[petsc-users] EPSSolve in a loop
Dharmendar Reddy
dharmareddy84 at gmail.com
Sat May 4 17:31:04 CDT 2013
On Sat, May 4, 2013 at 9:54 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Dharmendar Reddy <dharmareddy84 at gmail.com> writes:
> >> You are right, The time per solve increases in both case, see the
> > attached plot.
> > I have attached the stage wise log_summary .
> Thanks.
> # WARNING!!! #
> # This code was compiled with a debugging option, #
> # To get timing results run ./configure #
> # using --with-debugging=no, the performance will #
> # be generally two or three times faster. #
> Here are some relevant events:
> --- Event Stage 1: Solve Step : 1
> IPOrthogonalize 90 1.0 7.7698e-02 1.0 3.04e+06 1.0 0.0e+00 0.0e+00
> 5.4e+02 0 1 0 0 0 18 67 0 0 32 39
> IPInnerProduct 896 1.0 5.1215e-02 1.0 1.60e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 12 35 0 0 0 31
> VecMAXPBY 179 1.0 2.0418e-02 1.0 1.44e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 5 32 0 0 0 71
> VecScale 89 1.0 9.6772e-03 1.0 7.92e+03 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 2 0 0 0 0 1
> VecReduceArith 448 1.0 3.6906e-02 1.0 1.48e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 9 32 0 0 0 40
> --- Event Stage 111: Solve Step : 111
> IPOrthogonalize 90 1.0 1.5872e+01 1.0 3.04e+06 1.0 0.0e+00 0.0e+00
> 5.4e+02 1 1 0 0 0 83 67 0 0 32 0
> IPInnerProduct 896 1.0 9.5349e+00 1.0 1.60e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00 1 0 0 0 0 50 35 0 0 0 0
> VecMAXPBY 179 1.0 6.3249e+00 1.0 1.44e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00 1 0 0 0 0 33 32 0 0 0 0
> VecScale 89 1.0 3.1402e+00 1.0 7.92e+03 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 16 0 0 0 0 0
> VecReduceArith 448 1.0 9.5169e+00 1.0 1.48e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00 1 0 0 0 0 49 32 0 0 0 0
> VecScale is simple and does exactly the same amount of work in both
> cases, so I think the problem is in memory management. It doesn't look
> like you are using enough memory to be swapping and I don't think there
> are any CHKMEMQ statements in here. You could try running with '-malloc
> 0', and/or in optimized mode.
There is no CHKMEMQ statements. I will try running the optimized modes.
Aren't the different eps objects independent ? All the objects are created
only once. Every time i call solve, all i do is EPSSetOperators and
EPSSolve.
The code is designed to provide a eigensolver to the user, without worrying
about the slepc and petsc objects inside, if i have to resue the eps
objects for all solvers then i may have to share the eps between different
instances of eigenSolver, i am not sure how easily i can do that.
I am running the code on dual 8-core Xeon X5 with 32 GB memory. I hardly
use 1 to 2 % of memory. What do you mean by memory management problem ?
> It looks like you create one EPS per loop iteration, but don't destroy
> any of them until the end. If you don't need all the EPS at once, you
> should either reuse one throughout the loop or destroy the new one each
> step after using it.
I need to reuse the eps objects, There is an outer loop
do jc=1,numSolve
computeOperators (A1,B1,A2,B2,A3,B3)
do ic=1,111
eigenSolver(ic)%solve
end do
ComputeOtherQuantities based on eigenvectors
end do
Dharmendar Reddy Palle
Graduate Student
Microelectronics Research center,
University of Texas at Austin,
10100 Burnet Road, Bldg. 160
MER 2.608F, TX 78758-4445
e-mail: dharmareddy84 at gmail.com
Phone: +1-512-350-9082
United States of America.
Homepage: https://webspace.utexas.edu/~dpr342
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130504/d29cec68/attachment.html>
