[petsc-users] dense matrix problem
Matthew Knepley
knepley at gmail.com
Thu Jan 31 12:12:20 CST 2013
On Thu, Jan 31, 2013 at 12:31 PM, Alex Salazar <alejandrocof at gmail.com>wrote:
> Thanks Jed, sorry I new using Petsc.
> I am runing my program with default options :
> mpirun -np 1 ./a.out
> runing the program with a few points (10) the interpolation is aceptable,
> using the monitor options ie.
> mpirun -np 1 ./a.out -ksp_converged_reason -ksp_monitor_true_residual
> the output is the next
> 0 KSP preconditioned resid norm 7.415666989515e+05 true resid norm
> 1.510533668194e+04 ||r(i)||/||b|| 1.000000000000e+00
> 1 KSP preconditioned resid norm 4.935801698308e+02 true resid norm
> 1.721762948997e+01 ||r(i)||/||b|| 1.139837519183e-03
> 2 KSP preconditioned resid norm 1.038493428107e-01 true resid norm
> 9.406615966569e+00 ||r(i)||/||b|| 6.227346112594e-04
> Linear solve converged due to CONVERGED_RTOL iterations 2
> But if encrease the number of points to interpolate, the result is
> incorrect and the time of convergece encrease, the output in this case is:
> 138 KSP preconditioned resid norm 4.897817095518e-06 true resid norm
> 5.455886375264e-08 ||r(i)||/||b|| 4.852601039969e-10
> 139 KSP preconditioned resid norm 3.535973415166e-06 true resid norm
> 3.717900878947e-08 ||r(i)||/||b|| 3.306793512687e-10
> 140 KSP preconditioned resid norm 2.450794339359e-06 true resid norm
> 3.009597005096e-08 ||r(i)||/||b|| 2.676810430480e-10
> Linear solve converged due to CONVERGED_RTOL iterations 140
> [0] time (sec) 89.940000
You have an ill-conditioned system, so you will have to lower the
tolerance. Also note that your
preconditioner is a piece of crap.
Matt
> the code where the solution is implemented is the next:
> KSP ksp;
> KSPCreate(PETSC_COMM_WORLD,&ksp);
> KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN);
> KSPSetTolerances(ksp,1.e-5/(N+nt+1),1.e-50,PETSC_DEFAULT,PETSC_DEFAULT);
> KSPSetFromOptions(ksp);
> KSPSolve(ksp,b,x);
> Let me know if you need another information.
> Regard Alex
> 2013/1/31 Jed Brown <jedbrown at mcs.anl.gov>
>> "result is incorrect" is not helpful. Please include diagnostics. Are you
>> using an iterative or direct solver? Start here if you don't know what to
>> check:
>> http://scicomp.stackexchange.com/questions/513/why-is-my-iterative-linear-solver-not-converging
>> On Thu, Jan 31, 2013 at 9:58 AM, Alex Salazar <alejandrocof at gmail.com>wrote:
>>> Hello, everyone
>>> I want to get the solution of algrebraic system (with a dense
>>> zero-diagonal simetric matrix) of a interpolation problem (using radial
>>> basis functions) with Petsc.
>>> For a few points (around 10 elements) using KSP I get the correct
>>> solution, however when I increase the number of points, the result is
>>> incorrect.
>>> Any Idea ?
>>> Regards Alejandro.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130131/fdefb32e/attachment.html>
