[petsc-users] Advice Being Sought
David Scott d.scott at ed.ac.uk
Fri May 3 09:16:16 CDT 2013
Barry,
On 23/04/2013 02:36, Barry Smith wrote:
> On Apr 22, 2013, at 11:26 AM, David Scott <d.scott at ed.ac.uk> wrote:
>> Thanks for the suggestion.
>> I had tried '-pc_type gamg -pc_gamg_agg_nsmooths 1' with an earlier version of the code without success. I have tried it again but I get NaN's after only 90 time steps whereas with block Jacobi it runs quite happily for 36,000 time steps and produces physically sensible results.
>    David,
>      We would be very interested in determining what is "going wrong" with the solver here since we hope to make it robust.  Would it be possible for you to use a MatView() and VecView() on the matrix and the right hand side with a binary viewer when it "goes bad" and send us the resulting file?
>     Barry
> We'd run the gamg solver on your matrix and track down what is happening.
I have inserted
     call PetscViewerBinaryOpen(PETSC_COMM_WORLD, 'DifficultSystem', &
       FILE_MODE_WRITE, viewer, ierr)
     call KSPGetOperators(ksp, A, PETSC_NULL_OBJECT, &
       PETSC_NULL_INTEGER, ierr)
     call MatView(A, viewer, ierr)
     call KSPGetRhs(ksp, b, ierr)
     call VecView(b, viewer, ierr)
     call PetscViewerDestroy(viewer, ierr)
in my code after KSPSolve.
You may download the result for the 29th time step from
   http://www2.epcc.ed.ac.uk/~dscott6/
I can generate data for other time steps if necessary.
David
Dr. D. M. Scott
Applications Consultant
Edinburgh Parallel Computing Centre
Tel. 0131 650 5921
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
