[petsc-users] plexvtk viewer
Dharmendar Reddy dharmareddy84 at gmail.com
Thu May 9 11:11:02 CDT 2013
Hello,
         I am getting an error, when i try to vec view for dofs defined on
nodes and cell centers.  I find this error massage strange, i am the dofs
belong to different fields, why is it considered a mixed type object? It
works if us fileds with only nodal or only cell dofs
Is it possible to support a case wehre i have few fields which are differed
on nodes, and few which are defined on cell (this are usually auxiliary
variables providing information such as material parameters). Attached a
test case
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: No support for this operation for this object type!
[0]PETSC ERROR: No support for viewing mixed space with dofs at both
vertices an
d cells!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Development GIT revision:
ba3d6699fe16b82fc53230ec60dd42b2
a6c4d965  GIT Date: 2013-05-09 07:57:34 -0500
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./testDMView on a mpi_rScalar_Debug named
login1.stampede.tacc.u
texas.edu by Reddy135 Thu May  9 11:04:50 2013
[0]PETSC ERROR: Libraries linked from
/home1/00924/Reddy135/LocalApps/petsc/mpi_
rScalar_Debug/lib
[0]PETSC ERROR: Configure run at Thu May  9 08:52:27 2013
[0]PETSC ERROR: Configure options   --download-blacs=1 --download-ctetgen=1
--do
wnload-metis=1 --download-mumps=1 --download-parmetis=1
--download-scalapack=1 -
-download-superlu_dist=1 --download-triangle=1 --download-umfpack=1
--with-blas-
lapack-dir=/opt/apps/intel/13/composer_xe_2013.2.146/mkl/lib/intel64/
--with-deb
ugging=1 --with-mpi-dir=/opt/apps/intel13/mvapich2/1.9/
--with-petsc-arch=mpi_rS
calar_Debug --with-petsc-dir=/home1/00924/Reddy135/LocalApps/petsc
PETSC_ARCH=mp
i_rScalar_Debug
[0]PETSC ERROR:
[0]PETSC ERROR: VecView_Plex_Local() line 42 in
petsc/src/dm/impls/plex/plex.c
[0]PETSC ERROR: VecView() line 706 in
/home1/00924/Reddy135/LocalApps/petsc/src/
vec/vec/interface/vector.c
login1$
Dharmendar Reddy Palle
Graduate Student
Microelectronics Research center,
University of Texas at Austin,
10100 Burnet Road, Bldg. 160
MER 2.608F, TX 78758-4445
e-mail: dharmareddy84 at gmail.com
Phone: +1-512-350-9082
United States of America.
Homepage: https://webspace.utexas.edu/~dpr342
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130509/e5d14713/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130509/e5d14713/attachment.obj>
