[petsc-users] How to use PETSc preconditioners in SLEPc?
Heikki Virtanen
heikki.a.virtanen at hotmail.com
Tue May 21 12:18:10 CDT 2013
Thanks! If there is a way to avoid command line options,
it would be excellent. Sorry, that I didn't remember to
mention this one. Your example has command line options
"st_ksp_type","st_pc_type","st_pc_hypre_type"
Do they have an equivalent function calls?
-Heikki
> > Hi, I try to solve eigenvalue problem using EPS object
> > and Krylov-Schur solver. Everything goes well and I
> > can solve the problems that I want.
> > Anyway, I want to use other preconditioners than the
> > default preconditioner. It is a little bit unclear for
> > me how to do this. For example, I have installed
> > PETSc with Hypre. How can use BoomerAMG preconditioner
> > instead of ILU? ( SLEPc chooses this by default )
> > -Heikki
> Have a look at section 3.4.1 of SLEPc's users guide. For instance, you can try something like this:
> $ ./program -st_ksp_type bcgs -st_pc_type hypre -st_pc_hypre_type boomeramg
> Jose
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130521/43763e00/attachment.html>
