[petsc-users] How to assemble a sparse SPD matrix in parallel
Jed Brown
jedbrown at mcs.anl.gov
Tue May 7 08:36:49 CDT 2013
Thomas Ponweiser <Thomas.Ponweiser at risc-software.at> writes:
> Dear PETSc community!
> I would like to read in a (large) sparse SPD matrix from a file in parallel. More precisely my plan was to do the following:
> 1) Read matrix size N from file.
> 2) Create PETSc matrix.
> 3) Set option MAT_SPD=PETSC_TRUE.
> 4) Set global size N x N, local sizes PETSC_DECIDE.
> 5) Read in only those rows from file, which are owned by the local process.
> 6) Preallocate the matrix using statistics collected in the previous step.
> 7) Insert the values read into the matrix row-by-row.
> 8) Begin and finish matrix assembly.
> My problem is in step 5, leading to 3 questions:
> QUESTION 1: How can I let PETSc decide, which rows of the global
> matrix will be local to the process BEFORE prealloction?
> In the manual pages I have found so far:
> A) MatGetOwnershipRange():
> "requires that the matrix be preallocated".
> B) MatGetOwnershipRanges():
> "Not collective, unless matrix has not been allocated, then collective on Mat"
> However, when running the program, I get the error message: "Must call MatXXXSetPreallocation() or MatSetUp() ... before MatGetOwnershipRanges()!"
> QUESTION 2: Is the documentation of MatGetOwnershipRanges() incorrect or am I misinterpreting it?
> -> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetOwnershipRanges.html
> I finally got the program running by calling MatSetUp() before
> MatGetOwnershipRange(). Still I cannot fight the feeling that I am
> doing things not as they have been intended by the developers, since
> preallocation is now done twice.
You should use PetscSplitOwnership(). We couldn't do anything more
intelligent anyway without because such would be necessarily
matrix-dependent.
> The alternative seems to be to use PetscSplitOwnership() and
> MPI_Scan() to calculate the row ranges for each process before
> creating the matrix with MatCreate(). But this leads in any case to a
> very even distribution of row counts among the processes. Assuming
> that only the upper triangular part of the symmetric matrix needs to
> be stored (IS THIS CORRECT?), I would guess that consequently this
> leads to an imbalance regarding the number of (nonzero) matrix entries
> owned by each process (Processes with higher rank will own fewer
> nonzeros).
> QUESTION 3: For SPD matrices, is it in general a good strategy to have
> every process owning approximately the same number of rows? (In this
> case, I can of course forget about PetscSplitOwnership() and
> MPI_Scan() and do the distribution myself).
Yes, but this only affects the off-diagonal part (which involves
communication). For most mesh-based problems, the size of the
off-diagonal part is basically the same size for all processes except
those on the trailing boundary. It's not a problem to have many
balanced ranks and a few "light" ones.
