[petsc-users] 转发: PETsc problem
余浩
hao.yu at peraglobal.com
Thu May 9 10:20:55 CDT 2013
Thanks!
so what can I do to compile if I want to use PETsc in VS2010?
I have tried using g++:
./configure --with-cxx=g++ --with-fc=0 --download-f2blaslapck --download-mpich
then
make PETSC_ARCH=arch-mswin-cxx-debug all
make PETSC_ARCH=arch-mswin-cxx-debug test
it shows:
Using PETSC_DIR=/petsc-3.3-p6 and PETSC_ARCH=arch-mswin-cxx-debug
/usr/bin/sh: line 20: 10916 Segmentation fault " some path here"(I omitted)
Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI process
See http://www.mcs.anlgov/petsc/documentation/faq.html
/usr/bin/sh: line 20: 11780 Segmentation fault "some path here"(I omitted)
Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2 MPI processes
See http://www.mcs.anl.gov/petsc/documentation/faq.html
Completed test examples
Hao
发件人: Jed Brown [five9a2 at gmail.com] 代表 Jed Brown [jedbrown at mcs.anl.gov]
发送时间: 2013年5月9日 21:15
收件人: 余浩
主题: Re: PETsc problem
余浩 <hao.yu at peraglobal.com> writes:
> Dear Jed Brown,
> I am sorry to trouble you! I am a PhD in math dept. at U of Minnesota,
> currently using PETsc. I have a problem , it can't successfully
> compile in VS2010 after installation. Because I am using Windows, so
> under cygwin, I use:
> ./configure --with-cc=gcc -with-fc=0 --download-f2blaslapck
> --download-mpich make all test
You can't mix gcc here and VS2010 later because they are not compatible.
> then it completes, but after I include , for example, "petscksp.h",
> the error message after compling:
> Error 4 error C3861: '__builtin_expect': identifier not found
> e:\cygwin\home\petsc-3.3-p6\include\petsclog.h 332 1 HelloFluids2
Configure tests whether the compiler supports __builtin_expect. There
are probably many other incompatibilities.
If you have any further questions, please send email to either
petsc-users at mcs.anl.gov or petsc-maint at mcs.anl.gov.
