[petsc-users] question on MatSubMatrixUpdate
Shaohao Chen
shchen at www.phys.lsu.edu
Mon May 6 16:00:53 CDT 2013
Dear managers and users,
I got a problem when using PETSc to make parallel codes. Could you please help me out?
Basically, I need to do is to update the values of some blocks of a large matrix (not the whole matrix),
and I need to do it many times in a big loop. These blocks could be assembled to the same or
different processors. If using "MatSetValues", it would spend much time for the data transfer between
different processors. I expect "MatSubMatrixUpdate" could do the job better. Am I correct? But I can
not find an example of using "MatSubMatrixUpdate" on the website. It is said that the
"MatSubMatrixUpdate" is only in a "developer" level and the users should use some other functions to
replace it. What other functions should I use?
Thank you for your attention!
Shaohao Chen
Department of Physics & Astronomy,
Louisiana State University,
Baton Rouge, LA
