[petsc-users] newbie questions on preconditioner LU
Jed Brown
jedbrown at mcs.anl.gov
Mon Jan 28 13:50:12 CST 2013
On Mon, Jan 28, 2013 at 1:46 PM, Ling Zou <lingzou80 at gmail.com> wrote:
> As you explained, M is not explicitly computed. However, when setup the ksp
> KSPSetOperators(KSP ksp,Mat Amat,Mat Pmat,MatStructure flag);
> We need a Pmat (the M we are talking about here). In the solver, we
> actually need M^{-1}
The two statements above contradict. You can *either* have M=Pmat or you
can have "M^{-1}" is the preconditioning operation used in the Krylov
method.
> as the preconditioning matrix, so we don't need to compute the M matrix
> but need PC to get the approximated M^{-1}, right? Even we don't explicitly
> compute M, but we still need provide non-zero entries for this M, is it
> correct?
You need to provide a matrix that will be used to compute a preconditioning
operation. The preconditioning operation will *not* be the inverse of the
matrix you provide, but it may be "close".
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130128/c02d47b1/attachment.html>
