[petsc-users] submatrix times subvector
Jed Brown
jedbrown at mcs.anl.gov
Tue Jan 15 12:23:04 CST 2013
On Tue, Jan 15, 2013 at 12:09 PM, Tabrez Ali <stali at geology.wisc.edu> wrote:
> Jed
> The problem with MatGetSubMatrix is that iscol isn't available easily. I
> want to get all associated columns but according to the man page it is not
> possible in Fortran.
> "If iscol is PETSC_NULL then all columns are obtained (not supported in
> Fortran)."
Well, we could add Fortran support for that case (it currently needs a
custom binding to do that) or you can
call MatGetColumnOwnershipRange(A,colstart,colend,ierr)
ncols = colend - colstart
call ISCreateStride(comm,ncols,colstart,one,iscol,ierr)
and pass iscol to MatGetSubMatrix(). This is what's done internally when
you pass iscol=NULL:
if (!iscol) {
ierr =
ISCreateStride(((PetscObject)mat)->comm,mat->cmap->n,mat->cmap->rstart,1,&iscoltmp);CHKERRQ(ierr);
> Is there a workaround?
> Tabrez
> On 01/14/2013 03:38 PM, Jed Brown wrote:
> On Mon, Jan 14, 2013 at 3:27 PM, Tabrez Ali <stali at geology.wisc.edu>wrote:
>> Hello
>> I am solving a system of equations of the form:
>> |A C| |u1| = |f1|
>> |C'B| |u2| |f2|
>> After each solve, I need to perform B*f2 before updating f. Should I use
>> MatGetSubMatrix/VecGetSubVector followed by MatMult or is there something
>> simpler.
> Yes, or let PCFIELDSPLIT do all the block solver stuff for you.
> No one trusts a model except the one who wrote it; Everyone trusts an observation except the one who made it- Harlow Shapley
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130115/4422dd1f/attachment.html>
