERROR: [106]PETSC ERROR: [113]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[118]PETSC ERROR: [105]PETSC ERROR: [104]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[118]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[106]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[125]PETSC ERROR: [115]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[107]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[110]PETSC ERROR: [77]PETSC ERROR: [66]PETSC ERROR: [68]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[71]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[72]PETSC ERROR: [76]PETSC ERROR: ./hit on a named nid21860 by Unknown Fri May 24 16:12:20 2013
[77]PETSC ERROR: Configure options
[69]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[83]PETSC ERROR: [82]PETSC ERROR: [65]PETSC ERROR: See docs/changes/index.html for recent updates.
[84]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[73]PETSC ERROR: [66]PETSC ERROR: [67]PETSC ERROR: See docs/changes/index.html for recent updates.
[85]PETSC ERROR: [93]PETSC ERROR: [81]PETSC ERROR: [80]PETSC ERROR: [65]PETSC ERROR: See docs/changes/index.html for recent updates.
[89]PETSC ERROR: Libraries linked from
[74]PETSC ERROR: See docs/index.html for manual pages.
[78]PETSC ERROR: [72]PETSC ERROR: See docs/index.html for manual pages.
[81]PETSC ERROR: [95]PETSC ERROR: [70]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[69]PETSC ERROR: [68]PETSC ERROR: See docs/index.html for manual pages.
See docs/index.html for manual pagesPCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[58]PETSC ERROR: Libraries linked from
[33]PETSC ERROR: [58]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
Configure run at
[52]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[49]PETSC ERROR: [40]PETSC ERROR: [33]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
Configure options
Configure options
[56]PETSC ERROR: [57]PETSC ERROR: [51]PETSC ERROR: [52]PETSC ERROR: [41]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[50]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[54]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[48]PETSC ERROR: [33]PETSC ERROR: ------------------------------------------------------------------------
[57]PETSC ERROR: [49]PETSC ERROR: Configure run at
[40]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[53]PETSC ERROR: [111]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[124]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[113]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[125]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[116]PETSC ERROR: [114]PETSC ERROR: [124]PETSC ERROR: [112]PETSC ERROR: [107]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[113]PETSC ERROR: [119]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[117]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[115]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[121]PETSC ERROR: [124]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[125]PETSC ERROR: [127]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[118]PETSC ERROR: [117]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[109]PETSC ERROR: [114]PETSC ERROR: [112]PETSC ERROR: [110]PETSC ERROR: [107]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[118]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[65]PETSC ERROR: Configure run at
[76]PETSC ERROR: [72]PETSC ERROR: [87]PETSC ERROR: ------------------------------------------------------------------------
[70]PETSC ERROR: See docs/changes/index.html for recent updates.
[88]PETSC ERROR: [91]PETSC ERROR: [84]PETSC ERROR: ------------------------------------------------------------------------
[93]PETSC ERROR: ------------------------------------------------------------------------
[77]PETSC ERROR: ./hit on a named nid21860 by Unknown Fri May 24 16:12:20 2013
[76]PETSC ERROR: [68]PETSC ERROR: Libraries linked from
[84]PETSC ERROR: [94]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[91]PETSC ERROR: [82]PETSC ERROR: [65]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[87]PETSC ERROR: ./hit on a named nid21860 by Unknown Fri May 24 16:12:20 2013
[81]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[71]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[66]PETSC ERROR: [67]PETSC ERROR: [65]PETSC ERROR: ------------------------------------------------------------------------
./hit on a named nid21860 by Unknown Fri Ma[56]PETSC ERROR: [52]PETSC ERROR: [58]PETSC ERROR: [51]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[54]PETSC ERROR: [55]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
Configure run at
[44]PETSC ERROR: [53]PETSC ERROR: [58]PETSC ERROR: [48]PETSC ERROR: [57]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[33]PETSC ERROR: Configure options
[47]PETSC ERROR: [40]PETSC ERROR: [33]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[48]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[52]PETSC ERROR: [53]PETSC ERROR: ------------------------------------------------------------------------
[43]PETSC ERROR: [42]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[33]PETSC ERROR: [52]PETSC ERROR: [55]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[41]PETSC ERROR: [49]PETSC ERROR: ./hit on a named nid21819 by Unknown Fri May 24 16:12:20 2013
[48]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[127]PETSC ERROR: [107]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[127]PETSC ERROR: [117]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[108]PETSC ERROR: [109]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[112]PETSC ERROR: [124]PETSC ERROR: [125]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[115]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[113]PETSC ERROR: [127]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[125]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[106]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[121]PETSC ERROR: [120]PETSC ERROR: [124]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[112]PETSC ERROR: [114]PETSC ERROR: [125]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[12y 24 16:12:20 2013
[85]PETSC ERROR: ./hit on a named nid21860 by Unknown Fri May 24 16:12:20 2013
[86]PETSC ERROR: [91]PETSC ERROR: [77]PETSC ERROR: Libraries linked from
[67]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[69]PETSC ERROR: Configure run at
Configure options
[94]PETSC ERROR: [76]PETSC ERROR: [65]PETSC ERROR: Configure run at
[71]PETSC ERROR: [70]PETSC ERROR: Libraries linked from
[65]PETSC ERROR: [73]PETSC ERROR: [66]PETSC ERROR: [87]PETSC ERROR: See docs/changes/index.html for recent updates.
