[petsc-users] automatic determination of which libraries petsc wants
Thu Jan 31 19:15:01 CST 2013
I agree with using PETSc.pc now that it's available (but it's not in
petsc-3.3).
FWIW, it should be putting everything but libpetsc into Libs.private (which
will be used for static linking).
On Thu, Jan 31, 2013 at 7:05 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Why all the nonstandard suggestions, why not just do what Satish
> suggested: (if those work for you let us know and we'll improve the
> pkgconfig file
> Barrys-MacBook-Pro:power_grid barrysmith$ more
> ~/Src/petsc-dev/arch-gnu/lib/pkgconfig/PETSc.pc
> prefix=/Users/barrysmith/Src/petsc-dev
> exec_prefix=${prefix}
> includedir=${prefix}/include
> libdir=/Users/barrysmith/Src/petsc-dev/arch-gnu/lib
> ccompiler=/Users/barrysmith/Src/petsc-dev/arch-gnu/bin/mpicc
> fcompiler=/Users/barrysmith/Src/petsc-dev/arch-gnu/bin/mpif90
> blaslapacklibs=-llapack -lblas
> Description: Library to solve ODEs and algebraic equations
> Version: 3.3.0
> Cflags: -I/Users/barrysmith/Src/petsc-dev/include
> -I/Users/barrysmith/Src/petsc-dev/arch-gnu/include
> -I/usr/local/include/libAfterImage/ -I/opt/X11/include
> -I/Users/barrysmith/Src/ams-dev/include
> Libs: -L/Users/barrysmith/Src/petsc-dev/arch-gnu/lib  -lpetsc -lHYPRE
> -L/usr/llvm-gcc-4.2/lib/gcc/i686-apple-darwin11/4.2.1/x86_64
> -L/Applications/Xcode.app/Contents/Developer/usr/llvm-gcc-4.2/lib/gcc/i686-apple-darwin11/4.2.1/x86_64
> -lmpichcxx -lstdc++ -lml -lmpichcxx -lstdc++ -lcmumps -ldmumps -lsmumps
> -lzmumps -lmumps_common -lpord -lscalapack -lsuperlu_4.3 -lsuperlu_dist_3.2
> -llapack -lblas -L/usr/local/include/libAfterImage/../../lib -lAfterImage
> -ltriangle -L/opt/X11/lib -lX11 -L/Users/barrysmith/Src/ams-dev/lib
> -lamspub -lparmetis -lmetis -lfftw3_mpi -lfftw3 -lptesmumps -lptscotch
> -lptscotcherr -lpthread -lyaml -lmpichf90 -lgfortran
> -L/usr/local/lib/gcc/x86_64-apple-darwin10.7.0/4.6.0 -L/usr/local/lib
> -lgfortran -lgcc_ext.10.5 -lquadmath -lm -lm -lmpichcxx -lstdc++ -lm -lz
> -lz -ldl -lpmpich -lmpich -lopa -lmpl -lSystem -ldl
> On Jan 31, 2013, at 6:34 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > On Thu, 31 Jan 2013, Geoffrey Irving wrote:
> >> We have an scons build system linking against PETSc, and it would be
> >> nice to have an automatic way of determining the list of libraries
> >> that a statically linked, installed version of PETSc wants (e.g., the
> >> MacPorts installed version).  What's a good way to do such a thing
> >> from *outside* the PETSc build system?
> > One way is for some script [like configure or equivalent] to create a
> > simple petsc makefile and use any of the following targets to get
> > the required info
> > asterix:/home/balay/tmp>cat makefile
> > PETSC_DIR=/home/balay/spetsc
> > PETSC_ARCH=asterix64
> > include ${PETSC_DIR}/conf/variables
> > include ${PETSC_DIR}/conf/rules
> > asterix:/home/balay/tmp>make getincludedirs
> > -I/home/balay/spetsc/include -I/home/balay/spetsc/asterix64/include
> -I/home/balay/soft/linux64/mpich2-1.1/include
> -I/home/balay/soft/mpich2-1.5/include
> > asterix:/home/balay/tmp>make getlinklibs
> > -Wl,-rpath,/home/balay/spetsc/asterix64/lib
> -L/home/balay/spetsc/asterix64/lib -lpetsc -llapack -lblas -lX11 -lpthread
> -lm -Wl,-rpath,/home/balay/soft/mpich2-1.5/lib
> -L/home/balay/soft/mpich2-1.5/lib
> -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.7.2
> -L/usr/lib/gcc/x86_64-redhat-linux/4.7.2 -lmpichf90 -lgfortran -lm
> -lgfortran -lm -lquadmath -lm -ldl -lmpich -lopa -lmpl -lrt -lgcc_s -ldl
> > [more similar targets are listed in conf/rules]
> > The other option is to use pkgconfig file created by configure.
> > It should be in PETSC_ARCH/lib/pkgconfig [in petsc-dev]
> > Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130131/c34a9064/attachment-0001.html>
