[petsc-users] Memory logging in fortran
Colin McAuliffe cjm2176 at columbia.edu
Wed May 22 20:32:23 CDT 2013
According to gdb the program goes here
110: #elif defined(PETSC_HAVE_TASK_INFO)
111:   *mem = 0;
The configuration flags from my petsc compilation indicate that both
PETSC_HAVE_TASK_INFO and PETSC_HAVE_GETRUSAGE are 1. I'm not sure what
have task info is supposed to do, is it safe to set it to 0 to see if
this fixes the problem?
Quoting Barry Smith <bsmith at mcs.anl.gov>:
> On May 22, 2013, at 7:06 PM, Colin McAuliffe <cjm2176 at columbia.edu> wrote:
>> Hi Barry, thanks for the quick response.
>> I am using os x and so I would expect that petsc would be able to
>> use getrusage in the following lines of mem.c:
>> 115: #elif defined(PETSC_HAVE_GETRUSAGE)
>> 116:   getrusage(RUSAGE_SELF,&temp);
>> Is this not the case?
>    You can run in the debugger, put a break point at that line to
> verify it goes there and if it does check the values of temp after
> the call. (Sometimes Apple's docs are more optimistic than reality.)
>    Barry
>> Here is the link to apple's getrusage manual page
>> http://developer.apple.com/library/mac/#documentation/Darwin/Reference/ManPages/10.7/man2/getrusage.2.html
>>>   Colin,
>>>    PetscMemoryGetCurrentUsage() and MaximumUsage() us calls to the
>>>   underlying operating system to get how much memory the process
>>> is   using, as such they will also include external package
>>> memory.   Unfortunately it depends on the operating system
>>> providing this   information and often it does not, this is why
>>> you get 0. If you  are  a hacker you could look at the source for
>>>  PetscMemoryGetCurrentUsage() and see how to get the information
>>> for  your OS and add it to this routine.
>>>   Barry
>>> On May 22, 2013, at 6:31 PM, Colin McAuliffe <cjm2176 at columbia.edu> wrote:
>>>> Hi all,
>>>> When calling PetscMemoryGetCurrentUsage or
>>>> PetscMemoryGetMaximumUsage in a fortran code the memory usage
>>>> returned is always zero. Adding command line options such as
>>>> -malloc_log and -memory_info doesn't change this result. Is there
>>>>   something else I'm missing? Also, will use of these two
>>>> functions  give memory used by external packaged called by petsc?
>>>> All the best,
>>>> Colin
>>>> Colin McAuliffe
>>>> PhD Candidate
>>>> Columbia University
>>>> Department of Civil Engineering and Engineering Mechanics
>> Colin McAuliffe
>> PhD Candidate
>> Columbia University
Colin McAuliffe
PhD Candidate
Columbia University