[77]PETSC ERROR: [74]PETSC ERROR: ------------------------------------------------------------------------
[83]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
Configure options
[68]PETSC ERROR: [91]PETSC ERROR: See docs/index.html for manual pages.
Configure run at
[71]PETSC ERROR: [80]PETSC ERROR: See docs/index.html for manual pages.
[94]PETSC ERROR: Configure run at
[68]PETSC ERROR: [93]PETSC ERROR: Libraries linked from
[76]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[74]PETSC ERROR: [57]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[53]PETSC ERROR: [60]PETSC ERROR: [33]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[56]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[48]PETSC ERROR: [46]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[33]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[60]PETSC ERROR: [50]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[33]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[49]PETSC ERROR: [53]PETSC ERROR: [57]PETSC ERROR: [60]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[49]PETSC ERROR: [40]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[53]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
Configure options
[55]PETSC ERROR: [60]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[57]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[49]PETSC ERROR: [50]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[42]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[44]0]PETSC ERROR: [124]PETSC ERROR: [121]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[108]PETSC ERROR: [115]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[106]PETSC ERROR: [127]PETSC ERROR: [112]PETSC ERROR: [85]PETSC ERROR: [84]PETSC ERROR: ./hit on a named nid21860 by Unknown Fri May 24 16:12:20 2013
[86]PETSC ERROR: [83]PETSC ERROR: ------------------------------------------------------------------------
[69]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[82]PETSC ERROR: ------------------------------------------------------------------------
Configure options
[91]PETSC ERROR: [73]PETSC ERROR: [67]PETSC ERROR: [66]PETSC ERROR: Libraries linked from
[93]PETSC ERROR: [72]PETSC ERROR: See docs/index.html for manual pages.
[88]PETSC ERROR: [81]PETSC ERROR: ./hit on a named nid21860 by Unknown Fri May 24 16:12:20 2013
[83]PETSC ERROR: [94]PETSC ERROR: ./hit on a named nid21860 by Unknown Fri May 24 16:12:20 2013
[85]PETSC ERROR: [82]PETSC ERROR: ./hit on a named nid21860 by Unknown Fri May 24 16:12:20 2013
[70]PETSC ERROR: [72]PETSC ERROR: [88]PETSC ERROR: [91]PETSC ERROR: ./hit on a named nid21860 by Unknown Fri May 24 16:12:20 2013
Configure run at
Configure run at
Configure run at
[66]PETSC ERROR: [72]PETSC ERROR: ------------------------------------------------------------------------
[74]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
Configure options
[71]PETSC ERROR: [68]PETSC ERROR: [93]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[91]PETSC ERROR: ------------------------------------------------------------------------
[71]PETSC ERROR: ------------------PETSC ERROR: [51]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[53]PETSC ERROR: [60]PETSC ERROR: [33]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[43]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
Configure options
[120]PETSC ERROR: [104]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[110]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[109]PETSC ERROR: [120]PETSC ERROR: [106]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[105]PETSC ERROR: [120]PETSC ERROR: [117]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[114]PETSC ERROR: [127]PETSC ERROR: [124]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[112]PETSC ERROR: [120]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[125]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[114]PETSC ERROR: [110]PETSC ERROR: [111]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[117]PETSC ERROR: [106]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[104]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[114]PETSC ERROR: [117]PETSC ERROR: [125]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gam------------------------------------------------------
