[petsc-users] Set the options NOT from argc and argv
Longxiang Chen suifengls at gmail.com
Tue May 21 15:33:13 CDT 2013
Here is an example:
I only have a function written in C(and it is called in fortran, I cannot
change fortran code):
PetscInitialize() is called in C function.
void P_solve(A, b, x, size)
   // definition and declaration
  PetscInitialize();
  // petsc KSP functions
I use PetscOptionsSetValue() to set the options. But need to compile it
every time I change options, I would fix it in the end.
Could I get the command line options in this situation? Like petscrc in
fortran for this C function?
Best regards,
Longxiang Chen
Do something every day that gets you closer to being done.
465 Winston Chung Hall
Computer Science Engineering
University of California, Riverside
On Tue, May 21, 2013 at 7:48 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> If PetscInitialize() is called from fortran - command line should work.
> An easy alternative is to have a file 'petscrc' in the executable run
> dir - with the command line options listed [one option per line]
> Satish
> On Tue, 21 May 2013, Matthew Knepley wrote:
> > On Mon, May 20, 2013 at 11:01 PM, Longxiang Chen <suifengls at gmail.com
> >wrote:
> > > The fortran program is too long (several files with more than 10,000
> > > lines).
> > > And I just want to insert the P_solve inside one of the subroutine to
> > > solve Ax=b.
> > > Or it can only use argc and argv?
> > Barry is correct that you can use PetscOptionsSetValue(), however I think
> > you are
> > still missing the point.
> > Command line options are processed in PetscInitialize(). You do not have
> to
> > do anything
> > else. You do not have to change your huge Fortran code. You just use the
> > command line.
> > It is much better than hard coding a solver type since you can use ALL
> > solver types. There
> > is no reason not to use it.
> >   Thanks,
> >      Matt
> > > Thanks.
> > > Longxiang
> > > Best regards,
> > > Longxiang Chen
> > > On Mon, May 20, 2013 at 8:52 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > >> On May 20, 2013, at 10:38 PM, Longxiang Chen <suifengls at gmail.com>
> wrote:
> > >> > To whom it may concern,
> > >> > I am using KSP to solve Ax=b.
> > >> > The main() is in Fortran, and it calls a function I write in C.The
> > >> parameter is array A, x, b.
> > >> > void P_solve(double x[ ], double b[ ], double A[ ], int size);
> > >> > In the function, I should call PetscInitialize() before I create the
> > >> matrix and vectors for A, x, b, and also call MatSetFromOptions() and
> > >> VecSetFromOptions().
> > >> > But I don't have the argc and argv from main function.
> > >>     If Fortran is the main program the options database still has
> access
> > >> to the command line arguments. You should still be able to use
> command line
> > >> arguments and not need to set them in the program.
> > >>      Does this not work? Can you send a sample program where it does
> not
> > >> work?
> > >>    Barry
> > >> > I just want to fix the KSP type to bcgs and the PC type.
> > >> > Is there another way that I can set the options not through argc and
> > >> argv, just set them in the program.
> > >> > e.g. options[] = {"-ksp_type", "bcgs"}.
> > >> > Thanks,
> > >> > Longxiang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130521/e21a2607/attachment.html>
