[petsc-users] DMDACoor3d and VecView
Jed Brown
jedbrown at mcs.anl.gov
Thu May 23 11:31:59 CDT 2013
Roc Wang <pengxwang at hotmail.com> writes:
>> From: jedbrown at mcs.anl.gov
>> To: pengxwang at hotmail.com; petsc-users at mcs.anl.gov
>> Subject: Re: [petsc-users] DMDACoor3d and VecView
>> Date: Thu, 23 May 2013 10:10:19 -0500
>> > The coordinates of nodes are needed to plot the 3-D distributions of
>> > the solution. The matrix and the vector are managed with DMDA, so the
>> > array for the coordinates can be obtained by
>> > DMDAGetCoordinateDA(da,&cda) and DMDAVecGetArray(cda,gc,&coors).
>> > Here, coors is defined as DMDACoor3d ***coors. Since the function
>> > VecVeiw can only output one vector, Vec sol, to a binary file , the
>> > array of coordinates must be output to another file and thus must be
>> > read separately.
>> Not true, just read them in the same order you wrote them.
> Does this mean I can save the vectors in the same binary file? If yes, whether the following procedure is correct?
> /* writing vectors in solver program */
> DM cda;
> Vec gc;
> ierr = DMDAGetCoordinateDA(da,&cda);CHKERRQ(ierr);
> ierr = DMDAGetCoordinates(cda, &gc);CHKERRQ(ierr);
> ierr = PetscViewerBinaryOpen(PETSC_COMM_WORLD,"vector.bin",FILE_MODE_WRITE,&viewer);CHKERRQ(ierr);
> ierr = VecView(sol,viewer);CHKERRQ(ierr); //write solution vector
> ierr = VecView(gc,viewer);CHKERRQ(ierr); //write coordinate vector
> ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr);
> /* reading vectors in a stand-along program */
> ierr = VecCreate(PETSC_COMM_WORLD,&sol);CHKERRQ(ierr);
> ierr = VecCreate(PETSC_COMM_WORLD,&gc);CHKERRQ(ierr);
Create your DM and coordinate DM, then
DMCreateGlobalVector(da,&sol);
DMCreateGlobalVector(cda,&gc);
then below
> ierr = PetscViewerBinaryOpen(PETSC_COMM_WORLD,"vector.bin",FILE_MODE_READ,&viewer);CHKERRQ(ierr);
> ierr = VecLoad(sol,viewer);CHKERRQ(ierr); //read solution vector
> ierr = VecLoad(gc,viewer);CHKERRQ(ierr); //read coordinate vector
Alternatively, write the DM too so that you can load it instead of
making it from out-of-band knowledge of sizes:
ierr = DMView(da,viewer);CHKERRQ(ierr);
ierr = VecView(global,viewer);CHKERRQ(ierr);
ierr = DMView(cda,viewer);CHKERRQ(ierr);
and read with
ierr = DMLoad(da,bviewer);CHKERRQ(ierr);
ierr = DMCreateGlobalVector(da,&sol);CHKERRQ(ierr);
ierr = DMLoad(cda,viewer);CHKERRQ(ierr);
ierr = DMCreateGlobalVector(cda,&gc);CHKERRQ(ierr);
See src/dm/examples/tests/ex14.c and ex13.c.
>> > The problem is that the array of coordinates is local array and the
>> > number of processes in the post-processing program must be same as
>> > that in the solver.
>> DMGetCoordinates() returns a global Vec. Store that, not the local Vec.
>> From the names, you must have an older version of PETSc. Please upgrade
>> to petsc-3.4.
