[petsc-users] Generalized eigenvalue problem with spectral transformations and mpiaij compatible preconditioners
Jose E. Roman
jroman at dsic.upv.es
Wed May 22 15:22:30 CDT 2013
El 22/05/2013, a las 22:15, Heikki Virtanen escribió:
> Hi, I have been trying to solve a generalized eigenvalue problem using
> SLEPc's EPS object. I have tried to parallelize my solver, so I should
> use PETSc's mpiaij matrices instead of seqaij matrices.
> Unfortunately, PETSc's LU preconditioner does not support MPI matrices.
> (this is said in the manual and if I use it with mpiaij matrices I
> get an error message) I get the eigenvalue problem solved with
> LU preconditioner and seqaij matrices but, I also have to use a
> spectral transformation ( shift-invert ) to improve convergence.
> But, as I mentioned before I cannot use LU preconditioner with mpiaij
> matrices. Thus, I have changed preconditioner to Hypre's BoomerAMG,
> for example. ( which supports mpiaij matrices ) When I use this
> combination ( BoomerAMG/shift-invert transformation/
> Krylov-Schur solver) I get an early convergence failure after a couple
> of iterations. I have also tried other solvers and preconditioners,
> (Hypre's pilut, euclid, bjacobi and Jacobi-Davidson solver) but the result is
> the same. Without any preconditioner I also get the early convergence
> failure and without the spectral transformation convergence is
> too slow. Any comments or suggestions?
> -Heikki
Try a parallel LU such as MUMPS. This is mentioned in the manual.
Jose
