[petsc-users] automatic determination of which libraries petsc wants
Geoffrey Irving irving at naml.us
Thu Jan 31 19:53:48 CST 2013
On Thu, Jan 31, 2013 at 5:29 PM, Sean Farley <sean at mcs.anl.gov> wrote:
> On Thu, Jan 31, 2013 at 6:46 PM, Geoffrey Irving <irving at naml.us> wrote:
>> On Thu, Jan 31, 2013 at 4:38 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Thu, Jan 31, 2013 at 7:34 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>>> On Thu, Jan 31, 2013 at 7:25 PM, Geoffrey Irving <irving at naml.us> wrote:
>>>>> We have an scons build system linking against PETSc, and it would be
>>>>> nice to have an automatic way of determining the list of libraries
>>>>> that a statically linked, installed version of PETSc wants (e.g., the
>>>>> MacPorts installed version).  What's a good way to do such a thing
>>>>> from *outside* the PETSc build system?
>>>> It depends on how much work you want to do. For at least two years I
>>>> think,
>>>> our default had been -lpetsc. I would just do this.
>>> Satish is right, use 'make getlinklibs'.
>>> However, if you don't have to waste time on a life or family, you may want
>>> to consider
>>> getting the info straight from the configure. You can load up the Python
>>> module from
>>> from $PETSC_ARCH/conf/RDict.db and pull out all these things. There is an
>>> example
>>> in configVars.py.
>> configVars.py errors out at "import script":
>>> ./bin/configVars.py
>> Traceback (most recent call last):
>>   File "./bin/configVars.py", line 7, in <module>
>>     import script
>> ImportError: No module named script
>> Indeed, I don't see any file named script.py anywhere underneath
>> /optlocal/lib/petsc, nor any directory named exactly "config" as
>> configVars seems to want.
>> Bad macports, bad?
> MacPorts does a lot of things bad ;-) Actually, now that I'm a
> certified MacPorts developer, I've had my sights on fixing the PETSc
> port. First, I need to do some massaging to get the other devs to
> understand the need of a standalone gfortran port. Then, the rest will
> fall in place (hopefully).
Cool, I look forward to that.  For now I ended up just updating our
manual list of libraries.
Geoffrey
