[petsc-users] h-FGMRES
Gaetan Kenway
gaetank at gmail.com
Mon May 20 08:26:48 CDT 2013
Hi again
I installed petsc3.4.0 and I am still getting the following error when
running with the following options (on 64 procs)
# Matrix Options
-matload_block_size 5 -mat_type mpibaij
# KSP solver options
-ksp_type fgmres -ksp_max_it 1000 -ksp_gmres_restart 200 -ksp_monitor
-ksp_view -ksp_pc_side right -ksp_rtol 1e-6
# Nested GMRES Options
-pc_type bjacobi -pc_bjacobi_blocks 4 -sub_ksp_type gmres -sub_ksp_max_it 5
-sub_pc_type bjacobi -sub_sub_pc_type ilu
-sub_sub_pc_factor_mat_ordering_type rcm -sub_sub_pc_factor_levels 1
Any thoughts?
Thank you,
Gaetan
[44]PETSC ERROR:
[44]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[44]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[44]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[44]PETSCERROR:
or try
http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
corruption errors
[44]PETSC ERROR: likely location of problem given in stack below
[44]PETSC ERROR: --------------------- Stack Frames
[44]PETSC ERROR: Note: The EXACT line numbers in the stack are not
available,
[44]PETSC ERROR: INSTEAD the line number of the start of the function
[44]PETSC ERROR: is given.
[44]PETSC ERROR: [44] PCSetUp_BJacobi_Multiproc line 1197
/home/j/jmartins/kenway/packages/petsc-3.4.0/src/ksp/pc/impls/bjacobi/bjacobi.c
[44]PETSC ERROR: [44] PCSetUp_BJacobi line 24
[44]PETSC ERROR: [44] PCSetUp line 868
/home/j/jmartins/kenway/packages/petsc-3.4.0/src/ksp/pc/interface/precon.c
[44]PETSC ERROR: [44] KSPSetUp line 192
/home/j/jmartins/kenway/packages/petsc-3.4.0/src/ksp/ksp/interface/itfunc.c
[44]PETSC ERROR: [44] KSPSolve line 356
[43]PETSC ERROR:
On Sun, May 19, 2013 at 11:15 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> You should be using PETSc version 3.4 which was recently released and
> is what the paper is based on.
> Barry
> On May 19, 2013, at 10:11 PM, Gaetan Kenway <gaetank at gmail.com> wrote:
> > Hi Everyone
> > I am trying to replicate the type of preconditioner described in
> "Hierarchical and Nested Krylov Methods for Extreme-Scale Computing".
> > I have used the following options: (I'm using fortran so the following
> is my petsc_options file)
> > # Matrix Options
> > -mat_type mpibaij
> > -ksp_type gmres
> > -ksp_max_it 1000
> > -ksp_monitor
> > -ksp_view
> > -ksp_pc_side right
> > -ksp_rtol 1e-6
> > -pc_type bjacobi
> > -sub_ksp_type gmres
> > -sub_ksp_max_it 5
> > The test is run on 64 processors and the total number of block jacobi
> blocks is 4 (less than nproc). The error I get is:
> > [6]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> > [6]PETSC ERROR: INSTEAD the line number of the start of the
> function
> > [6]PETSC ERROR: is given.
> > [6]PETSC ERROR: [6] PCSetUp_BJacobi_Multiproc line 1269
> /home/j/jmartins/kenway/packages/petsc-3.3-p5/src/ksp/pc/impls/bjacobi/bjacobi.c
> > [6]PETSC ERROR: [6] PCSetUp_BJacobi line 24
> > [6]PETSC ERROR: [6] PCSetUp line 810
> /home/j/jmartins/kenway/packages/petsc-3.3-p5/src/ksp/pc/interface/precon.c
> > [6]PETSC ERROR: [6] KSPSetUp line 182
> /home/j/jmartins/kenway/packages/petsc-3.3-p5/src/ksp/ksp/interface/itfunc.c
> > [6]PETSC ERROR: [6] KSPSolve line 351
> > [6]PETSC ERROR: --------------------- Error Message
> > [6]PETSC ERROR: Signal received!
> > [6]PETSC ERROR:
> > [6]PETSC ERROR: Petsc Release Version 3.3.0, Patch 5, Sat Dec 1
> 15:10:41 CST 2012
> > [6]PETSC ERROR: See docs/changes/index.html for recent updates.
> > [6]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > [6]PETSC ERROR:
> > [6]PETSC ERROR:
> > [6]PETSC ERROR: ./main on a intel-rea named gpc-f109n001 by kenway Sun
> May 19 23:01:52 2013
> > [6]PETSC ERROR: Libraries linked from
> /home/j/jmartins/kenway/packages/petsc-3.3-p5/intel-real-debug/lib
> > [6]PETSC ERROR: Configure run at Sun Jan 20 15:52:20 2013
> > [6]PETSC ERROR: Configure options --with-shared-libraries
> --download-superlu_dist=yes --download-parmetis=yes --download-metis=yes
> --with-fortran-interfaces=1 --with-debugging=yes --with-scalar-type=real
> -with-petsc-arch=intel-real-debug --with-blas-lapack-dir= --with-pic
> > [6]PETSC ERROR:
> > If the number of blocks is greater than or equal to the number of
> processors it runs fine. I'm using version 3.3-p5.
> > The options as listed in the paper are:
> > -flow_ksp_type fgmres -flow_ksp_pc_side right -flow_pc_type bjacobi
> -flow_pc_bjacobi_blocks ngp
> > -flow_sub_ksp_type gmres -flow_sub_ksp_max_it 6 -flow_sub_pc_type bjacobi
> > -flow_sub_sub_pc_type ilu
> > Any suggestions would be greatly appreciated.
> > Thank you,
> > Gaetan Kenway
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130520/9d2e4d18/attachment.html>
