[petsc-users] CG or GMRES
Zhenglun (Alan) Wei
zhenglun.wei at gmail.com
Wed May 8 18:26:44 CDT 2013
Dear folks,
I hope you're having a nice day.
For the Poisson solver in /src/ksp/ksp/example/tutorial/ex45.c, I used
the ksp_type = CG to solve it before; it converges very fast with
pc_type = gamg. However, I was trying to check if the matrix generated
by the 'ComputeMatrix' is symmetric by using "ierr = MatIsSymmetric(B,
tol, &flg);". It shows that this matrix is not exact a symmetric one by
setting tol = 0.0. Yet, the matrix is 'symmetric' if the tol > 0.01.
Does this mean that, even if the matrix is not exact symmetric, the CG
could still be used. This brings me a question. Can the CG be used to
solve an actual unsymmetric matrix as long as 'MatIsSymmetric' returns a
'PETSC_TRUE' value with certain tolerance. Is there any rule of thumb
for this tolerence?
Also, as a preconditioner, does 'gamg' only work for symmetric
positive-definite matrix? or it works for any matrix or even with GMRES?
thanks,
Alan
