[petsc-users] petsc 3.4:
Lisandro Dalcin
dalcinl at gmail.com
Wed May 15 09:00:06 CDT 2013
On 15 May 2013 16:54, Satish Balay <balay at mcs.anl.gov> wrote:
> On Wed, 15 May 2013, Matteo Parsani wrote:
>> Hello Satish,
>> Lisandro has found that in the make file we have
>> include ././${PETSC_ARCH}/conf/petscvariables
> we try to support too many ways of installing petsc [with prefix/
> without prefix, with a defaut PETSC_ARCH, without PETSC_DIR set etc..]
> And we need this line for users who forget to set PETSC_ARCH in a
> non-prefix build. [to pick up a defaut PETSC_ARCH]
Satish, I think all what is needed is to fix a little the test_build
target. Basically, test if the file under PETSC_ARCH exists, otherwise
use PETSC_DIR/include/petscconf.h . Perhpas I'm missing something, but
this should be near to work.
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
