[petsc-users] 3-dimension to matrix
Joon hee Choi
choi240 at purdue.edu
Fri May 17 21:28:59 CDT 2013
Thank you for your reply. Yes. I think so now. If I have slow result in spite of applying MatCreateAIJ, then I reply it again. Thank you very much again.
Sincerely,
Joon
----- Original Message -----
To: "Peter Lichtner" <peter.lichtner at gmail.com>, petsc-users at mcs.anl.gov
Sent: Friday, May 17, 2013 5:05:12 PM
Subject: Re: [petsc-users] 3-dimension to matrix
Peter Lichtner <peter.lichtner at gmail.com> writes:
> I found a similar problem solving Laplace's equation: using MatCreate
> took forever, whereas using MatCreateAIJ instead the time for
> MatSetValues was essentially negligible. I set up MatCreate with a
> call to MatSetSizes.
This is almost certainly caused by bad preallocation information, or
from that information not being used. The complete implementation of
MatCreateAIJ is:
PetscErrorCode MatCreateAIJ(MPI_Comm comm,PetscInt m,PetscInt n,PetscInt M,PetscInt N,PetscInt d_nz,const PetscInt d_nnz[],PetscInt o_nz,const PetscInt o_nnz[],Mat *A)
PetscErrorCode ierr;
PetscMPIInt size;
PetscFunctionBegin;
ierr = MatCreate(comm,A);CHKERRQ(ierr);
ierr = MatSetSizes(*A,m,n,M,N);CHKERRQ(ierr);
ierr = MPI_Comm_size(comm,&size);CHKERRQ(ierr);
if (size > 1) {
ierr = MatSetType(*A,MATMPIAIJ);CHKERRQ(ierr);
ierr = MatMPIAIJSetPreallocation(*A,d_nz,d_nnz,o_nz,o_nnz);CHKERRQ(ierr);
} else {
ierr = MatSetType(*A,MATSEQAIJ);CHKERRQ(ierr);
ierr = MatSeqAIJSetPreallocation(*A,d_nz,d_nnz);CHKERRQ(ierr);
PetscFunctionReturn(0);
