[petsc-users] slepc build fails..
Dharmendar Reddy dharmareddy84 at gmail.com
Mon May 6 09:49:43 CDT 2013
On Mon, May 6, 2013 at 8:28 AM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> El 05/05/2013, a las 09:30, Dharmendar Reddy escribió:
> > On Sun, May 5, 2013 at 1:06 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > Dharmendar Reddy <dharmareddy84 at gmail.com> writes:
> > > Hello,
> > >          I am getting an error when i try to build slepc.
> > > I first see:
> > >       CMake setup incomplete (status 256), falling back to legacy
> > > build
> > This problem, which is definitely a CMake bug (but they seem to have no
> > plans to fix), is usually related to NOTFOUND cache entries:
> >   //Path to a library.
> >   -LARPACKLIB:FILEPATH=-LARPACKLIB-NOTFOUND
> > This is probably constructed by joining an empty variable.  Jose may
> > know where in the SLEPc CMake code to look for this occurring.
> > > then make all gives an error, look at the attached logs
> > Does 'make test' work?  What about after 'make allfortranstubs all'?
> >    Make test works.
> >   login4$ make SLEPC_DIR=$PWD
> PETSC_DIR=/home1/00924/Reddy135/LocalApps/petsc PETSC_ARCH=mp
> > i_rScalar_Opt test
> > Running test examples to verify correct installation
> > Using SLEPC_DIR=/home1/00924/Reddy135/LocalApps/slepc,
> > alApps/petsc and PETSC_ARCH=mpi_rScalar_Opt
> > C/C++ example src/eps/examples/tests/test10 run successfully with 1 MPI
> process
> > C/C++ example src/eps/examples/tests/test10 run successfully with 2 MPI
> process
> > Fortran example src/eps/examples/tests/test7f run successfully with 1
> MPI process
> > Completed test examples
> >  But
> >  fails..
> > grep: ftn-auto/makefile: No such file or directory
> > libfast in:
> /home1/00924/Reddy135/LocalApps/slepc/include/finclude/ftn-auto
> > make[5]: *** No rule to make target `slepc_tree'.  Stop.
> > libfast in:
> /home1/00924/Reddy135/LocalApps/slepc/include/finclude/ftn-custom
> > libfast in: /home1/00924/Reddy135/LocalApps/slepc/include/slepc-private
> > libfast in: /home1/00924/Reddy135/LocalApps/slepc/docs
> > Completed building libraries
> > making shared libraries in
> /home1/00924/Reddy135/LocalApps/slepc/mpi_rScalar_Opt/lib
> > building libslepc.so
> > *******************************ERROR************************************
> >   Error during compile, check mpi_rScalar_Opt/conf/make.log
> >   Send all contents of mpi_rScalar_Opt/conf to slepc-maint at grycap.upv.es
> > Now, i am wondering why i get these errors now ? i had no issues with
> slepc until i did git pull on petsc today. petsc does compile and pass
> tests. ?
> > I am using slepc-dev -rev 3324
> > Thanks
> > Reddy
> You should be using petsc-master since slepc-dev is in sync with
> petsc-master, not petsc-next.
> Anyway, I think the problem is the arpack-flags option, it should be like
> this (with a comma, as in the example of the manual):
> $ ./configure --with-arpack-dir=/home1/00924/Reddy135/LocalApps/arpack/lib
> --with-arpack-flags=-lparpack,-larpack
> Thanks. I forgot the comma. That explains, why it failed this time. I did
build slepc successfully with arpack many times earlier.
 Jose
Dharmendar Reddy Palle
Graduate Student
Microelectronics Research center,
University of Texas at Austin,
10100 Burnet Road, Bldg. 160
MER 2.608F, TX 78758-4445
e-mail: dharmareddy84 at gmail.com
Phone: +1-512-350-9082
United States of America.
Homepage: https://webspace.utexas.edu/~dpr342
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130506/0a9b85f9/attachment.html>
