[petsc-users] Does MUMPS check the nonzero pattern for each iteration?
Santos Teixeira Frederico fsantost at student.ethz.ch
Fri May 10 04:55:00 CDT 2013
I am using PETSc with MUMPS and based on the time required for each iteraction (it is almost the same amount of time), I suspect MUMPS is not using the information about the nonzero pattern.
My question is: how do I make sure it is correctly configured? I am already setting "KSPSetOperators(ksp, A, A, SAME_NONZERO_PATTERN)".
Thanks in advance for any tip!
 Frederico.
