[petsc-users] Memory logging in fortran
Barry Smith
bsmith at mcs.anl.gov
Thu May 23 18:45:53 CDT 2013
Colin,
Thanks for the info. We'll try to reorganize getting the memory size on the Apple using your information and get it into a patch.
Barry
On May 23, 2013, at 4:11 PM, Colin McAuliffe <cjm2176 at columbia.edu> wrote:
> So after comparing the results of getrusage with guppy, a python memory profiling tool, it seems the os x getrusage is returning bytes in contrast to the os x man pages which say the results are in kb. Doing the same tests on a linux machine, it looks like getrusage is returning kb as it says in the documentation. Anyway it is not problem to correct the results of the petsc memory functions from my application code. Thanks for all your help!
> Colin
> Quoting Barry Smith <bsmith at mcs.anl.gov>:
>> On May 22, 2013, at 8:32 PM, Colin McAuliffe <cjm2176 at columbia.edu> wrote:
>>> According to gdb the program goes here
>>> 110: #elif defined(PETSC_HAVE_TASK_INFO)
>>> 111: *mem = 0;
>>> The configuration flags from my petsc compilation indicate that both PETSC_HAVE_TASK_INFO and PETSC_HAVE_GETRUSAGE are 1. I'm not sure what have task info is supposed to do, is it safe to set it to 0 to see if this fixes the problem?
>> Remove the PETSC_HAVE_TASK_INFO stuff completely and then rerun make and see if it solves the problem.
>> At some point the TASK_INFO stuff worked on the Apple some years ago, perhaps they turned if off.
>> Barry
>>>> On May 22, 2013, at 7:06 PM, Colin McAuliffe <cjm2176 at columbia.edu> wrote:
>>>>> Hi Barry, thanks for the quick response.
>>>>> I am using os x and so I would expect that petsc would be able to use getrusage in the following lines of mem.c:
>>>>> 115: #elif defined(PETSC_HAVE_GETRUSAGE)
>>>>> 116: getrusage(RUSAGE_SELF,&temp);
>>>>> Is this not the case?
>>>> You can run in the debugger, put a break point at that line to verify it goes there and if it does check the values of temp after the call. (Sometimes Apple's docs are more optimistic than reality.)
>>>> Barry
>>>>> Here is the link to apple's getrusage manual page
>>>>> http://developer.apple.com/library/mac/#documentation/Darwin/Reference/ManPages/10.7/man2/getrusage.2.html
>>>>>> Colin,
>>>>>> PetscMemoryGetCurrentUsage() and MaximumUsage() us calls to the underlying operating system to get how much memory the process is using, as such they will also include external package memory. Unfortunately it depends on the operating system providing this information and often it does not, this is why you get 0. If you are a hacker you could look at the source for PetscMemoryGetCurrentUsage() and see how to get the information for your OS and add it to this routine.
>>>>>> Barry
>>>>>> On May 22, 2013, at 6:31 PM, Colin McAuliffe <cjm2176 at columbia.edu> wrote:
>>>>>>> Hi all,
>>>>>>> When calling PetscMemoryGetCurrentUsage or PetscMemoryGetMaximumUsage in a fortran code the memory usage returned is always zero. Adding command line options such as -malloc_log and -memory_info doesn't change this result. Is there something else I'm missing? Also, will use of these two functions give memory used by external packaged called by petsc?
>>>>>>> All the best,
>>>>>>> Colin
>>>>>>> Colin McAuliffe
>>>>>>> PhD Candidate
>>>>>>> Columbia University
>>>>>>> Department of Civil Engineering and Engineering Mechanics
>>>>> Colin McAuliffe
>>>>> PhD Candidate
>>>>> Columbia University
>>> Colin McAuliffe
>>> PhD Candidate
>>> Columbia University
> Colin McAuliffe
> PhD Candidate
> Columbia University
