[petsc-users] Set the options NOT from argc and argv
Tue May 21 16:17:55 CDT 2013
On Tue, 21 May 2013, Satish Balay wrote:
> You should be able to use 'petscrc' file as mentioned before. [without
> any code changes]
> Alternative is to call fortran initialize/finalize from your c code -
> but this is a bit convoluted.. [but appears to work for me]
Or you can do the following... by having a fortran intermediate file..
Satish
balay at asterix /home/balay/download-pine
$ cat main.F
      program main
      call wrap()
      end
$ cat wrap.F
      subroutine wrap()
      implicit none
#include <finclude/petsc.h>
      PetscErrorCode ierr
      call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
      call foo()
      call PetscFinalize(ierr)
      end
$ cat sub.c
#include <petsc.h>
#if defined(PETSC_HAVE_FORTRAN_CAPS)
#define foo_             FOO
#elif !defined(PETSC_HAVE_FORTRAN_UNDERSCORE)
#define foo_             foo
#endif
void foo_(void)
  /* petsc code */
  return;
