[petsc-users] MatMatMult size error
Jim Fonseca
jefonseca at gmail.com
Tue Jan 15 15:05:40 CST 2013
Hi Jed,
We didn't see obvious memory corruption with valgrind.
We printed matrix A and B and they both appear correct.
We think it may be related to the matrices being non-square. Could it be
related to that?
Also, if we run outside the debugger, we get the following error, but I'm
not sure which line that is coming from.
terminate called after throwing an instance of 'std::runtime_error'
what(): [PetscMatrixNemo<cplx>] PETSc gave error with code 73:
Object is in wrong state
Jim
On Tue, Jan 15, 2013 at 1:00 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> This looks like memory corruption. Can you run in valgrind?
> On Tue, Jan 15, 2013 at 11:54 AM, Jim Fonseca <jefonseca at gmail.com> wrote:
>> Hi,
>> We are in the process of upgrading from Petsc 3.2 to 3.3p5.
>> We are creating matrices A and B in this way.
>> petsc_matrix = new Mat;
>> ierr = MatCreateDense(comm, m, num_cols ,num_rows,num_cols,data,A);
>> Elsewhere, we have this. It gets called a few times, and on the 4th time,
>> the size of matrix is C is wrong. Please see the output below. What could
>> be the problem?
>> C = new Mat;
>> double fill = PETSC_DEFAULT;
>> MatMatMult(A,B,MAT_INITIAL_MATRIX, fill, C);
>> int m,n;
>> MatGetOwnershipRange(A, &m, &n);
>> cerr << "A.m = " << m << "\n";
>> cerr << "A.n = " << n << "\n";
>> MatGetSize(A,&m,&n);
>> cerr << "A global rows = " << m << "\n";
>> cerr << "A global cols = " << n << "\n";
>> MatGetOwnershipRange(B, &m, &n);
>> cerr << "B.m = " << m << "\n";
>> cerr << "B.n = " << n << "\n";
>> MatGetSize(B,&m,&n);
>> cerr << "B global rows = " << m << "\n";
>> cerr << "B global cols = " << n << "\n";
>> MatGetOwnershipRange(*C, &m, &n);
>> cerr << "C.m = " << m << "\n";
>> cerr << "C.n = " << n << "\n";
>> MatGetSize(*C,&m,&n);
>> cerr << "C global rows = " << m << "\n";
>> cerr << "C global cols = " << n << "\n";
>> A.m = 0
>> A.n = 59
>> A global rows = 59
>> A global cols = 320
>> B.m = 0
>> B.n = 320
>> B global rows = 320
>> B global cols = 320
>> C.m = 0
>> C.n = 59
>> C global rows = 59
>> C global cols = 320
>> A.m = 0
>> A.n = 59
>> A global rows = 59
>> A global cols = 320
>> B.m = 0
>> B.n = 320
>> B global rows = 320
>> B global cols = 59
>> C.m = 10922
>> C.n = -1389327096
>> C global rows = -1389327112
>> C global cols = -1389327112
>> Thanks,
>> Jim
>> Jim Fonseca, PhD
>> Research Scientist
>> Network for Computational Nanotechnology
>> Purdue University
>> 765-496-6495
>> www.jimfonseca.com
Jim Fonseca, PhD
Research Scientist
Purdue University
765-496-6495
www.jimfonseca.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130115/7adf64c7/attachment.html>
