[petsc-users] automatic determination of which libraries petsc wants
Satish Balay
balay at mcs.anl.gov
Thu Jan 31 18:53:54 CST 2013
On Thu, 31 Jan 2013, Matthew Knepley wrote:
> On Thu, Jan 31, 2013 at 7:46 PM, Geoffrey Irving <irving at naml.us> wrote:
> > On Thu, Jan 31, 2013 at 4:38 PM, Matthew Knepley <knepley at gmail.com>
> > wrote:
> > > On Thu, Jan 31, 2013 at 7:34 PM, Matthew Knepley <knepley at gmail.com>
> > wrote:
> > >> On Thu, Jan 31, 2013 at 7:25 PM, Geoffrey Irving <irving at naml.us>
> > wrote:
> > >>> We have an scons build system linking against PETSc, and it would be
> > >>> nice to have an automatic way of determining the list of libraries
> > >>> that a statically linked, installed version of PETSc wants (e.g., the
> > >>> MacPorts installed version). What's a good way to do such a thing
> > >>> from *outside* the PETSc build system?
> > >> It depends on how much work you want to do. For at least two years I
> > >> think,
> > >> our default had been -lpetsc. I would just do this.
> > > Satish is right, use 'make getlinklibs'.
> > > However, if you don't have to waste time on a life or family, you may
> > want
> > > to consider
> > > getting the info straight from the configure. You can load up the Python
> > > module from
> > > from $PETSC_ARCH/conf/RDict.db and pull out all these things. There is an
> > > example
> > > in configVars.py.
> > configVars.py errors out at "import script":
> > > ./bin/configVars.py
> > Traceback (most recent call last):
> > File "./bin/configVars.py", line 7, in <module>
> > import script
> > ImportError: No module named script
> > Indeed, I don't see any file named script.py anywhere underneath
> > /optlocal/lib/petsc, nor any directory named exactly "config" as
> > configVars seems to want.
> > Bad macports, bad?
> Requires config/BuildSystem in PYTHONPATH. This is what configure.py does
> first.
This requires PETSc sources - which would be missing in "prefix install"
of PETSc. [which macports presumably uses]
Satish
