[petsc-users] odd SNES behavior
Mark F. Adams mark.adams at columbia.edu
Wed Mar 6 16:31:18 CST 2013
>  It looks like SNES is not getting set it's "master" Jacobian.  If you run the same code with hypre does it also hit this create?
MatCreate_MFFD is called just once with gamg and hypre.  It looks like Cheby is using the outside operator instead of the pre_op.  This could be desirable but I don't want it here.  I'll keep digging.
