[petsc-users] 答复: 答复: 答复: 答复: 答复: 答复: 答复: 答复: 转发: PETsc problem
余浩
hao.yu at peraglobal.com
Wed May 22 18:15:33 CDT 2013
How can I just copy/paste what you wrote?
I run configure, and it shows:
cannot download--install MPICH under Windows. Suggest to install MPICH manually
Thanks!
Hao
发件人: Satish Balay [balay at mcs.anl.gov]
发送时间: 2013年5月22日 22:16
收件人: 余浩
抄送: petsc-users
主题: Re: [petsc-users] 答复: 答复: 答复: 答复: 答复: 答复: 答复: 转发: PETsc problem
On Wed, 22 May 2013, 余浩 wrote:
> Because the difference in directory, firstly, I enter in d:/Program Files/VC (in VS cmd)
> cl OK.cpp
> it shows:
> > Microsoft <R> 32-bit C/C++ Optimizing Compiler Version 16.00.30319.01 for 80X86
> > Copyright <C> Microsoft Corposration. All rights reserved.
> > OK.cpp
> > Microsoft <R> Incremental Linker Version 10.00.30319.01
> > Copyright <C> MIcrosoft Corporation. All rights reserved.
> > /out:OK.exe
> > OK.obj
> then
> echo %errorlevel%
> 0
> then, I login into cygwin in VS cmd, enter
> cd /cygdrive/d/Program\ Files/VC
> cl OK.cpp
> with exactly the same output as you wrote.
> echo $?
> 0
> then login into the directory that petsc is in:
I would have prefered a copy/paste of everything on the terminal -
instead of this type of transcribing. :(
> $ /home/petsc-3.3-p6/bin/win32fe/win32fe cl -c OK.cpp
> OK.cpp
Are you sure you didn't type some of ther command inbetween these two commands? Again a proper
copy/paste would have helped.
> $echo $?
> 0
ok [if there was no other command inbetween the above two commands]
its indicating that the compiler is ok here. Can you now try configure
form this same terminal? [but first recheck the above command's return
code]
Satish
> Thanks!
> Hao
> Hao
> 发送时间: 2013年5月21日 22:42
> 收件人: 余浩
> 抄送: petsc-users at mcs.anl.gov
> 主题: Re: [petsc-users] 答复: 答复: 答复: 答复: 答复: 答复: 转发: PETsc problem
> On Tue, 21 May 2013, 余浩 wrote:
> > I have a program OK.cpp in the directory d:/Program Files/VC/
> thats a strange location to do compiles.
> > #incldue<stdio.h>
> hm - typo?
> > int main()
> > printf("OK");
> > return 0;
> > after cl OK.cpp ,
> > OK.cpp
> > /out:OK.exe
> > OK.obj
> > Thanks!
> Please copy/paste the complete output from the following sequence of
> commands.
> Satish
> C:\cygwin\home\balay\junk>cl OK.c
> Microsoft (R) C/C++ Optimizing Compiler Version 14.00.50727.762 for x64
> Copyright (C) Microsoft Corporation. All rights reserved.
> OK.c
> Microsoft (R) Incremental Linker Version 8.00.50727.762
> /out:OK.exe
> OK.obj
> C:\cygwin\home\balay\junk>echo %errorlevel%
> 0
> C:\cygwin\home\balay\junk>c:\cygwin\bin\bash --login
> balay at msnehalem2 ~
> $ cd junk/
> balay at msnehalem2 ~/junk
> $ cl OK.c
> OK.c
> /out:OK.exe
> OK.obj
> $ echo $?
> 0
> $ ~/petsc.clone/bin/win32fe/win32fe cl -c OK.c
> OK.c
> $ echo $?
> 0