[74]PETSC ERROR: Configure options
Configure options
[84]PETSC ERROR: Configure run at
[78]PETSC ERROR: Configure run at
--------------------- Error Message ------------------------------------
[67]PETSC ERROR: [68]PETSC ERROR: [89]PETSC ERROR: [82]PETSC ERROR: [83]PETSC ERROR: [91]PETSC ERROR: [84]PETSC ERROR: [76]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[74]PETSC ERROR: ./hit on a named nid21860 by Unknown Fri May 24 16:12:20 2013
[68]PETSC ERROR: Configure options
[80]PETSC ERROR: [81]PETSC ERROR: [71]PETSC ERROR: Configure run at
Configure run at
Configure options
[87]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[93]PETSC ERROR: [69]PETSC ERROR: Configure options
[89]PETSC ERROR: [94]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[78]PETSC ERROR: ------------------------------------------------------------------------
[68]PETSC ERROR: [69]PETSC ERROR: [72]PETSC ERROR: [91]PETSC ERROR: [66]PETSC ERROR: Configure options
Configure run at
Configure options
[93]PETSC ERROR: Configure options
[86]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[67]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/[47]PETSC ERROR: [49]PETSC ERROR: [55]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[60]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[54]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[44]PETSC ERROR: [45]PETSC ERROR: [33]PETSC ERROR: [48]PETSC ERROR: [51]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[54]PETSC ERROR: [55]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[47]PETSC ERROR: [50]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[50]PETSC ERROR: [60]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[41]PETSC ERROR: [49]PETSC ERROR: [48]PETSC ERROR: [42]PETSC ERROR: [47]PETSC ERROR: [60]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[45]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
PCSetUp_Mdense.c
[67]PETSC ERROR: [93]PETSC ERROR: [91]PETSC ERROR: [94]PETSC ERROR: [78]PETSC ERROR: [66]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[79]PETSC ERROR: See docs/index.html for manual pages.
[76]PETSC ERROR: [69]PETSC ERROR: [72]PETSC ERROR: ./hit on a named nid21860 by Unknown Fri May 24 16:12:20 2013
[88]PETSC ERROR: Configure run at
[70]PETSC ERROR: ------------------------------------------------------------------------
Configure run at
[93]PETSC ERROR: [91]PETSC ERROR: ------------------------------------------------------------------------
[89]PETSC ERROR: [70]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[86]PETSC ERROR: [72]PETSC ERROR: [68]PETSC ERROR: [74]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[87]PETSC ERROR: [93]PETSC ERROR: [94]PETSC ERROR: [91]PETSC ERROR: [83]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[80]PETSC ERROR: [73]PETSC ERROR: Configure options
[88]PETSC ERROR: [74]PETSC ERROR: Libraries linked from
[67]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[85]PETSC ERROR: [73]PETSC ERROR: [82]PETSC ERROR: Configure options
[94]PETSC ERROR: ------------------------------------------------------------------------
Configure run at
[84]PETSC ERROR: [83]PETSC ERROR: ------------------------------------------------------------------------
[85]PETSC ERROR: [76]PETSC ERROR: [81]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[78]PETSC ERROR: [77]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[71]PETSC ERROR: ./hit on a named nid21860 by Unknown Fri May 24 16:12:20 2013
[72]PETSC ERROR: [80]PETSC ERROR: ------------------------------------------------------------------------
[68]PETSC ERROR: [69]PETSC ERROR: [88]PETSC ERROR: [74]PETSC ERROR: Configure options
[66]PETSC ERROR: ------------------------------------------------------------------------
[83]PETSC ERROR: [82]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[93]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
Configure run at
[94]PETSC ERROR: [67]PETSC ERROR: Libraries linked from
Invalid argument!
[91]PETSC ERROR: [93]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[76]PETSC ERROR: See docs/index.html for manual pages.
