[petsc-users] A little help for running config
Yonghui
lyh03259.aps at gmail.com
Thu Jan 24 15:38:53 CST 2013
Dear PETSc users,
I am trying to compile PETSc, but there seems to be some problems when I run
config.
Here is my config command: ./config --prefix=/opt/PETSc --with-c++-support=1
--with-c-support=1 --with-fortran=1 --with-mpi-dir=/opt/mpich2
And here is the error message:
TESTING: checkCLibraries from
config.compilers(/home/biu/Projects/petsc-3.3-p5/config/BuildSystem/c
onfig/compilers.py:161)
UNABLE to EXECUTE BINARIES for ./configure
Cannot run executables created with FC. If this machine uses a batch system
to submit jobs you will need to configure using ./configure with the
additional option --with-batch.
Otherwise there is problem with the compilers. Can you compile and run code
with your C/C++ (and maybe Fortran) compilers?
I just installed intel compiler on the machine this morning without any
error. Then I compiled mpich2 (details below) with the intel compiler.
Then sudo make install in /opt/mpich2. There is no error when compiling
mpich2.
More details:
OS: Ubuntu 12.04 LTS (32-bit).
CPU: Intel® Core i7-2630QM CPU @ 2.00GHz × 4
RAM: 2GB
Compiler: icc (ICC) 13.0.1 20121010, ifort (IFORT) 13.0.1 20121010 (Parallel
studio 2013 update1).
MPICH2: 1.4.1p1 (compiled with compilers above without error).
Any suggestion will be appreciated.
Yonghui
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130124/72128263/attachment.html>
