[petsc-users] 答复: 答复: 答复: 答复: 答复: 转发: PETsc problem
Matthew Knepley
knepley at gmail.com
Tue May 21 05:44:06 CDT 2013
On Tue, May 21, 2013 at 4:52 AM, 余浩 <hao.yu at peraglobal.com> wrote:
> It still has problem. I open VS2010 cmd, then login in bash, then
> configure following the instruction, it shows "if you use batch system, you
> should ./configure --with-batch. otherwise, the complier has some
> problem...." But cl really works.
Please show us an example of your cl working from the command line. This
means
a) Open a command shell
b) Create a simple program, just an empty main()
c) Compile it with cl
d) Mail us the program and all the output from this to
petsc-maint at mcs.anl.gov
Matt
> Thanks!
> Hao
> 发件人: Satish Balay [balay at mcs.anl.gov]
> 发送时间: 2013年5月20日 23:23
> 收件人: 余浩
> 抄送: petsc-users at mcs.anl.gov
> 主题: Re: [petsc-users] 答复: 答复: 答复: 答复: 转发: PETsc problem
> On Mon, 20 May 2013, 余浩 wrote:
> > I can use cl to compile file under Windows. But even if I include path
> which cl is in in the enviromental variable of Cygwin, it still shows
> "Win32fe cl" does not work.
> Have you checked the windows installation instructions?
> https://www.mcs.anl.gov/petsc/documentation/installation.html#windows
> You should start the 'compiler cmd' - and then run 'bash --login' inside it
> [and not 'set cygwin path to include cl']
> Satish
> > The attached is the configure.log and make.log
> > Thanks!
> > Hao
> > 发件人: Matthew Knepley [knepley at gmail.com]
> > 发送时间: 2013年5月11日 4:32
> > 收件人: 余浩; petsc-users at mcs.anl.gov
> > 主题: Re: 答复: [petsc-users] 答复: 答复: 转发: PETsc problem
> > On Fri, May 10, 2013 at 12:11 PM, 余浩 <hao.yu at peraglobal.com<mailto:
> hao.yu at peraglobal.com>> wrote:
> > What do you mean by compiling something with it ? I don't know. you mean
> 'win32fe cl' is not installed correctly?
> > I mean, can you compile a file using cl from the command line?
> > Matt
> > Hao
> > 发件人: Matthew Knepley [knepley at gmail.com<mailto:knepley at gmail.com>]
> > 发送时间: 2013年5月10日 19:55
> > 收件人: 余浩
> > 抄送: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
> > 主题: Re: [petsc-users] 答复: 答复: 转发: PETsc problem
> > On Fri, May 10, 2013 at 6:20 AM, 余浩 <hao.yu at peraglobal.com<mailto:
> > The configure.log and make.log are attached.
> > it shows that 'win32fe cl' does not work. I dont' know what the problem
> is.
> > Can you compile something with it? It looks like it is not installed
> correctly.
> > Matt
> > Thanks!
> > Hao
> > 发件人: Jed Brown [five9a2 at gmail.com<mailto:five9a2 at gmail.com>] 代表 Jed
> Brown [jedbrown at mcs.anl.gov<mailto:jedbrown at mcs.anl.gov>]
> > 发送时间: 2013年5月10日 15:16
> > 主题: Re: [petsc-users] 答复: 转发: PETsc problem
> > 余浩 <hao.yu at peraglobal.com<mailto:hao.yu at peraglobal.com>> writes:
> problem is.
> > You couldn't have found a less helpful way to report this.
> > Note the bold part:
> > http://www.mcs.anl.gov/petsc/documentation/bugreporting.html
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130521/0fb435b8/attachment.html>