Configure options
[5]PETSC ERROR: [21]PETSC ERROR: ------------------------------------------------------------------------
[5]PETSC ERROR: [21]PETSC ERROR: ./hit on a named nid21818 by Unknown Fri May 24 16:12:20 2013
[5]PETSC ERROR: [21]PETSC ERROR: Libraries linked from
[5]PETSC ERROR: [21]PETSC ERROR: Configure run at
[5]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
Configure options
[5]PETSC ERROR: [21]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[5]PETSC ERROR: [21]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[5]PETSC ERROR: [21]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[5]PETSC ERROR: [21]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[5]PETSC ERROR: [21]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[5]PETSC ERROR: [21]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[5]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[5]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[5]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[5]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[80]PETSC ERROR: Libraries linked from
[68]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[78]PETSC ERROR: [79]PETSC ERROR: [84]PETSC ERROR: Configure run at
[72]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[74]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[71]PETSC ERROR: ------------------------------------------------------------------------
[94]PETSC ERROR: [77]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[82]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[91]PETSC ERROR: [88]PETSC ERROR: [67]PETSC ERROR: [70]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[69]PETSC ERROR: [71]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
Configure run at
[83]PETSC ERROR: Configure options
[94]PETSC ERROR: [88]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[86]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[69]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
Configure run at
[76]PETSC ERROR: [81]PETSC ERROR: [80]PETSC ERROR: [93]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[67]PETSC ERROR: [71]PETSC ERROR: [87]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[93]PETSC ERROR: Comm must be of size 1!
[69]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[67]PETSC ERROR: [84]PETSC ERROR: [85]PETSC ERROR: Configure options
[78]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
Configure run at
[80]PETSC ERROR: [94]PETSC ERROR: [81]PETSC ERROR: [79]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[73]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[93]PETSC ERROR: [89]PETSC ERROR: ------------------------------------------------------------------------
[69]PETSC ERROR: ------------------------------------------------------------------------
[89]PETSC ERROR: Configure options
[76]PETSC ERROR: [67]PETSC ERROR: Configure options
[80]PETSC ERROR: [69]PETSC ERROR: [81]PETSC ERROR: [70]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[94]PETSC ERROR: [83]PETSC ERROR: Configure options
[66]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[88]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[88]PETSC ERROR: [71]PETSC ERROR: [66]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[85]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[78]PETSC ERROR: [66]PETSC ERROR: [93]PETSC ERROR: [94]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[70]PETSC ERROR: [91]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[86]PETSC ERROR: [74]PETSC ERROR: [67]PETSC ERROR: Libraries linked from
[82]PETSC ERROR: [71]PETSC ERROR: [79]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[89]PETSC ERROR: [74]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[84]PETSC ERROR: [72]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[74]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[88]PETSC ERROR: [86]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[81]PETSC ERROR: Configure run at
[83]PETSC ERROR: [77]PETSC ERROR: Configure run at
[91]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[70]PETSC ERROR: [66]PETSC ERROR: [73]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[89]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[87]PETSC ERROR: [86]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[91]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[76]PETSC ERROR: [66]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[94]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[80]PETSC ERROR: [71]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[89]PETSC ERROR: [83]PETSC ERROR: [88]PETSC ERROR: [94]PETSC ERROR: [82]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[84]PETSC ERROR: [72]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
Configure options
Configure options
[85]PETSC ERROR: [94]PETSC ERROR: [84]PETSC ERROR: ------------------------------------------------------------------------
[78]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[76]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[72]PETSC ERROR: [74]PETSC ERROR: [91]PETSC ERROR: [82]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[94]PETSC ERROR: [83]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[80]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[86]PETSC ERROR: [74]PETSC ERROR: [76]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[70]PETSC ERROR: [72]PETSC ERROR: [81]PETSC ERROR: [89]PETSC ERROR: [79]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[73]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[88]PETSC ERROR: [89]PETSC ERROR: ------------------------------------------------------------------------
[70]PETSC ERROR: [81]PETSC ERROR: [84]PETSC ERROR: [87]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[78]PETSC ERROR: [72]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[80]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[78]PETSC ERROR: [86]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[80]PETSC ERROR: [82]PETSC ERROR: [85]PETSC ERROR: [83]PETSC ERROR: [87]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[72]PETSC ERROR: [82]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[88]PETSC ERROR: [86]PETSC ERROR: [81]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[80]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[89]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[81]PETSC ERROR: [83]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[79]PETSC ERROR: [76]PETSC ERROR: [73]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[87]PETSC ERROR: [80]PETSC ERROR: [83]PETSC ERROR: [81]PETSC ERROR: [79]PETSC ERROR: [86]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[88]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[81]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[73]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[77]PETSC ERROR: [86]PETSC ERROR: See docs/index.html for manual pages.
