[petsc-users] order dependency in petsc options?
Matthew Knepley
knepley at gmail.com
Wed Jan 30 19:38:35 CST 2013
On Wed, Jan 30, 2013 at 7:32 PM, Geoffrey Irving <irving at naml.us> wrote:
> I'm setting options via
> CHECK(PetscOptionsClear());
> CHECK(PetscOptionsInsert(&argc,&argv,0));
> a while after calling PetscInitialize(). If the options are
> -ksp_rtol 1e-3 -pc_factor_mat_ordering_type nd -ksp_type cg
> -pc_type icc -pc_factor_levels 0 -ksp_max_it 100
> it successfully caps CG iterations at 100. If I use
> -ksp_max_it 100 -ksp_rtol 1e-3 -pc_factor_mat_ordering_type nd
> -ksp_type cg -pc_type icc -pc_factor_levels 0
> the maximum iterations are 10000. I.e., -ksp_max_it work at the end
> but not at the beginning. What might be causing this order
> dependence? I'm using
If you are using straight up argv, then the first argument is always the
program name
and gets ignored.
Matt
> [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 3, Wed Aug 29
> 11:26:24 CDT 2012
> Thanks,
> Geoffrey
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130130/26a26561/attachment.html>
