[petsc-users] 3-dimension to matrix
Joon hee Choi
choi240 at purdue.edu
Fri May 17 21:16:01 CDT 2013
Thank you for your reply.
I will calculate the multiplication of block matrices. I made the vector with tuples from dataset and then set up the matrix by reading each tuple.
And the matrix has 144*10^6 non-zero entries.
Sincerely,
Joon
----- Original Message -----
To: "Joon hee Choi" <choi240 at purdue.edu>
Cc: petsc-users at mcs.anl.gov
Sent: Friday, May 17, 2013 4:48:28 PM
Subject: Re: [petsc-users] 3-dimension to matrix
Joon hee Choi <choi240 at purdue.edu> writes:
> My petsc version is 3.3.5.
> And I made nnz using the number of each row. When I wrote the matrix
> using MatSetValues, I wrote from low row and column to high row and
> column. However, when I changed the order writing the matrix, it took
> much more time (up to 3hrs). So I am concerned that the slowness is
> because the big size of matrix (2.6*10^7, 1.248*10^15) is related to
> reading from or writing to the cache, ram, or hard.
What are you going to do with a matrix of that dimension? You can't
apply it to a vector because you can't store the vector.
How many entries does it have?
> Anyway, the following code is the part that I read the data from a
> file and set up tuples and nnz:
> FILE *fp = fopen("data.txt", "r");
> while (fscanf(fp, "%d %d %d %d", &x, &y, &z, &v) == 4)
> tups.push_back(std::tr1::make_tuple (x-1, z-1, y-1, v));
> nzrow[i-1] += 1;
> if (x > X) X = x;
> if (y > Y) Y = y;
> if (z > Z) Z = z;
> fclose(fp);
> PetscMalloc(X*sizeof(PetscInt), &nnz);
> memset(nnz, 0, X);
> for (itnz=nzrow.begin(); itnz!=nzrow.end(); ++itnz) {
> nnz[itnz->first] = itnz->second;
What is this trying to do? nnz will just be the column of the last
point to be processed...
> sort(tups.begin(), tups.end());
> If my code is wrong, then please let me know.
> Thank you,
> Joon
> From: "Jed Brown" <jedbrown at mcs.anl.gov>
> Sent: Friday, May 17, 2013 3:24:09 PM
>> Thank you for your fast reply. Your last comments looks like my first
>> code. The full size of the matrix is (X, Y*Z). Also, I used SEQAIJ as
>> matrix type and (X, Y) as block size. Also, I implemented
>> SeqAIJpreallocating with nnz. Nevertheless, it was very slow. The
>> Matrix-Set-Up part of the first code is as follows:
>> MatCreate(PETSC_COMM_SELF, &A);
>> MatSetType(A, MATSEQAIJ);
>> MatSetSizes(A, PETSC_DECIDE, PETSC_DECIDE, X, Y*Z);
>> MatSetBlockSizes(A, X, Y);
>> MatSeqAIJSetPreallocation(A, PETSC_DEFAULT, nnz);
>> sz = tups.size();
>> for (i=0; i<sz; i++) {
>> x = std::tr1::get<0>(tups[i]);
>> y = std::tr1::get<2>(tups[i]) + std::tr1::get<1>(tups[i])*Y;
>> val = std::tr1::get<3>(tups[i]);
>> MatSetValues(A, 1, &x, 1, &y, &val, INSERT_VALUES);
>> MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
>> MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
>> I used tuple (x, z, y, value) and vector of c++. I didn't get any
>> errors from this code. However, it took about 9 minutes in this
>> part.
> What version of PETSc? Your preallocation was almost certainly not
> sufficient.
