[petsc-users] OpenFOAM and PETSc
Karl Rupp
rupp at mcs.anl.gov
Sun Jun 23 13:37:18 CDT 2013
Hi Chekuri,
unfortunately I don't have a direct answer for you, as we cannot keep
track of the details of all packages using PETSc. I suggest you give the
usual OpenFOAM support channels a try, for example here:
http://www.cfd-online.com/Forums/openfoam/
Best regards,
Karli
On 06/21/2013 02:09 PM, Chekuri Choudary wrote:
> OpenFOAM is mentioned in the following slides on PETSc. What exactly is
> the relationship between OpenFOAM and PETSc?
> http://www.mcs.anl.gov/petsc/documentation/tutorials/ACTSTutorial2012.pdf
> How well is PETSc integrated with OpenFOAM? Is it possible to use most
> of the linear solvers and data types in PETSc for OpenFOAM based
> applications using the FoamedOver interface mentioned in the link
> below?(http://oversetgridsymposium.org/assets/pdf/presentations/1_2/Boger_OversetSymposium2010.pdf)
> Thanks
