[petsc-users] Memory logging in fortran
Colin McAuliffe cjm2176 at columbia.edu
Wed May 22 23:21:48 CDT 2013
Removing the have task info stuff leads to getrusage being called.
Though there must be a bug in the os x getrusage because the max
resident set size it returns is too large to be right. I realize this
is not related to petsc, but if you are interested the python script:
import resource
import sys
t = range(0,10000)
print "Size of t is ",sys.getsizeof(t),"bytes"
print "Max resident set size is
",resource.getrusage(resource.RUSAGE_SELF)[2]*1024,"bytes"
gives the output:
Size of t is  80072 bytes
Max resident set size is  4521459712 bytes
I would guess the two values should be in the same ballpark, and
actually the computed resident set size is larger than the amount of
memory I have to begin with! Hopefully the apple developers would be
able to help.
Thanks
Colin
Quoting Barry Smith <bsmith at mcs.anl.gov>:
> On May 22, 2013, at 8:32 PM, Colin McAuliffe <cjm2176 at columbia.edu> wrote:
>> According to gdb the program goes here
>> 110: #elif defined(PETSC_HAVE_TASK_INFO)
>> 111:   *mem = 0;
>> The configuration flags from my petsc compilation indicate that
>> both PETSC_HAVE_TASK_INFO and PETSC_HAVE_GETRUSAGE are 1. I'm not
>> sure what have task info is supposed to do, is it safe to set it to
>>  0 to see if this fixes the problem?
>     Remove the PETSC_HAVE_TASK_INFO  stuff completely and then rerun
>  make and see if it solves the problem.
>      At some point the TASK_INFO stuff worked on the Apple some
> years ago, perhaps they turned if off.
>    Barry
>>> On May 22, 2013, at 7:06 PM, Colin McAuliffe <cjm2176 at columbia.edu> wrote:
>>>> Hi Barry, thanks for the quick response.
>>>> I am using os x and so I would expect that petsc would be able to
>>>>   use getrusage in the following lines of mem.c:
>>>> 115: #elif defined(PETSC_HAVE_GETRUSAGE)
>>>> 116:   getrusage(RUSAGE_SELF,&temp);
>>>> Is this not the case?
>>>   You can run in the debugger, put a break point at that line to
>>> verify it goes there and if it does check the values of temp after
>>>   the call. (Sometimes Apple's docs are more optimistic than
>>> reality.)
>>>   Barry
>>>> Here is the link to apple's getrusage manual page
>>>> http://developer.apple.com/library/mac/#documentation/Darwin/Reference/ManPages/10.7/man2/getrusage.2.html
>>>>>  Colin,
>>>>>   PetscMemoryGetCurrentUsage() and MaximumUsage() us calls to
>>>>> the   underlying operating system to get how much memory the
>>>>> process is   using, as such they will also include external
>>>>> package memory.   Unfortunately it depends on the operating
>>>>> system providing this   information and often it does not, this
>>>>> is why you get 0. If you  are  a hacker you could look at the
>>>>> source for   PetscMemoryGetCurrentUsage() and see how to get the
>>>>>  information  for  your OS and add it to this routine.
>>>>>  Barry
>>>>> On May 22, 2013, at 6:31 PM, Colin McAuliffe
>>>>>> Hi all,
>>>>>> When calling PetscMemoryGetCurrentUsage or
>>>>>> PetscMemoryGetMaximumUsage in a fortran code the memory usage
>>>>>>  returned is always zero. Adding command line options such as
>>>>>>  -malloc_log and -memory_info doesn't change this result. Is
>>>>>> there   something else I'm missing? Also, will use of these two
>>>>>>   functions  give memory used by external packaged called by
>>>>>> petsc?
>>>>>> All the best,
>>>>>> Colin
>>>>>> Colin McAuliffe
>>>>>> PhD Candidate
>>>>>> Columbia University
>>>>>> Department of Civil Engineering and Engineering Mechanics
>>>> Colin McAuliffe
>>>> PhD Candidate
>>>> Columbia University
>> Colin McAuliffe
>> PhD Candidate
>> Columbia University
Colin McAuliffe
PhD Candidate
Columbia University