[79]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[86]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[88]PETSC ERROR: [82]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[80]PETSC ERROR: [73]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[78]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[77]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[87]PETSC ERROR: [81]PETSC ERROR: [79]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[86]PETSC ERROR: [72]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[77]PETSC ERROR: [82]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[73]PETSC ERROR: [84]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[80]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[85]PETSC ERROR: [81]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[78]PETSC ERROR: [89]PETSC ERROR: [82]PETSC ERROR: [87]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[84]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[77]PETSC ERROR: [88]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[89]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[81]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[88]PETSC ERROR: [84]PETSC ERROR: [73]PETSC ERROR: [85]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[78]PETSC ERROR: ./hit on a named nid21860 by Unknown Fri May 24 16:12:20 2013
[87]PETSC ERROR: [79]PETSC ERROR: [85]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[89]PETSC ERROR: [79]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[77]PETSC ERROR: [86]PETSC ERROR: [87]PETSC ERROR: [85]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[79]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
Configure options
[73]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[79]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[86]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[85]PETSC ERROR: [73]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[79]PETSC ERROR: [85]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[77]PETSC ERROR: [79]PETSC ERROR: [73]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[79]PETSC ERROR: [77]PETSC ERROR: [73]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[79]PETSC ERROR: [77]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[79]PETSC ERROR: [77]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[79]PETSC ERROR: [77]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[79]PETSC ERROR: [77]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[75]PETSC ERROR: [90]PETSC ERROR: Invalid argument!
[75]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
[64]PETSC ERROR: [90]PETSC ERROR: [75]PETSC ERROR: See docs/changes/index.html for recent updates.
[90]PETSC ERROR: [64]PETSC ERROR: ------------------------------------------------------------------------
[90]PETSC ERROR: [75]PETSC ERROR: [64]PETSC ERROR: See docs/index.html for manual pages.
[90]PETSC ERROR: See docs/index.html for manual pages.
[75]PETSC ERROR: [64]PETSC ERROR: [90]PETSC ERROR: See docs/changes/index.html for recent updates.
[90]PETSC ERROR: [75]PETSC ERROR: [64]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[75]PETSC ERROR: [92]PETSC ERROR: [90]PETSC ERROR: ./hit on a named nid21860 by Unknown Fri May 24 16:12:20 2013
[75]PETSC ERROR: Configure run at
[92]PETSC ERROR: [64]PETSC ERROR: [90]PETSC ERROR: ------------------------------------------------------------------------
[64]PETSC ERROR: Configure options
[92]PETSC ERROR: Configure run at
[75]PETSC ERROR: ./hit on a named nid21860 by Unknown Fri May 24 16:12:20 2013
[90]PETSC ERROR: [92]PETSC ERROR: [64]PETSC ERROR: ------------------------------------------------------------------------
Configure options
[90]PETSC ERROR: [64]PETSC ERROR: Libraries linked from
[92]PETSC ERROR: [90]PETSC ERROR: [64]PETSC ERROR: Configure run at
[75]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[92]PETSC ERROR: [90]PETSC ERROR: Configure options
[92]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[90]PETSC ERROR: Configure run at
[92]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[64]PETSC ERROR: [90]PETSC ERROR: [92]PETSC ERROR: [75]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
Configure options
[92]PETSC ERROR: [64]PETSC ERROR: [90]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[92]PETSC ERROR: [90]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[64]PETSC ERROR: [75]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[92]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[64]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[90]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[92]PETSC ERROR: [90]PETSC ERROR: [75]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[92]PETSC ERROR: [64]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[90]PETSC ERROR: [92]PETSC ERROR: [64]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[75]PETSC ERROR: [92]PETSC ERROR: [64]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[75]PETSC ERROR: [92]PETSC ERROR: [64]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[75]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[75]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[75]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
hit: gamg.c:568: PCSetUp_GAMG: Assertion `pc->setupcalled' failed.
