[petsc-users] Memory logging in fortran
Colin McAuliffe cjm2176 at columbia.edu
Wed May 22 19:06:37 CDT 2013
Hi Barry, thanks for the quick response.
I am using os x and so I would expect that petsc would be able to use
getrusage in the following lines of mem.c:
115: #elif defined(PETSC_HAVE_GETRUSAGE)
116:   getrusage(RUSAGE_SELF,&temp);
Is this not the case?
Here is the link to apple's getrusage manual page
http://developer.apple.com/library/mac/#documentation/Darwin/Reference/ManPages/10.7/man2/getrusage.2.html
Quoting Barry Smith <bsmith at mcs.anl.gov>:
>    Colin,
>     PetscMemoryGetCurrentUsage() and MaximumUsage() us calls to the
> underlying operating system to get how much memory the process is
> using, as such they will also include external package memory.
> Unfortunately it depends on the operating system providing this
> information and often it does not, this is why you get 0. If you are
>  a hacker you could look at the source for
> PetscMemoryGetCurrentUsage() and see how to get the information for
> your OS and add it to this routine.
>    Barry
> On May 22, 2013, at 6:31 PM, Colin McAuliffe <cjm2176 at columbia.edu> wrote:
>> Hi all,
>> When calling PetscMemoryGetCurrentUsage or
>> PetscMemoryGetMaximumUsage in a fortran code the memory usage
>> returned is always zero. Adding command line options such as
>> -malloc_log and -memory_info doesn't change this result. Is there
>> something else I'm missing? Also, will use of these two functions
>> give memory used by external packaged called by petsc?
>> All the best,
>> Colin
>> Colin McAuliffe
>> PhD Candidate
>> Columbia University
>> Department of Civil Engineering and Engineering Mechanics
Colin McAuliffe
PhD Candidate
Columbia University
