[petsc-users] Memory logging in fortran
Colin McAuliffe
cjm2176 at columbia.edu
Wed May 22 18:31:14 CDT 2013
Hi all,
When calling PetscMemoryGetCurrentUsage or PetscMemoryGetMaximumUsage
in a fortran code the memory usage returned is always zero. Adding
command line options such as -malloc_log and -memory_info doesn't
change this result. Is there something else I'm missing? Also, will
use of these two functions give memory used by external packaged
called by petsc?
All the best,
Colin
Colin McAuliffe
PhD Candidate
Columbia University
Department of Civil Engineering and Engineering Mechanics
