[petsc-users] Error from ex42
Prewitt . Nathan NPrewitt at drc.com
Fri Mar 8 17:06:32 CST 2013
    I have run PETSc example ex42.c using the ex42-fsschur.opts options without error.  However, if I try to use ex42-mgfs.opts, ex42-mgfs2.opts, or ex42-mgschur.opts, I get the error
PETSC ERROR:  Arguments are incompatible
PETSC ERROR:  MatPtAP requires A, mpiaij, to be compatible with P, mpimaij
Do you have any suggestions what might cause this error?
Nathan
This electronic message transmission and any attachments that accompany it contain information from DRC® (Dynamics Research Corporation) or its subsidiaries, or the intended recipient, which is privileged, proprietary, business confidential, or otherwise protected from disclosure and is the exclusive property of DRC and/or the intended recipient. The information in this email is solely intended for the use of the individual or entity that is the intended recipient. If you are not the intended recipient, any use, dissemination, distribution, retention, or copying of this communication, attachments, or substance is prohibited. If you have received this electronic transmission in error, please immediately reply to the author via email that you received the message by mistake and also promptly and permanently delete this message and all copies of this email and any attachments. We thank you for your assistance and apologize for any inconvenience.