[95]PETSC ERROR: ------------------------------------------------------------------------
[95]PETSC ERROR: ./hit on a named nid21860 by Unknown Fri May 24 16:12:20 2013
[95]PETSC ERROR: Libraries linked from
[95]PETSC ERROR: Configure run at
[95]PETSC ERROR: Configure options
[95]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[95]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[95]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[95]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[95]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[95]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[95]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[95]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[54]PETSC ERROR: [49]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[60]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[55]PETSC ERROR: [50]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[48]PETSC ERROR: [60]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[47]PETSC ERROR: [41]PETSC ERROR: [43]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[48]PETSC ERROR: [40]PETSC ERROR: [47]PETSC ERROR: [44]PETSC ERROR: [42]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[48]PETSC ERROR: g/gamg.c
[115]PETSC ERROR: [117]PETSC ERROR: [125]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[105]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[115]PETSC ERROR: [110]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[104]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[108]PETSC ERROR: [107]PETSC ERROR: [109]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[105]PETSC ERROR: [110]PETSC ERROR: [104]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[109]PETSC ERROR: [110]PETSC ERROR: [107]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[105]PETSC ERROR: [110]PETSC ERROR: [108]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[108]PETSC ERROR: [105]PETSC ERROR: [109]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[108]PETSC ERROR: [109]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[45]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[47]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[45]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[44]PETSC ERROR: [40]PETSC ERROR: [47]PETSC ERROR: [41]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[41]PETSC ERROR: [40]PETSC ERROR: [42]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[45]PETSC ERROR: [42]PETSC ERROR: [43]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[42]PETSC ERROR: [40]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[45]PETSC ERROR: [43]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[40]PETSC ERROR: [42]PETSC ERROR: [47]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[47]PETSC ERROR: [45]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[41]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[44]PETSC ERROR: [42]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[47]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[43]PETSC ERROR: [41]PETSC ERROR: [44]PETSC ERROR: [45]PETSC ERROR: PCSetUp_MG()See docs/index.html for manual pages.
[123]PETSC ERROR: ------------------------------------------------------------------------
[96]PETSC ERROR: [123]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[96]PETSC ERROR: [123]PETSC ERROR: Libraries linked from
[123]PETSC ERROR: Configure run at
[96]PETSC ERROR: [123]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
Configure options
[96]PETSC ERROR: [123]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[96]PETSC ERROR: [123]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[96]PETSC ERROR: [123]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[96]PETSC ERROR: [123]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[96]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[123]PETSC ERROR: [96]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[41]PETSC ERROR: [47]PETSC ERROR: [44]PETSC ERROR: [45]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[40]PETSC ERROR: [41]PETSC ERROR: [45]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
hit: gamg.c:568: PCSetUp_GAMG: AssertiKSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[63]PETSC ERROR: [34]PETSC ERROR: Configure run at
[34]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[34]PETSC ERROR: [63]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[34]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
Configure options
[59]PETSC ERROR: [63]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[63]PETSC ERROR: [59]PETSC ERROR: MatCreate_SeqDense() line 2189 in src/mat/impls/dense/seq/dense.c
[63]PETSC ERROR: [59]PETSC ERROR: MatSetType() line 74 in src/mat/interface/matreg.c
[63]PETSC ERROR: [59]PETSC ERROR: MatConvert() line 3747 in src/mat/interface/matrix.c
[63]PETSC ERROR: [59]PETSC ERROR: PCSetUp_SVD() line 51 in src/ksp/pc/impls/svd/svd.c
[63]PETSC ERROR: [59]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[63]PETSC ERROR: [59]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
[63]PETSC ERROR: [59]PETSC ERROR: PCSetUp_MG() line 729 in src/ksp/pc/impls/mg/mg.c
[63]PETSC ERROR: [59]PETSC ERROR: PCSetUp_GAMG() line 984 in src/ksp/pc/impls/gamg/gamg.c
[63]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
_pmiu_daemon(SIGCHLD): [NID 21860] [c9-1c1s2n2] [Fri May 24 16:12:48 2013] PE RANK 64 exit signal Aborted
[NID 21860] 2013-05-24 16:12:48 Apid 1659986: initiated application termination
_pmiu_daemon(SIGCHLD): [NID 21861] [c9-1c1s2n3] [Fri May 24 16:12:48 2013] PE RANK 96 exit signal Aborted
Application 1659986 exit codes: 134
Application 1659986 exit signals: Killed
Application 1659986 resources: utime ~62s, stime ~34s
