[petsc-users] Solving Poisson equation with multigrid
Fri May 17 16:16:06 CDT 2013
Michele Rosso <mrosso at uci.edu> writes:
> Thank you.
> I will ask to update to 3.4 but I am working on a supercomputer thus I
> do not have control on the installed software.
You can install in your $HOME.
> So you suggest to use conjugate gradient + multigrid as preconditioner,
> correct?
Yes
> If so, I retain
> -ksp_type cg
> instead of
> -ksp_type richardson
> correct?
Yes
