[petsc-users] petsc 3.4:
Wed May 15 09:32:34 CDT 2013
On Wed, 15 May 2013, Lisandro Dalcin wrote:
> >> On 15 May 2013 16:54, Satish Balay <balay at mcs.anl.gov> wrote:
> >> > On Wed, 15 May 2013, Matteo Parsani wrote:
> >> >> Hello Satish,
> >> >> Lisandro has found that in the make file we have
> >> >> include ././${PETSC_ARCH}/conf/petscvariables
> >> > we try to support too many ways of installing petsc [with prefix/
> >> > without prefix, with a defaut PETSC_ARCH, without PETSC_DIR set etc..]
> >> > And we need this line for users who forget to set PETSC_ARCH in a
> >> > non-prefix build. [to pick up a defaut PETSC_ARCH]
> >> Satish, I think all what is needed is to fix a little the test_build
> >> target. Basically, test if the file under PETSC_ARCH exists, otherwise
> >> use PETSC_DIR/include/petscconf.h . Perhpas I'm missing something, but
> >> this should be near to work.
> > We've avoided using gnu make extensions - so there is no usage of 'if'
> > directives in petsc makefiles. [and we've used include directive as
> > alternative]
> I was not clear enough. I'm talking about a shell "if", something like
> if [-f ${PETSC_DIR}/${PETSC_ARCH}/include/petscconf.h]; then \
>    egrep ...
> else
>    egrep ....
> fi
Sure - I was hoping for a: 'if [ "${PREFIX}" = "" ]' - but currently
configure doesn't appear so set such a thing. We could add that - or
just use the if statement of petscconf.h as you suggest.
Satish
diff --git a/makefile b/makefile
index 372e593..9bc5cfb 100644
--- a/makefile
+++ b/makefile
@@ -138,7 +138,11 @@ test_build:
        @cd src/snes/examples/tutorials >/dev/null; ${OMAKE} PETSC_ARCH=${PETSC_ARCH}  PETSC_DIR=${PETSC_DIR} clean
        @cd src/snes/examples/tutorials >/dev/null; ${OMAKE} PETSC_ARCH=${PETSC_ARCH}  PETSC_DIR=${PETSC_DIR} testex19
        @if [ "${FC}" != "" ]; then \
-          egrep "^#define PETSC_USE_FORTRAN_DATATYPES 1" ${PETSC_DIR}/${PETSC_ARCH}/include/petscconf.h | tee .ftn-dtype.log > /dev/null; \
+          if [ -f ${PETSC_DIR}/${PETSC_ARCH}/include/petscconf.h ]; then \
+            egrep "^#define PETSC_USE_FORTRAN_DATATYPES 1" ${PETSC_DIR}/${PETSC_ARCH}/include/petscconf.h | tee .ftn-dtype.log > /dev/null; \
+          else \
+            egrep "^#define PETSC_USE_FORTRAN_DATATYPES 1" ${PETSC_DIR}/include/petscconf.h | tee .ftn-dtype.log > /dev/null; \
+          fi; \
           if test -s .ftn-dtype.log; then F90TEST="testex5f90t"; else F90TEST="testex5f"; fi; ${RM} .ftn-dtype.log; \
           cd src/snes/examples/tutorials >/dev/null; ${OMAKE} PETSC_ARCH=${PETSC_ARCH}  PETSC_DIR=${PETSC_DIR} $${F90TEST}; \
          fi;
